I got some new beagleboards from Digikey, and I tried to load Ubuntu
10.10 Maverick on it, like the other boards that we got, but it didn't
work. It turns out that it's Rev C.
There is no mention of this Rev for Maverick, but for Natty (11.04)
there is no mention of the Rev's that it supports (or I didn't see
anything), so I tried that instead.
It turns out that there are two versions of Natty. The headless and
regular version. I first tried the regular version, but it doesn't
seem to boot up. Actually, it may have booted up, but I can't get the
display to work. I have a pretty modern monitor, but it can't seem to
do 1280x720 (a friend joked that I should use an HD tv). One monitor
supports 1280x768, but that didn't work either. Supposedly,there is a
bug for the monitor problem, but one that won't get fixed.
I then tried the headless version, but it keeps erroring out. After I
configure the keyboard and such, it also mentioned something about not
having the network configured. It starts to install but at 15% it
quits. I tried many times to install this, but it fails.
I looked at the manual to try to get an idea of what changed, and it
points to the older manual, Rev C4.
That version of parted is really old (August 2007 according to
parted's ftp site..).. You can use sed to remove every "--align" from
the script as it's not essential, (it should just align the partitions
better) but the rest may still may not work depending on how old fdisk
is..
I need to tweak the script to not use "--align" for parted <= 2.1
"ttyS2" is the older serial port name, just for legacy sake (kernel <=
2.6.35) i have both ttyS2 and ttyO2 enabled by default so people can
easily use old/new kernels..
For Ubuntu:
sudo rm -f /etc/init/ttyS2.conf
And then you shouldn't see the message ever again.
Thanks so much for your Ubuntu Demo images,
My xM Rec C is now up and running. I'm only stuck on one issue now:
The network connection does not seem to work.
I see usb0 and usb1 from ifconfig and the lights turn on when I hook
up a network cable however I cannot get a ping to the ip (or transfer
data).
> From: Robert Nelson robertcnelson@gmail.com > Subject: Re: [beagleboard] Re: How to boot beagleboard xM Rev C? > To: beagleboard@googlegroups.com > Date: Sunday, May 29, 2011, 7:32 PM > > On Sun, May 29, 2011 at 3:13 AM, Aharon <aharon.levine@gmail.com> wrote: > > Hi Robert > > > > Thanks so much for your Ubuntu Demo images, > > My xM Rec C is now up and running. I’m only stuck on one issue now: > > The network connection does not seem to work. > > I see usb0 and usb1 from ifconfig and the lights turn on when I hook > > up a network cable however I cannot get a ping to the ip (or transfer > > data). > > > > Have you experienced this? > > Did you actually get an ip from your dhcp server? a dump of “sudo > ifconfig -a” whould show that… > > Regards, > > – > Robert Nelson > http://www.rcn-ee.com/ > > – > You received this message because you are subscribed to the Google Groups “Beagle Board” group. > To post to this group, send email to beagleboard@googlegroups.com. > To unsubscribe from this group, send email to beagleboard+unsubscribe@googlegroups.com. > For more options, visit this group at http://groups.google.com/group/beagleboard?hl=en.
Hi Steve…
I’ m new to BB-xM Rev C…
could u pls sharre files…all the files…related to booting
I have few of them…but unable to decide abt UImage…different sizes available in the links…
pls do them…
Appreciate…for your timely help…
