I want to disable the USB Ethernet. I don’t need it and it’s interfering with something I am trying to do. Running Debian Wheezy 7.1. Thanks.
-Tom
-Tom
Which board is this on?
Did I post in the wrong forum? It’s the black.
-Tom
This forum covers all of them, BeagleBoard, BeagleBoard-xM, BeagleBone, and BeagleBone Black.
So why not just not plug it in? Just power the board over DC.
If that is not possible. then I will defer to the SW experts on how to shut that gadget down.
The USB cable is not plugged in. I am powering it thru the DC jack. It still comes up with a valid IP. I’m trying to run Open Lighting Architecture and I have a script that restarts it if it doesn’t have Ethernet. But it’s binding to the USB Ethernet.
-Tom
The Ethernet on the board is not USB based so I have no idea where that is coming from unless it is always there just in case,.
There was always USB0 on the Armstrong image also.
-Tom
I got rid of the USB0 entry in /etc/network/interfaces, but it still shows up somehow.
-Tom
Depends on which Debian distro you have but have a look if you have scripts in /opt/boot-scripts/
Brian
From the fat partition, just remove the file "run_boot-scripts", and
everything specific to the beaglebone image will be disabled...
The "setup_sdcard.sh" script has a warning/note about this, but no one
reads all the stuff..
Sweet! That worked. Thanks Robert.
-Tom
