I used connmanctl to connect with my router, and now even if I am connected with beaglebone-XXXX wifi on any device(mobile , laptop) , I can use internet from my router.It is sweet and nice. I didn’t noticed for hours while working on laptop.
However, it is a potential security risk as anyone who might have knowledge about beaglebone can connect using default password. By now I have tried every search result on google and frustrated enough to overlook any of my stupid mistakes or obvious solutions.
Background:
I got my beaglebone black wireless around 2017, that time I tried very hard but couldn’t put WiFi to work , recently I again took interest in it and therefore from this page (Error using connmanctl> enable wifi BBBW), I found out kernel was damaged somehow in every image I downloaded , and I used this command dd if=/opt/scripts/device/bone/bbbw-eeprom.dump of=/sys/devices/platform/ocp/44e0b000.i2c/i2c-0/0-0050/eeprom and voila! Wifi and bt led which I never noticed on board illuminated.
Following is output for /opt/scripts/tools/version.sh
git:/opt/scripts/:[7cdc270818b76d829d247cf05fe309c320a3929a]
eeprom:[A335BNLTBWA50000BBWG*]
model:[TI_AM335x_BeagleBone_Black_Wireless]
dogtag:[BeagleBoard.org Debian Buster IoT Image 2020-04-06]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2019.04-00002-g07d5700e21]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-19-TI-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0]
UBOOT: Loaded Overlay:[BB-BBBW-WL1835-00A0]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0]
UBOOT: Loaded Overlay:[BB-HDMI-TDA998x-00A0]
kernel:[4.19.94-ti-r42]
nodejs:[v10.21.0]
/boot/uEnv.txt Settings:
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.14.20200722.0-0~buster+20200722]
pkg:[bb-wl18xx-firmware]:[1.20200702.0-0~buster+20200702]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.5-git20200715.0-0~buster+20200716]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal bluetooth netdev i2c gpio pwm eqep remoteproc admin spi iio docker tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 56.564542] remoteproc remoteproc0: wkup_m3 is available
[ 56.803677] remoteproc remoteproc0: powering up wkup_m3
[ 56.803711] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[ 56.803984] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 58.894162] remoteproc remoteproc1: 4a334000.pru is available
[ 58.911225] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[ 58.894350] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[ 58.915782] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
dmesg | grep pinctrl-single
[ 0.958066] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
[ 0.971160] gpio-of-helper ocp:cape-universal: ready
lsusb
END
I tried this solution without any success
Please check the below steps for changing the SSID and Password for the Beaglebone :
Step: 1 – > Get the latest updates
BeagleBone Black Rev C:
cd /opt/scripts/tools/
./update_kernel.shBeagleBone and BeagleBone Black Rev A/B:
- opkg update
- opkg upgrade
And then reboot
Step : 2 – > Configure WiFiBeagleBone Black Rev C:
Edit /etc/networking/interfaces
Uncomment the WiFi section and add SSID and password:
auto wlan0
iface wlan0 inet dhcp
wpa-ssid “mySSID”
wpa-psk “mypassword”BeagleBone and BeagleBone Black Rev A/B, confugure ConnMan:
Verify that you have “[WiFi] Enabled = true” in /var/lib/connman/settings
Add a new file /var/lib/connman/wifi.config with the following content:
[service_home]
Type =wifi
Name = yourSSID
Security = wpa2-psk
Passphrase = yourPassPhrase(replace “yourSSID” with the name of your network and replace “yourPassPhrase” with your passphrase. If you use wpa (and not wpa2), you must also change “wpa2-psk” to “wpa”.
Restart connman: systemctl restart connman
Also, please clarify how do I know which rev bbb I have(rev A,B or C) ? Does bbbw stands for Beaglebone Black wireless, because I stupidly confused it with beaglebone white?
