Hi, There,
I successfully built image for the beagleboard following instruction
at http://www.angstrom-distribution.org/building-angstrom.
When I tried to bitbake the pulseaudio module, there is a error
"configure: error: Unable to find libltdl version 2. Makes sure you
have libtool 2.2 or later installed."
with the command
"bitbake -c clean -b $(OETREE)/sources/openembedded/recipes/pulseaudio/
pulseaudio_0.9.21.bb"
"bitbake -c compile -b $(OETREE)/sources/openembedded/recipes/
pulseaudio/pulseaudio_0.9.21.bb"
I check my /usr/local/angstrom/arm, the libltdl.so and ltdl.h is
there. anybody have simular issue? Do I use the bitbake correctly?
Xu Wei
