Thanks for your support.
I'm able to load the kernel module by enabling "module force
load/unload" options.
But it looks like I'm not able to run decode test applications.
I'm getting the following error:
"unable to open decode engine"
What could possibly be wrong here?
Thanks for your concern.
the error is in PROC_attach, attaching to the DSP fails.
unfortunately the logs only show the user space part,
the kernel module needs to be recompiled with traces to
see more.
I have also enabled the debug trace at the time of dsplink build.
yes, but not enough it seems, you also have to enable the traces by modifying
a certain file.
a certain file.
Do you have the lpm module loaded?
yes, lpm module is loaded.
I will build the module again with debug traces on.
I get these additional messages this time:
Assertion failed ((isrObj!= NULL) && (ISR_InstalledIsrs [isrObj->irq]
== isrObj)). File : isr.c Line : 437
Will upgrading to a newer dsplink and codec engine help me? If yes
then which version combination is known to work with 2.6.27 kernel and
from where can I download them.
I don't have an OE setup and currently I'm building the packages
directly. So it would be really helpful if someone can point me to the
correct resources as I do have a TI account to download the packages.
So we do not need to enable dspbridge or anything related to DSPBIOS
in Kernel itself.
Does Dsplink takes care of DSP BIOS. As far as I know DSPLINK is only
for API which help GPP to talk to DSP.
I am new bie on this tho..
