Hear is the log of HyperTerminal:
Texas Instruments X-Loader 1.4.4ss (Mar 8 2011 - 08:54:45)
Beagle xM
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.03-rc1-00000-g9a3cc57-dirty (Apr 01 2011 - 17:41:42)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev A
No EEPROM on expansion board
Die ID #330a00011ff00000015739eb08014027
The user button is currently NOT pressed.
SD/MMC found on device 0
reading uEnv.txt
** Unable to read "uEnv.txt" from mmc 0:1 **
Loading file "/boot/uImage" from mmc device 0:2 (xxa2)
3203088 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3203024 Bytes = 3.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.............................................................
done, booti
ng the kernel.
[ 0.000000] Linux version 2.6.32 (koen@dominion) (gcc version 4.3.3
(GCC) ) #
3 PREEMPT Tue May 10 10:06:15 CEST 2011
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction ca
che
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630/DM3730 ES1.0 (l2cache iva sgx neon isp
192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x100000
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pag
es: 130048
[ 0.000000] Kernel command line: console=ttyS2,115200n8
mpurate=auto buddy=no
ne camera=lbcm3m1 vram=12M omapfb.mode=dvi:640x480MR-16@60
omapdss.def_disp=dvi
root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] Beagle expansionboard: none
[ 0.000000] Beagle cameraboard: lbcm3m1
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6,
262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072
bytes)
[ 0.000000] Memory: 256MB 256MB = 512MB total
[ 0.000000] Memory: 500352KB available (5900K code, 673K data, 204K
init, 0K
highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupt
s
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 489.46 BogoMIPS (lpj=1912832)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option 'mode'
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP3 Beagle Rev: xM A
[ 0.000000] Beagle cameraboard: registering i2c2 bus for lbcm3m1
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 0.000000] omap_init_mbox: platform not supported
[ 9.983764] OMAP DMA hardware revision 5.0
[ 9.990142] bio: create slab <bio-0> at 0
[ 9.991363] SCSI subsystem initialized
[ 9.992736] usbcore: registered new interface driver usbfs
[ 9.992889] usbcore: registered new interface driver hub
[ 9.993041] usbcore: registered new device driver usb
[ 9.993408] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
[ 9.996032] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 9.996063] twl4030: power (irq 373) chaining IRQs 376..383
[ 9.996337] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 9.998016] regulator: VUSB1V5: 1500 mV normal standby
[ 9.998229] regulator: VUSB1V8: 1800 mV normal standby
[ 9.998443] regulator: VUSB3V1: 3100 mV normal standby
[ 9.999725] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 10.000122] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 10.000366] regulator: VDAC: 1800 mV normal standby
[ 10.000579] regulator: VPLL2: 1800 mV normal standby
[ 10.000823] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 10.001129] regulator: VAUX3: 1800 mV normal standby
[ 10.001495] regulator: VAUX4: 1800 mV normal standby
[ 10.011444] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
[ 10.011749] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
[ 10.012908] Switching to clocksource 32k_counter
[ 10.022033] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 10.025634] musb_hdrc: USB OTG mode controller at fa0ab000 using
DMA, IRQ 92
[ 10.025665] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 10.025787] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number
1
[ 10.025909] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 10.025939] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=
1
[ 10.025939] usb usb1: Product: MUSB HDRC host driver
[ 10.025970] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 10.025970] usb usb1: SerialNumber: musb_hdrc
[ 10.026611] hub 1-0:1.0: USB hub found
[ 10.026641] hub 1-0:1.0: 1 port detected
[ 10.027648] NET: Registered protocol family 2
[ 10.027862] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 10.028411] TCP established hash table entries: 16384 (order: 5,
131072 bytes
[ 10.028869] TCP bind hash table entries: 16384 (order: 4, 65536
bytes)
[ 10.029083] TCP: Hash tables configured (established 16384 bind
16384)
[ 10.029113] TCP reno registered
[ 10.029113] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 10.029144] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 10.029388] NET: Registered protocol family 1
[ 10.029815] RPC: Registered udp transport module.
[ 10.029815] RPC: Registered tcp transport module.
[ 10.029846] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 10.030700] omap-iommu omap-iommu.0: isp registered
[ 10.032409] VFS: Disk quotas dquot_6.5.2
[ 10.032501] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 10.033538] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 10.034332] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red
Hat, Inc.
[ 10.035156] msgmni has been set to 977
[ 10.038940] alg: No test for stdrng (krng)
[ 10.039215] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 2
54)
[ 10.039215] io scheduler noop registered
[ 10.039245] io scheduler deadline registered
[ 10.039398] io scheduler cfq registered (default)
[ 10.099060] OMAP DSS rev 2.0
[ 10.099121] OMAP DISPC rev 3.0
[ 10.099182] OMAP VENC rev 2
[ 10.099426] OMAP DSI rev 1.0
[ 10.436035] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 10.453582] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 10.470489] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 10.487365] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 11.053649] console [ttyS2] enabled
[ 11.063903] brd: module loaded
[ 11.070281] loop: module loaded
[ 11.074798] omap2-nand driver initializing
[ 11.079223] No NAND device found!!!
[ 11.082885] No NAND device found!!!
[ 11.087432] usbcore: registered new interface driver catc
[ 11.092926] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 11.098968] usbcore: registered new interface driver kaweth
[ 11.104583] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet dr
iver
[ 11.112213] usbcore: registered new interface driver pegasus
[ 11.117950] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 11.124938] usbcore: registered new interface driver rtl8150
[ 11.130737] usbcore: registered new interface driver asix
[ 11.136230] usbcore: registered new interface driver cdc_ether
[ 11.142181] usbcore: registered new interface driver dm9601
[ 11.147918] usbcore: registered new interface driver smsc95xx
[ 11.153808] usbcore: registered new interface driver gl620a
[ 11.159454] usbcore: registered new interface driver net1080
[ 11.165252] usbcore: registered new interface driver plusb
[ 11.170867] usbcore: registered new interface driver rndis_host
[ 11.176910] usbcore: registered new interface driver cdc_subset
[ 11.182952] usbcore: registered new interface driver zaurus
[ 11.188659] usbcore: registered new interface driver MOSCHIP usb-
ethernet dri
ver
[ 11.196716] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 11.203552] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 11.209564] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus numbe
r 2
[ 11.217163] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 11.231781] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 11.237670] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[ 11.244537] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=
1
[ 11.251831] usb usb2: Product: OMAP-EHCI Host Controller
[ 11.257202] usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
[ 11.262634] usb usb2: SerialNumber: ehci-omap.0
[ 11.267852] hub 2-0:1.0: USB hub found
[ 11.271697] hub 2-0:1.0: 3 ports detected
[ 11.302215] Initializing USB Mass Storage driver...
[ 11.307312] usbcore: registered new interface driver usb-storage
[ 11.313385] USB Mass Storage support registered.
[ 11.318389] mice: PS/2 mouse device common for all mice
[ 11.324035] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 11.331848] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-1/1-
0049/twl4030_pwrbutton/input/input1
[ 11.342559] i2c /dev entries driver
[ 11.346618] Linux video capture interface: v2.00
[ 11.351593] omap-iommu omap-iommu.0: isp: version 1.1
[ 11.358276] vpfe_init
[ 11.361114] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 11.367889] cpuidle: using governor ladder
[ 11.372009] cpuidle: using governor menu
[ 11.482055] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card
detect
[ 11.489074] Registered led device: beagleboard::usr0
[ 11.494232] Registered led device: beagleboard::usr1
[ 11.500823] Registered led device: beagleboard::pmu_stat
[ 11.507904] usbcore: registered new interface driver usbhid
[ 11.513549] usbhid: USB HID core driver
[ 11.517578] Advanced Linux Sound Architecture Driver Version
1.0.21.
[ 11.524475] usbcore: registered new interface driver snd-usb-audio
[ 11.599304] usb 2-2: new high speed USB device using ehci-omap and
address 2
[ 11.610748] No device for DAI omap-mcbsp-dai-0
[ 11.615264] No device for DAI omap-mcbsp-dai-1
[ 11.619750] No device for DAI omap-mcbsp-dai-2
[ 11.624237] No device for DAI omap-mcbsp-dai-3
[ 11.628723] No device for DAI omap-mcbsp-dai-4
[ 11.633209] OMAP3 Beagle SoC init
[ 11.637359] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 11.648895] ALSA device list:
[ 11.651885] #0: omap3beagle (twl4030)
[ 11.655853] oprofile: using arm/armv7
[ 11.659759] TCP cubic registered
[ 11.663085] NET: Registered protocol family 17
[ 11.667572] NET: Registered protocol family 15
[ 11.672180] lib80211: common routines for IEEE802.11 drivers
[ 11.677917] ThumbEE CPU extension supported.
[ 11.682220] Power Management for TI OMAP3.
[ 11.687561] SmartReflex driver initialized
[ 11.691833] omap3beaglelmb: Driver registration complete
[ 11.705688] VFP support v0.3: implementor 41 architecture 3 part 30
variant c
rev 3
[ 11.713928] registered taskstats version 1
[ 11.718780] fbcvt: 640x480@60: CVT Name - .307M3-R
[ 11.732604] Console: switching to colour frame buffer device 80x30
[ 11.744567] regulator_init_complete: incomplete constraints,
leaving VAUX3 on
[ 11.754669] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 11.762420] omap_vout omap_vout: probed for an unknown device
[ 11.768585] Waiting for root device /dev/mmcblk0p2...
[ 11.779266] usb 2-2: New USB device found, idVendor=0424,
idProduct=9514
[ 11.786010] usb 2-2: New USB device strings: Mfr=0, Product=0,
SerialNumber=0
[ 11.793853] hub 2-2:1.0: USB hub found
[ 11.797851] hub 2-2:1.0: 5 ports detected
[ 11.895996] mmc0: host does not support reading read-only switch.
assuming wr
ite-enable.
[ 11.904205] mmc0: new high speed SDHC card at address 1234
[ 11.910156] mmcblk0: mmc0:1234 SA04G 3.67 GiB
[ 11.915008] mmcblk0: p1 p2
[ 11.996887] kjournald starting. Commit interval 5 seconds
[ 12.008239] EXT3-fs (mmcblk0p2): using internal journal
[ 12.013549] EXT3-fs (mmcblk0p2): mounted filesystem with writeback
data mode
[ 12.020690] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 12.031524] devtmpfs: mounted
[ 12.034576] Freeing init memory: 204K
[ 12.107208] usb 2-2.1: new high speed USB device using ehci-omap
and address
3
INIT: version 2.86 booting
[ 12.232482] usb 2-2.1: New USB device found, idVendor=0424,
idProduct=ec00
[ 12.239410] usb 2-2.1: New USB device strings: Mfr=0, Product=0,
SerialNumber
=0
[ 12.250030] smsc95xx v1.0.4
[ 12.307525] usb0: register 'smsc95xx' at usb-ehci-omap.0-2.1,
smsc95xx USB 2.
0 Ethernet, 12:05:cb:c2:73:3d
Please wait: booting...
Starting udev
Remounting root file system...
Caching udev devnodes
Populating dev cache
ALSA: Restoring mixer settings...
Configuring hicolor-icon-theme.
gtk-update-icon-cache: Failed to open file /usr/share/icons/
gnome/.icon-theme.ca
che : File exists
Configuring dbus.
System startup links for /etc/init.d/dbus-1 already exist.
Configuring pango-module-basic-x.
Configuring pango-module-basic-fc.
Configuring ttf-dejavu-common.
Configuring ttf-dejavu-sans.
Configuring gdk-pixbuf-loader-png.
Configuring gdk-pixbuf-loader-jpeg.
Configuring gdk-pixbuf-loader-gif.
Configuring gdk-pixbuf-loader-xpm.
Configuring policykit.
Configuring gnome-vfs.
