I have problems to understand how to configure uEnv.txt to get BBB to boot from eMMC.
Setup:
- u-boot
u-boot is created as described here:
https://eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-Bootloader:U-Boot
i.e.
git clone https:``//github.com/u-boot/u-boot
cd u-boot/
git checkout v2017.``03``-rc2 -b tmp
with one exception: I have included only the patch 0001
patch -p1 < ``0001``-am335x_evm-uEnv.txt-bootz-n-fixes.patch
MLO and u-boot.img are first copied to SD card.
Then BBB is booted from SD card and above files copied to eMMC :
dd ``if``=./MLO of=/dev/mmcblk1p1 count=``1 seek=``1 bs=128k
dd ``if``=./u-boot.img of=/dev/mmcblk1p1 count=``2 seek=``1 bs=384k
- Rootfs
The rootfs is build with Buildroot with kernel version 4.4.52 and custom am335x-boneblack.dtb and am335x-bonegreen.dtb whitch enables two serial ports (O1 & O2). ( I’m having both BBB and BBG HWs).
Rootfs is copied to first to SD card and then extracted to eMMC when BBB is booted from SD card.
- uEnv.txt
uEnv.txt content is the following as indicated in the eewiki’s BBB page.
uname_r=4.4.52
- zImage
zImage is stored to /boot folder with name vmlinuz-4.4.52 as indicated in the eewiki’s BBB page.
- The problem / Questions
Booting starts well but stops at the following point
mm1: new high speed MMC card at address 0001
mmcblkk0: mmc1:0001 MMC04G 3.66 GiB
mmcblk0boot0: mmc:0001 MMC04G partition 1 1.00 MiB
mmcblk0boot1: mmc:0001 MMC04G partition 2 1.00 Mib
mmcblk0: p1
Waiting for root device /dev/mmcblk1p1…
=> so suddenly eMMC has changed it’s identity to mmcblk0 and apparently /dev/mmcblk1p1 doesn’t exist any more preventing booting from eMMC.
Q: why this identity change happens?
Q: what need to added into uEnv.txt to get booting from eMMC working?
- Dirty hack / good luck
I’have managed to get BBB to boot from eMMC when having the following configuration
Files:
- zImage
- uEnv.txt
- am335x-boneblack.dtb and am335x-bonegreen.dtb
are saved into root of eMMC.
The uEnv.txt has the following lines which I copied from the Buildroot Training Lab Book (buildroot-labs.pdf) by Free-Electrons.com.
bootdir=
bootpart=0:1
uenvcmd=run loadimage;run loadramdisk;run findfdt;run loadfdt;run mmcloados
So, I’ve managed to get eMMC booting with a good luck without really knowing what I’m doing.
Now I’d like to understand what is the correct way to configure BBB to boot from eMMC (+ preferable so that uEnv.txt & vmlinuz-4.4.52 are stored to /boot folder).
BR
Timo Välimäki
