Hi All,
Now I am able to see installed drivers using lsmod command.
Steps I followed ā¦
I use buildroot for MLO, u-boot.img, extlinux/ and rootfs.tar
build mainline Linux kernel.
make ARCH=arm distclean
make ARCH=arm omap2plus_defconfig
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- menuconfig
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage dtbs -j10
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- modules -j10
sudo make ARCH=arm modules_install INSTALL_MOD_PATH=/media/riscv/Rootfs/
sudo cp arch/arm/boot/zImage /media/riscv/Rootfs/BOOT && sync
sudo cp arch/arm/boot/dts/ti/omap/am355x-boneblack.dtb /media/riscv/Rootfs/BOOT && sync
extlinux/extlinux.conf
label beaglebone-buildroot
kernel /zImage
devicetree /am335x-boneblack.dtb
fdtdir /
append console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
U-Boot SPL 2023.04 (Oct 04 2023 - 16:14:54 +0530)
Trying to boot from MMC1
U-Boot 2023.04 (Oct 04 2023 - 16:14:54 +0530)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
Core: 160 devices, 18 uclasses, devicetree: separate
WDT: Started wdt@44e35000 with servicing every 1000ms (60s timeout)
NAND: 0 MiB
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
<ethaddr> not set. Validating first E-fuse MAC
Net: eth2: ethernet@4a100000, eth3: usb_ether
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
1: beaglebone-buildroot
Retrieving file: /zImage
append: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
Retrieving file: /am335x-boneblack.dtb
Kernel image @ 0x82000000 [ 0x000000 - 0x4ee988 ]
## Flattened Device Tree blob at 88000000
Working FDT set to 88000000
Loading Device Tree to 8ffeb000, end 8ffff1be ... OK
Working FDT set to 8ffeb000
Starting kernel ...
[ 0.000000] Linux version 6.6.0-rc3 (root@riscv-demo) (arm-linux-gnueabihf-gcc (GCC) 14.0.0 20230605 (experimental) [master revision c7fe7ad612bb6aac1d078d215d5700ec4ef70e3c], GNU ld (Linaro_Binutils-2023.06) 2.40.50.20230605) #1 SMP Fri Oct 6 09:19:37 IST 2023
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 16 MiB at 0x9e800000 on node -1
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] percpu: Embedded 16 pages/cpu s36052 r8192 d21292 u65536
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 484740K/522240K available (10240K kernel code, 1108K rwdata, 2532K rodata, 1024K init, 283K bss, 21116K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[ 0.000003] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000026] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000485] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[ 0.001933] Console: colour dummy device 80x30
[ 0.002008] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.090533] CPU: Testing write buffer coherency: ok
[ 0.090638] CPU0: Spectre v2: using BPIALL workaround
[ 0.090648] pid_max: default: 32768 minimum: 301
[ 0.090772] LSM: initializing lsm=capability,integrity
[ 0.090940] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.090961] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.092434] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.094016] Setting up static identity map for 0x80100000 - 0x80100078
[ 0.094299] rcu: Hierarchical SRCU implementation.
[ 0.094308] rcu: Max phase no-delay instances is 1000.
[ 0.095018] smp: Bringing up secondary CPUs ...
[ 0.095063] smp: Brought up 1 node, 1 CPU
[ 0.095075] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[ 0.095086] CPU: All CPU(s) started in SVC mode.
[ 0.095928] devtmpfs: initialized
[ 0.111340] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.111689] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.111724] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.113058] pinctrl core: initialized pinctrl subsystem
[ 0.115424] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.117921] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.118504] audit: initializing netlink subsys (disabled)
[ 0.119732] thermal_sys: Registered thermal governor 'fair_share'
[ 0.119751] thermal_sys: Registered thermal governor 'step_wise'
[ 0.119758] thermal_sys: Registered thermal governor 'user_space'
[ 0.119862] audit: type=2000 audit(0.110:1): state=initialized audit_enabled=0 res=1
[ 0.119938] cpuidle: using governor menu
[ 0.135697] No ATAGs?
[ 0.135721] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.138562] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.795722] iommu: Default domain type: Translated
[ 0.795742] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.797137] SCSI subsystem initialized
[ 0.798861] pps_core: LinuxPPS API ver. 1 registered
[ 0.798872] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.798895] PTP clock support registered
[ 0.800784] vgaarb: loaded
[ 0.801082] clocksource: Switched to clocksource dmtimer
[ 0.801679] VFS: Disk quotas dquot_6.6.0
[ 0.801738] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.823437] NET: Registered PF_INET protocol family
[ 0.823773] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.825110] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.825144] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.825162] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.825205] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.825304] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.825438] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.825466] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.825640] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.826790] RPC: Registered named UNIX socket transport module.
[ 0.826813] RPC: Registered udp transport module.
[ 0.826818] RPC: Registered tcp transport module.
[ 0.826823] RPC: Registered tcp-with-tls transport module.
[ 0.826829] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.826854] PCI: CLS 0 bytes, default 64
[ 0.828372] Initialise system trusted keyrings
[ 0.829216] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.830398] NFS: Registering the id_resolver key type
[ 0.830465] Key type id_resolver registered
[ 0.830473] Key type id_legacy registered
[ 0.830523] jffs2: version 2.2. (NAND) (SUMMARY) Ā© 2001-2006 Red Hat, Inc.
[ 0.830983] Key type asymmetric registered
[ 0.830997] Asymmetric key parser 'x509' registered
[ 0.831219] io scheduler mq-deadline registered
[ 0.831235] io scheduler kyber registered
[ 0.831320] io scheduler bfq registered
[ 0.835202] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[ 0.853745] brd: module loaded
[ 0.861628] loop: module loaded
[ 0.862529] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 0.865172] i2c_dev: i2c /dev entries driver
[ 0.865999] cpuidle: enable-method property 'ti,am3352' found operations
[ 0.866440] sdhci: Secure Digital Host Controller Interface driver
[ 0.866449] sdhci: Copyright(c) Pierre Ossman
[ 0.866624] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.866880] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.867619] Initializing XFRM netlink socket
[ 0.867771] NET: Registered PF_INET6 protocol family
[ 0.869486] Segment Routing with IPv6
[ 0.869561] In-situ OAM (IOAM) with IPv6
[ 0.869672] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 0.870581] NET: Registered PF_PACKET protocol family
[ 0.870609] NET: Registered PF_KEY protocol family
[ 0.870735] Key type dns_resolver registered
[ 0.870935] ThumbEE CPU extension supported.
[ 0.870956] Registering SWP/SWPB emulation handler
[ 0.871529] omap_voltage_late_init: Voltage driver support not added
[ 0.871873] SmartReflex Class3 initialized
[ 0.879205] Loading compiled-in X.509 certificates
[ 0.920339] platform 44e10800.pinmux: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@10000/scm@0/pinmux@800/clkout2-pins
[ 0.920872] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 0.925595] ti-sysc: probe of 44e31000.target-module failed with error -16
[ 0.939938] ti-sysc: probe of 48040000.target-module failed with error -16
[ 0.952381] OMAP GPIO hardware version 0.1
[ 0.965047] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.994773] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[ 0.995267] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 1.051096] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.072924] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.073365] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[ 1.073383] cpsw-switch 4a100000.switch: ALE Table size 1024
[ 1.073506] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
[ 1.073522] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[ 1.073610] cpsw-switch 4a100000.switch: Detected MACID = 6c:ec:eb:a5:a0:34
[ 1.075324] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[ 1.085756] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[ 1.085798] edma 49000000.dma: TI EDMA DMA engine driver
[ 1.105830] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 1.113188] l3-aon-clkctrl:0000:0: failed to disable
[ 1.115457] printk: console [ttyS0] disabled
[ 1.116234] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 34, base_baud = 3000000) is a 8250
[ 1.116312] printk: console [ttyS0] enabled
[ 2.071969] tps65217-pmic: Failed to locate of_node [id: -1]
[ 2.077999] tps65217-bl: Failed to locate of_node [id: -1]
[ 2.088829] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 2.095017] i2c 0-0070: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0/port/endpoint@0
[ 2.107777] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 2.117309] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 2.126222] sdhci-omap 48060000.mmc: Got CD GPIO
[ 2.131249] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
[ 2.141853] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 2.151675] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[ 2.160273] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 2.176134] clk: Disabling unused clocks
[ 2.197196] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[ 2.206184] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 2.215024] Waiting for root device /dev/mmcblk0p2...
[ 2.281329] mmc1: new high speed MMC card at address 0001
[ 2.287694] mmc0: new high speed SDHC card at address e624
[ 2.294274] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[ 2.299937] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[ 2.308118] mmcblk1: p1 p2
[ 2.311596] mmcblk0: p1 p2
[ 2.315629] mmcblk1boot0: mmc1:0001 MMC04G 2.00 MiB
[ 2.323323] mmcblk1boot1: mmc1:0001 MMC04G 2.00 MiB
[ 2.330064] mmcblk1rpmb: mmc1:0001 MMC04G 128 KiB, chardev (250:0)
[ 2.465909] EXT4-fs (mmcblk0p2): recovery complete
[ 2.478237] EXT4-fs (mmcblk0p2): mounted filesystem 1a64b592-aa5f-414f-9644-5e7e70d5bbe7 r/w with ordered data mode. Quota mode: none.
[ 2.490592] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.503994] devtmpfs: mounted
[ 2.508443] Freeing unused kernel image (initmem) memory: 1024K
[ 2.515026] Run /sbin/init as init process
[ 2.675985] EXT4-fs (mmcblk0p2): re-mounted 1a64b592-aa5f-414f-9644-5e7e70d5bbe7 r/w. Quota mode: none.
Seeding 256 bits without crediting
Saving 256 bits of non-creditable seed for next boot
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Starting mdev... OK
[ 4.461523] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 4.467788] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 4.501034] at24 2-0054: supply vcc not found, using dummy regulator
[ 4.536995] at24 2-0055: supply vcc not found, using dummy regulator
[ 4.575390] at24 2-0056: supply vcc not found, using dummy regulator
[ 4.615295] at24 2-0057: supply vcc not found, using dummy regulator
[ 4.657917] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.684025] remoteproc remoteproc0: wkup_m3 is available
[ 5.034668] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 5.304150] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 5.312353] input: tps65217_pwrbutton as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 5.400808] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 5.408087] random: crng init done
[ 5.432622] omap_rtc 44e3e000.rtc: already running
[ 5.459112] omap_rtc 44e3e000.rtc: registered as rtc0
[ 5.464443] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:04:08 UTC (946685048)
[ 5.514808] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 5.541375] omap-sham 53100000.sham: will run requests pump with realtime priority
[ 5.733768] tda998x 0-0070: found TDA19988
[ 5.753459] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops [tda998x])
[ 5.772836] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[ 5.781965] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[ 5.790464] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[ 5.836416] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[ 5.883222] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[ 5.989330] usbcore: registered new interface driver usbfs
[ 5.995141] usbcore: registered new interface driver hub
[ 6.000574] usbcore: registered new device driver usb
[ 6.128044] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 6.133662] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 6.151837] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 6.160190] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.167568] usb usb1: Product: MUSB HDRC host driver
[ 6.172593] usb usb1: Manufacturer: Linux 6.6.0-rc3 musb-hcd
[ 6.178281] usb usb1: SerialNumber: musb-hdrc.1
[ 6.205079] hub 1-0:1.0: USB hub found
[ 6.211562] hub 1-0:1.0: 1 port detected
[ 6.264144] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 6.304954] remoteproc remoteproc0: powering up wkup_m3
[ 6.310418] remoteproc remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2
[ 6.320132] remoteproc remoteproc0: request_firmware failed: -2
[ 6.326164] wkup_m3_ipc 44e11324.wkup_m3_ipc: rproc_boot failed
[ 6.363312] PM: Cannot get wkup_m3_ipc handle
Starting network: OK
Welcome to Buildroot
buildroot login: root
# iconfig[ 16.481924] PM: Cannot get wkup_m3_ipc handle
[ 16.486607] platform pm33xx: deferred probe pending
-sh: iconfig: not found
# ifconig
-sh: ifconig: not found
# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
# lsmod | more
Module Size Used by Not tainted
pm33xx 12288 0
cpufreq_dt 12288 0
wkup_m3_ipc 12288 1 pm33xx
omap_wdt 12288 0
watchdog 24576 1 omap_wdt
musb_dsps 16384 0
musb_hdrc 126976 1 musb_dsps
udc_core 45056 1 musb_hdrc
snd_soc_hdmi_codec 16384 1
usbcore 204800 1 musb_hdrc
phy_am335x 12288 2
phy_generic 12288 1 phy_am335x
usb_common 12288 5 musb_dsps,musb_hdrc,udc_core,usbcore,phy_am335x
tda998x 20480 0
snd_soc_simple_card 16384 0
snd_soc_simple_card_utils 16384 1 snd_soc_simple_card
omap_sham 28672 0
evdev 20480 0
rtc_omap 16384 2 pm33xx
omap_rng 12288 0
rng_core 16384 1 omap_rng
tps65218_pwrbutton 12288 0
snd_soc_davinci_mcasp 24576 2
snd_soc_ti_udma 12288 1 snd_soc_davinci_mcasp
snd_soc_ti_edma 12288 1 snd_soc_davinci_mcasp
snd_soc_ti_sdma 12288 1 snd_soc_davinci_mcasp
snd_soc_core 180224 7 snd_soc_hdmi_codec,snd_soc_simple_card,snd_soc_simple_card_utils,snd_soc_davinci_mcasp,snd_soc_ti_udma,snd_soc_ti_edma,snd_soc_ti_sdma
snd_pcm_dmaengine 12288 1 snd_soc_core
snd_pcm 110592 5 snd_soc_hdmi_codec,snd_soc_simple_card_utils,snd_soc_davinci_mcasp,snd_soc_core,snd_pcm_dmaengine
snd_timer 32768 1 snd_pcm
snd 69632 4 snd_soc_hdmi_codec,snd_soc_core,snd_pcm,snd_timer
soundcore 12288 1 snd
omap_mailbox 16384 1
leds_gpio 12288 0
led_class 12288 1 leds_gpio
tilcdc 32768 0
drm_dma_helper 16384 2 tilcdc
drm_kms_helper 122880 3 tda998x,tilcdc,drm_dma_helper
drm 425984 5 tda998x,tilcdc,drm_dma_helper,drm_kms_helper
drm_panel_orientation_quirks 12288 1 drm
ti_emif_sram 12288 1 pm33xx
cppi41 16384 60
wkup_m3_rproc 12288 1
phy_am335x_control 12288 1 phy_am335x
at24 16384 0
omap_aes_driver 24576 0
omap_crypto 12288 1 omap_aes_driver
crypto_engine 12288 2 omap_sham,omap_aes_driver
libaes 12288 1 omap_aes_driver
Thanks & Regards
Vivek Yadav
