Hi @RobertCNelson,
I have recently successfully boot my BBB from SD-Card. Where I build ML0, U-boot.img, extlinux.config file using buildroot.
But I use pre build rootfs from debian-rootfs.
By this methos, I reached till login window but after that I am getting issue.
U-Boot SPL 2018.09-00002-g0b54a51eee (Sep 10 2018 - 19:41:39 -0500)
Trying to boot from MMC2
Loading Environment from EXT4...
** Unable to use mmc 0:1 for loading the env **
U-Boot 2018.09-00002-g0b54a51eee (Sep 10 2018 - 19:41:39 -0500), Build: jenkins-github_Bootloader-Builder-65
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
152 bytes read in 2 ms (74.2 KiB/s)
1: beaglebone-buildroot
Retrieving file: /uImage
5248944 bytes read in 330 ms (15.2 MiB/s)
append: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
Retrieving file: /am335x-boneblack.dtb
70112 bytes read in 7 ms (9.6 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-6.8.0-rc7
Created: 2024-07-24 20:12:47 UTC
Data Size: 5248880 Bytes = 5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 88000000
Loading Kernel Image ... OK
Loading Device Tree to 8ffeb000, end 8ffff1df ... OK
Starting kernel ...
[ 0.000000] Linux version 6.8.0-rc7 (ninja@ninja) (arm-linux-gnueabihf-gcc (GCC) 14.0.0 20230605 (experimental) [master revi4
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 16 MiB at 0x9e800000 on node -1
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] percpu: Embedded 16 pages/cpu s35924 r8192 d21420 u65536
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] Memory: 483696K/522240K available (11264K kernel code, 1109K rwdata, 2580K rodata, 1024K init, 290K bss, 22160K )
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[ 0.000002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000027] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000498] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[ 0.001949] Console: colour dummy device 80x30
[ 0.002027] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.090544] CPU: Testing write buffer coherency: ok
[ 0.090640] CPU0: Spectre v2: using BPIALL workaround
[ 0.090652] pid_max: default: 32768 minimum: 301
[ 0.090777] LSM: initializing lsm=capability,integrity
[ 0.090949] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.090969] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.092461] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.094088] Setting up static identity map for 0x80100000 - 0x80100078
[ 0.094379] rcu: Hierarchical SRCU implementation.
[ 0.094389] rcu: Max phase no-delay instances is 1000.
[ 0.095134] smp: Bringing up secondary CPUs ...
[ 0.095178] smp: Brought up 1 node, 1 CPU
[ 0.095190] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[ 0.095202] CPU: All CPU(s) started in SVC mode.
[ 0.096076] devtmpfs: initialized
[ 0.110383] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.110929] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.110967] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.112276] pinctrl core: initialized pinctrl subsystem
[ 0.114783] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.117518] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.118094] audit: initializing netlink subsys (disabled)
[ 0.119623] thermal_sys: Registered thermal governor 'fair_share'
[ 0.119643] thermal_sys: Registered thermal governor 'step_wise'
[ 0.119649] thermal_sys: Registered thermal governor 'user_space'
[ 0.119771] audit: type=2000 audit(0.110:1): state=initialized audit_enabled=0 res=1
[ 0.119851] cpuidle: using governor menu
[ 0.139798] No ATAGs?
[ 0.139824] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.142739] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.163726] iommu: Default domain type: Translated
[ 0.163746] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.171715] SCSI subsystem initialized
[ 0.172486] pps_core: LinuxPPS API ver. 1 registered
[ 0.172497] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.172521] PTP clock support registered
[ 0.180838] vgaarb: loaded
[ 0.181155] clocksource: Switched to clocksource dmtimer
[ 0.181758] VFS: Disk quotas dquot_6.6.0
[ 0.181818] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.204867] NET: Registered PF_INET protocol family
[ 0.205209] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.206552] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.206589] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.206606] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.206649] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.206749] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.206874] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.206904] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.207076] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.212158] RPC: Registered named UNIX socket transport module.
[ 0.212179] RPC: Registered udp transport module.
[ 0.212184] RPC: Registered tcp transport module.
[ 0.212189] RPC: Registered tcp-with-tls transport module.
[ 0.212195] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.212220] PCI: CLS 0 bytes, default 64
[ 0.213763] Initialise system trusted keyrings
[ 0.221601] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.222839] NFS: Registering the id_resolver key type
[ 0.222908] Key type id_resolver registered
[ 0.222916] Key type id_legacy registered
[ 0.222971] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.223431] Key type asymmetric registered
[ 0.223448] Asymmetric key parser 'x509' registered
[ 0.223515] io scheduler mq-deadline registered
[ 0.223525] io scheduler kyber registered
[ 0.223595] io scheduler bfq registered
[ 0.237507] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[ 0.286359] brd: module loaded
[ 0.304718] loop: module loaded
[ 0.305624] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 0.308282] i2c_dev: i2c /dev entries driver
[ 0.309125] cpuidle: enable-method property 'ti,am3352' found operations
[ 0.309552] sdhci: Secure Digital Host Controller Interface driver
[ 0.309561] sdhci: Copyright(c) Pierre Ossman
[ 0.309741] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.310000] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.310726] Initializing XFRM netlink socket
[ 0.310875] NET: Registered PF_INET6 protocol family
[ 0.325991] Segment Routing with IPv6
[ 0.326071] In-situ OAM (IOAM) with IPv6
[ 0.326182] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 0.327125] NET: Registered PF_PACKET protocol family
[ 0.327154] NET: Registered PF_KEY protocol family
[ 0.327275] Key type dns_resolver registered
[ 0.327488] ThumbEE CPU extension supported.
[ 0.327510] Registering SWP/SWPB emulation handler
[ 0.327953] omap_voltage_late_init: Voltage driver support not added
[ 0.328294] SmartReflex Class3 initialized
[ 0.347101] Loading compiled-in X.509 certificates
[ 0.396073] platform 44e10800.pinmux: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-modules
[ 0.396611] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 0.401099] ti-sysc: probe of 44e31000.target-module failed with error -16
[ 0.449337] ti-sysc: probe of 48040000.target-module failed with error -16
[ 0.487089] OMAP GPIO hardware version 0.1
[ 0.537025] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.555502] platform 4830e000.lcdc: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@b0
[ 0.565647] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[ 0.566104] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 0.650726] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 0.767804] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 0.768263] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[ 0.768282] cpsw-switch 4a100000.switch: ALE Table size 1024
[ 0.779458] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
[ 0.779481] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[ 0.779584] cpsw-switch 4a100000.switch: Detected MACID = 0c:b2:b7:c9:0a:3e
[ 0.781377] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[ 0.791988] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[ 0.792029] edma 49000000.dma: TI EDMA DMA engine driver
[ 0.822231] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.829647] l3-aon-clkctrl:0000:0: failed to disable
[ 0.858481] printk: legacy console [ttyS0] disabled
[ 0.859287] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 34, base_baud = 3000000) is a 8250
[ 0.859367] printk: legacy console [ttyS0] enabled
[ 2.052048] tps65217-pmic: Failed to locate of_node [id: -1]
[ 2.058092] tps65217-bl: Failed to locate of_node [id: -1]
[ 2.068905] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 2.075006] platform 4830e000.lcdc: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@b0
[ 2.088393] i2c 0-0070: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0
[ 2.099767] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 2.107951] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 2.116854] sdhci-omap 48060000.mmc: Got CD GPIO
[ 2.121864] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
[ 2.131837] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 2.140424] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[ 2.149933] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 2.165529] clk: Disabling unused clocks
[ 2.188623] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[ 2.197057] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 2.205818] Waiting for root device /dev/mmcblk0p2...
[ 2.254371] mmc1: new high speed MMC card at address 0001
[ 2.261070] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 2.268612] mmcblk1: p1
[ 2.272542] mmcblk1boot0: mmc1:0001 M62704 2.00 MiB
[ 2.279663] mmcblk1boot1: mmc1:0001 M62704 2.00 MiB
[ 2.286784] mmcblk1rpmb: mmc1:0001 M62704 512 KiB, chardev (250:0)
[ 2.300065] mmc0: new high speed SDHC card at address e624
[ 2.306825] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[ 2.318089] mmcblk0: p1 p2
[ 3.185377] EXT4-fs (mmcblk0p2): recovery complete
[ 3.191485] EXT4-fs (mmcblk0p2): mounted filesystem 22914472-567d-4f3b-a9c8-ebd0687a3602 r/w with ordered data mode. Quota m.
[ 3.203836] VFS: Mounted root (ext4 filesystem) on device 179:26.
[ 3.214939] devtmpfs: mounted
[ 3.219539] Freeing unused kernel image (initmem) memory: 1024K
[ 3.226135] Run /sbin/init as init process
[ 3.575133] systemd[1]: System time before build time, advancing clock.
[ 3.597914] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[ 5.881177] random: crng init done
[ 5.952711] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIB)
[ 5.971845] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 9 (stretch)!
[ 6.015797] systemd[1]: Set hostname to <arm>.
[ 6.677926] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 6.711977] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 6.751502] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 6.791847] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 6.831907] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 6.872552] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 6.911974] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Encrypted Volumes.
[ OK ] Listening on Journal Socket.
[ OK ] Reached target Paths.
[ OK ] Listening on udev Kernel Socket.
[UNSUPP] Starting of Arbitrary Executable Fi…tem Automount Point not supported.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on Syslog Socket.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Created slice System Slice.
Starting Journal Service...
Mounting Debug File System...
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Remount Root and Kernel File Systems...
Starting Create Static Device Nodes in /dev...
[ OK ] Created slice system-getty.slice.
Mounting POSIX Message Queue File System...
Starting Load Kernel Modules...
[ OK ] Reached target Slices.
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Load Kernel Modules.
Mounting Configuration File System...
Starting Apply Kernel Variables...
Starting udev Kernel Device Manager...
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting udev Coldplug all Devices...
[ OK ] Mounted Configuration File System.
[ OK ] Started Journal Service.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Load/Save Random Seed.
Starting Raise network interfaces...
Starting Flush Journal to Persistent Storage...
[ OK ] Started udev Kernel Device Manager.
[ 8.752957] systemd-journald[81]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[FAILED] Failed to start Network Time Synchronization.
See 'systemctl status systemd-timesyncd.service' for details.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Raise network interfaces.
[ OK ] Found device /dev/ttyS0.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Telephony service...
[ OK ] Started Regular background program processing daemon.
Starting Generic Board Startup...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Telephony service.
Starting LSB: Start busybox udhcpd at boot time...
Starting Login Service...
Starting System Logging Service...
Starting Avahi mDNS/DNS-SD Stack...
Starting DUN service...
Starting Connection service...
Starting LSB: Load kernel modules needed to enable cpufreq scaling...
[ OK ] Started System Logging Service.
[FAILED] Failed to start Avahi mDNS/DNS-SD Stack.
See 'systemctl status avahi-daemon.service' for details.
[FAILED] Failed to start Connection service.
See 'systemctl status connman.service' for details.
[ OK ] Started DUN service.
[ OK ] Started LSB: Start busybox udhcpd at boot time.
[ OK ] Started Login Service.
[ OK ] Stopped Connection service.
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
Starting LSB: Advanced IEEE 802.11 management daemon...
Starting A high performance web server and a reverse proxy server...
Starting Permit User Sessions...
Starting OpenBSD Secure Shell server...
[ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[ OK ] Started LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
Starting LSB: set CPUFreq kernel parameters...
[ OK ] Started LSB: set CPUFreq kernel parameters.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started A high performance web server and a reverse proxy server.
Debian GNU/Linux 9 arm ttyS0
default username:password is [debian:temppwd]
arm login: debian
Password:
Last login: Sat Feb 16 20:39:16 UTC 2019 on ttyS0
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Unable to cd to '/home/debian'
[ OK ] Stopped Serial Getty on ttyS0.
[ OK ] Removed slice User Slice of debian.
arm login:
Q.1. Why I am not creating rootfs from buildroot and using the same ?
I did the same thing. I build rootfs using buildroot and place that into my ROOTFS partition.
I boot my BBB successfully. I achieve my target as well.
Q.2 Why I need debian rootfs ?
There is one problem with my rootfs build using buildroot that there is no package manager like apt or dkpg. If anything I want to download from internet. I am not able to do that.
So overall summary of my problem is that I want package manager in my BBB. So I can download as I do in ubuntu machine using sudo apt install <package>.
Please help me to find out the solution.
Thanks & Regards
Vivek Yadav
