I understand opencv is installed on the stock debian 8.4 distro included with the beaglebone black
i.e. pkg-config --modversion opencv returns 2.4.9.1
However, when I try to compile a simple hello-world test file:
g++ -O2 ‘pkg-config --cflags --libs opencv’ test.cpp -o test
I get an error that there is no such file or directory for opencv,
g++: error: pkg-config --cflags --libs opencv: No such file or directory
I’m running as root, but is there someother setup (path, folder permissions) that need to be done first?
I’m following the tutorial/code directly from here:
http://derekmolloy.ie/beaglebone/beaglebone-video-capture-and-image-processing-on-embedded-linux-using-opencv/
