How to check the exact model of CPU ?
cpuinfo gets just this: AM33XX
root@am335x-evm:~# cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 2 (v7l)
BogoMIPS : 597.68
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc08
CPU revision : 2
Hardware : Generic AM33XX (Flattened Device Tree)
Revision : 0000
Serial : 2017BBBG0292
Thanks.
Regards.
TI's image usually (or did) ship "omapconf"..
debian@bbb-pwr01-ser09:~$ sudo omapconf --cpuinfo
OMAPCONF (rev 1.73-nogit built Thu Jan 4 21:17:37 UTC 2018)
HW Platform:
AM3359 ES2.0 GP Device (UNKNOWN performance ZCZ package (1.0GHz))
Error: I2C Read failed
TPS65217C ES1.2
UNKNOWN AUDIO IC
"AM3359 ES2.0 GP ZCZ"...
It doesn’t work on my board:
debian@beaglebone:~$ sudo omapconf --cpuinfo
[sudo] password for debian:
sudo: omapconf: command not found
Sincerely,
Pavel.
It's not installed by default in the BeagleBoard.org image's, as it
doesn't provide very much useful information for the average user.
I had merely reference TI's sdk as that is what you posted in this thread.
Works. Thanks !
root@am335x-evm:~# sudo omapconf --cpuinfo
OMAPCONF (rev v1.74-1-g40ab0a2 built Sun Apr 19 07:10:00 UTC 2020)
HW Platform:
AM3358 ES2.1 GP Device (UNKNOWN performance ZCZ package (1.0GHz))
TPS65217B ES1.2
UNKNOWN AUDIO IC
root@am335x-evm:~#
Before I tried on eMMC images. I’ve two Linux images:
- downloaded from BeagleBone site (in eMMC)
- flashed on SD card using TI SDK utility (on SD card)
Where can I find omapconf to install it on eMMC ?
Sincerely,
Pavel.
sudo apt install tiomapconf
Dude I’m getting dizzy following this thread.
You must run this command on the sdk version of Linux
You said it works above on sdk now it appears you are running the command on Debian. It won’t work until you follow Robert’s update command.
As I previously mentioned, I’ve two version of Linux:
- debian in eMMC
- yocto-based in SD card
On yocto omapconf worked, on debian - not.
I installed it on debian using Robert’s suggestion and now it also works on debian.
What confuses you ?
Sincerely,
Pavel.
