Hi, I am new to BB. I have a BeagleBone Black Wireless. Could you please let me know how to connect it to home wifi network? I can run the board via usb cable or independently connect it to an external monitor. I once connected to a monitor but could not find any option to allow me to connect it to the wireless internet at home. Thanks
Here’s[1] some notes I have on connecting. Do they help?
–Mark
Thank you. Can I do this without connecting the BBB wifi to a PC and share the internet connection?
2019年9月3日火曜日 10時34分57秒 UTC-4 Mark A. Yoder:
I was able to get this part working thanks to Derek Malloys videos.
In windows Network and sharing your wifi adapter will appear as well as the local private adapter to the BBB
In the wifi adapter go to properties–> sharing and allow sharing to the private adapter.
Once that is done, go to the private adapter → properties. Click Internet protocol Version 4 (TCP/IPV4) then in the window that pops up select both Obtain IP and Obtain DNS automatically.
Brian
Following the BeagleBone: Getting Started - Windows USB Network Adapter Setup tutorial, I am able to repair the connection between my laptop and the BBB wifi. Now I can use putty. There are two issues:
I cannot login as root. I tried to just hit enter. Did not work. I tried temppwd which is the password for Debian. Also does not work. I tried to “edit sshd_config in /etc/sshd and change the “no” to a “yes” after PermitRootLogin.” but it is “yes” by default already. Anybody knows what I can do to login as root?
From the video, typing “ping 192.168.7.1” should get a list of bytes transfer and time to show that a private network has been established. However, my system only shows:
debian@beaglebone:/etc/ssh$ ping 192.168.7.1
PING 192.168.7.1 (192.168.7.1) 56(84) bytes of data.
and it hangs until I hit control C. Have I done anything wrong? I can connect the BBB wifi to my PC via putty and the website’s 192.168.7.2. However, ping does not work…
Could anybody please show me how to fix the issues? Thanks
2019年9月2日月曜日 20時11分18秒 UTC-4 user pc:
login as debian temppwd then sudo root check windows firewall
I am able to ping 192.168.7.2. I am also able to set up a new password for root and then sudo root. Now, problem with connection to google.com.
root@beaglebone:/home/Debian# ping www.google.com
ping: www.google.com: Temporary failure in name resolution
[In the video, it shows a different system respond: “ping: unknown host www.google.com”. Do I have to worry?]
I typed “/sbin/route add default gw 192.168.7.1” and then “ping 8.8.8.8”, I got only:
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
and the system hung rather than printing a list of 64 bytes from 8.8.8: … time=41.4 ms" until I type control C. Could you please let me know how to fix this?
Hi!
Personally I’d suggest there’s no need to waste time on this activity to add routes in windows. Just disconnect your BBB and connect it directly via Ethernet to your switch/router (and of course power via a 5V DC supply with barrel plug).
Although it’s technically possible to run your BBB like a dongle hanging off the end of the PC’s USB socket, it’s a waste of time investigating your PC operating system and any firewall settings, when you could instead be using your BBB.
I considered this before but there is no icon to configure the network setting under Debian. Somebody mentioned that I need to go through this to set up an internet connection for the BBB via usb connection to a PC. After setting up the wifi connection successfully for BBB wireless, I can then use it as a standalone controller that can connect to the internet via a PC. Eventually, I will need the BBB wireless to be able to connect to public wifi network.
Besides, I don’t have access to an external HDMI monitor outside home. I need to use the screen of my laptop as the screen for the BBB wifi when I am away from home.
2019年9月5日木曜日 23時27分23秒 UTC-4 shabaz:
I see; so you’ve got a BeagleBone Wireless or similar, and the actual aim is to get the wireless working.
In that case, you can do all this from the command line, and no need to add routes.
I wrote up some beginner steps here: https://www.element14.com/community/community/designcenter/single-board-computers/blog/2019/08/11/getting-started-with-beaglebone-black
There’s a section ‘Connecting to a Wireless Network’, it won’t entail you needing to use HDMI.
However I didn’t understand this bit:
“. I need to use the screen of my laptop as the screen for the BBB wifi when I am away from home”.
Ordinarily, applications that require remote operation or access, can be used with a web browser, or some other method, (say) configuration via command line, using SSH. If you’re referring to a ‘remote desktop’, while that’s possible, it is antiquated. Also, it’s not good to open up ports on your home firewall. Better to find alternative ways so that there’s no need for unusual solution topologies.
Thanks. I followed the steps described in your guide. So, wifi should be working. How come when I ping 8.8.8.8, the system still just prints: “PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.” and system hangs until I het ctrl-c.
When I typed: ping www.google.com, I got
PING www.google.com (172.217.164.196) 56 (84) bytes of data.
From your output, it seems there is (or was) some connectivity over WLAN or another medium, because your BBB appears to understand the IP address of google.com is 172.217.164.196.
You could consider trying a new test ping to a different host, to establish if that really is the case or not. Sometimes it’s best to try a more unusual host.
Also, the steps mention some confirmatory steps, but you’ve not pasted any output.
Personally, I don’t like diagnosing issues in a ping-pong fashion, because it’s a waste of time : (
I tried:
root@beaglebone:/home/Debian# ping www.apple.com
PING e6858.dsce9.akamaiedge.net (96.6.23.173) 56(84) bytes of data.
Then it hangs.
I quit Putty and then I re-enable the two Inbound Rules: File and Printer Sharing (Echo Request -ICMPv4-In).
Restart Putty and tried to ping www.apple.com again. Got the same reaction from the system.
It seems as if the wireless is up, if you’re able to resolve hostnames like this.
However, it would be good to confirm it.
You can check by typing
ifconfig -a
(as mentioned in the steps) and pasting the output, and also try pinging your home router IP address.
If the above is successful then traceroute could be tried too, to narrow down the issue.
Just to confirm, do you have a home router, or is this test being done in work premises (i.e. connecting to a corporate network)?
Hi, from now on, should I turn of or enable the two Inbound Rules "File and Printing Sharing (Echo Request - ICMPv4-In)? Currently, they are off as it is stated that it is not good to open firewall of home network.
I tried:
wlan0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 192.168.2.244 netmask 255.255.255.0 broadcast 192.168.2.255
inet6 fe80::f684:4cff:fe44:49d2 prefixlen 64 scopeid 0x20
ether f4:84:4c:44:49:d2 txqueuelen 1000 (Ethernet)
RX packets 14504 bytes 2681650 (2.5 MiB)
RX errors 0 dropped 2 overruns 0 frame 0
TX packets 782 bytes 89674 (87.5 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Pinging my own home wifi router’s IP address is working. A list of 64 bytes from … is shown.
I should add that I need to get this working both at home (wifi) and at workplace (wifi also).
You shouldn’t need to touch your home router config to be able to connect from your BBB to external hosts (but check you can ping the same hosts using your PC too). Nearly all ISP provided routers will be set up correctly. Opening up ports from the internet is not recommended.
Your wireless connection is good since you can ping your home router. Not sure why the router isn’t forwarding packets. A traceroute may help, but beyond that I don’t know what the issue is.
Regarding work network, that’s a different kettle of fish. Your work network may have security at layer 2. In other words, you’d need to confirm with your IT team if they will allow an unsupported device on the network. Packets from unauthorized devices may be silently dropped depending on how secure your work network is.
On Thu, 5 Sep 2019 20:38:13 -0700 (PDT), user pc
<petercohen8877@gmail.com> declaimed the
following:
On the Beagles, I believe (I don't have WiFi capable Beagles and always
use a CAT-5 wired connection to my router [technically, to an 8-port switch
which connects to the router]) you need to run connmanctl to configure
connections (the CAT-5 wired doesn't seem to need it, it is automatic).
Documentation at
https://manpages.debian.org/testing/connman/connmanctl.1.en.html
(Hmmm, it appears to be a Debian package, here I'd thought it was Beagle
specific)
https://manpages.debian.org/testing/connman/connman-service.config.5.en.html
After
The main concept is that you need to eventually be able to run the
Beagle /without/ using the USB connection. Forget about trying to use
Beagle (USB) -> computer -> internet
and I'd also forget about
Beagle (WiFi) -> computer -> (wired) internet
(Beagle (WiFi) -> computer -> (WiFi) internet is only possible if the
computer has two WiFi units, one set as an access point for the Beagle to
connect, and one set as a client to connect to an access point).
All of those have the hassles of configuring the computer to do
gateway, possibly DHCP, possibly nameserver for local stuff...
Use the USB connection (and SSH) only to edit the initial configuration
of the Beagle so that the WiFi module has information to connect to your
WiFi router. When the information has been provided, disconnect the USB
(obviously you'll need a 5V power supply) and reboot. It should then
connect to the WiFi router, and you'll access it using either a router
handled name (on Windows, that is often just the hostname without any
trailing domain) or via the IP # assigned by the router (you'll have to
check the router configuration pages to find the IP # assigned to WiFi
client).
This is also predicated on the router being in a permissive mode -- my
preference is to lock out unknown devices, only allowing a limited number
of MAC addresses to connect. This does mean everytime I get a new WiFi
device, I have to either discover the MAC address before connecting, or
enable "all devices" on the router, connect, check the MAC address for the
new device, then add it to the "allowed" list before relocking to "allowed
only".
On Thu, 5 Sep 2019 21:33:28 -0700 (PDT), user pc
following:
working. How come when I ping 8.8.8.8, the system still just prints: "PING
8.8.8.8 (8.8.8.8) 56(84) bytes of data." and system hangs until I het
ctrl-c.When I typed: ping www.google.com, I got
Which shows us that IPv4 name lookup is working... (For the following,
remember that I have CAT-5 to LAN switch)
debian@beaglebone:~$ ping 8.8.8.8
64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=22.7 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=22.2 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=54 time=22.7 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=54 time=23.1 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=54 time=22.9 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=54 time=22.4 ms
^C
--- 8.8.8.8 ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5009ms
rtt min/avg/max/mdev = 22.242/22.716/23.145/0.330 ms
debian@beaglebone:~$ ping www.google.com
PING www.google.com(dfw25s34-in-x04.1e100.net (2607:f8b0:4000:808::2004))
56 data bytes
64 bytes from dfw25s34-in-x04.1e100.net (2607:f8b0:4000:808::2004):
icmp_seq=1 ttl=53 time=47.1 ms
icmp_seq=2 ttl=53 time=47.2 ms
icmp_seq=3 ttl=53 time=46.5 ms
icmp_seq=4 ttl=53 time=47.2 ms
icmp_seq=5 ttl=53 time=46.8 ms
^C
--- www.google.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4007ms
rtt min/avg/max/mdev = 46.541/47.017/47.251/0.362 ms
debian@beaglebone:~$ ping -4 www.google.com
PING www.google.com (172.217.14.164) 56(84) bytes of data.
64 bytes from dfw28s22-in-f4.1e100.net (172.217.14.164): icmp_seq=1 ttl=53
time=46.6 ms
64 bytes from dfw28s22-in-f4.1e100.net (172.217.14.164): icmp_seq=2 ttl=53
time=45.7 ms
64 bytes from dfw28s22-in-f4.1e100.net (172.217.14.164): icmp_seq=3 ttl=53
time=46.1 ms
64 bytes from dfw28s22-in-f4.1e100.net (172.217.14.164): icmp_seq=4 ttl=53
time=45.9 ms
^C
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 45.724/46.132/46.676/0.440 ms
Note that my first ping to google used IPv6 numbers, I had to specify
IPv4 usage on the second.
If your pings are hanging after the initial status line (how long did
you wait) the most likely cause is... Firewall settings that are not
propagating the packet type used by ping. Have you tried traceroute
to find out how far the packets are making it? (you may need to install it
first sudo apt-get install traceroute )
debian@beaglebone:~$ traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
1 dsldevice.attlocal.net (192.168.1.254) 1.085 ms 1.123 ms 1.172 ms
2 76-255-152-1.lightspeed.gdrpmi.sbcglobal.net (76.255.152.1) 20.966 ms
30.590 ms 31.764 ms
3 71.152.176.29 (71.152.176.29) 22.195 ms 22.542 ms 22.660 ms
4 cr2.cgcil.ip.att.net (12.123.7.142) 29.049 ms 33.278 ms 33.308 ms
5 gar26.cgcil.ip.att.net (12.122.99.93) 29.804 ms 29.832 ms 30.594 ms
6 12.247.108.6 (12.247.108.6) 30.921 ms 12.247.108.10 (12.247.108.10)
23.448 ms 12.247.108.6 (12.247.108.6) 24.759 ms
7 * * *
8 dns.google (8.8.8.8) 22.939 ms 23.203 ms 24.298 ms
debian@beaglebone:~$ traceroute www.google.com
traceroute to www.google.com (172.217.1.228), 30 hops max, 60 byte packets
1 dsldevice.attlocal.net (192.168.1.254) 0.596 ms 0.668 ms 0.727 ms
2 76-255-152-1.lightspeed.gdrpmi.sbcglobal.net (76.255.152.1) 21.995 ms
31.390 ms 40.496 ms
3 71.152.176.29 (71.152.176.29) 21.439 ms 22.286 ms 22.320 ms
4 cr2.cgcil.ip.att.net (12.123.7.142) 29.271 ms 29.239 ms 29.542 ms
5 gar26.cgcil.ip.att.net (12.122.99.93) 28.887 ms 30.081 ms 29.934 ms
6 12.247.108.6 (12.247.108.6) 30.727 ms 12.247.108.10 (12.247.108.10)
25.764 ms 12.247.108.6 (12.247.108.6) 25.712 ms
7 * * *
8 216.239.42.34 (216.239.42.34) 22.567 ms 72.14.232.192 (72.14.232.192)
23.432 ms 72.14.232.168 (72.14.232.168) 23.821 ms
9 108.170.243.233 (108.170.243.233) 25.462 ms 108.170.243.219
(108.170.243.219) 40.857 ms 108.170.243.165 (108.170.243.165) 27.141 ms
10 72.14.233.10 (72.14.233.10) 28.569 ms 28.716 ms 216.239.57.77
(216.239.57.77) 30.460 ms
11 209.85.249.19 (209.85.249.19) 54.080 ms 209.85.246.211
(209.85.246.211) 53.393 ms 209.85.249.19 (209.85.249.19) 54.546 ms
12 209.85.250.54 (209.85.250.54) 54.335 ms 209.85.250.141
(209.85.250.141) 46.519 ms 209.85.250.54 (209.85.250.54) 46.535 ms
13 108.170.228.87 (108.170.228.87) 47.445 ms 216.239.59.169
(216.239.59.169) 47.090 ms 43.919 ms
14 108.170.240.129 (108.170.240.129) 48.624 ms 49.600 ms 49.973 ms
15 216.239.40.67 (216.239.40.67) 50.339 ms 51.655 ms 52.175 ms
16 dfw25s25-in-f4.1e100.net (172.217.1.228) 51.972 ms 53.119 ms 53.539
ms
If traceroute starts putting out * * * for all lines up to the max-hops
the odds are good that the packets are being lost at that point.
With the CAT-5 disconnected (so using the USB, without sharing on the
main computer)...
connect: Network is unreachable
Without sharing, the USB connection is only usable between the BBB and
computer -- there is no nameserver or gating...
debian@beaglebone:~$ ping 192.168.7.2
PING 192.168.7.2 (192.168.7.2) 56(84) bytes of data.
64 bytes from 192.168.7.2: icmp_seq=1 ttl=64 time=0.202 ms
64 bytes from 192.168.7.2: icmp_seq=2 ttl=64 time=0.234 ms
64 bytes from 192.168.7.2: icmp_seq=3 ttl=64 time=0.236 ms
64 bytes from 192.168.7.2: icmp_seq=4 ttl=64 time=0.229 ms
64 bytes from 192.168.7.2: icmp_seq=5 ttl=64 time=0.230 ms
^C
--- 192.168.7.2 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4041ms
rtt min/avg/max/mdev = 0.202/0.226/0.236/0.015 ms
debian@beaglebone:~$ ping 192.168.7.1
64 bytes from 192.168.7.1: icmp_seq=1 ttl=128 time=0.627 ms
64 bytes from 192.168.7.1: icmp_seq=2 ttl=128 time=0.651 ms
64 bytes from 192.168.7.1: icmp_seq=3 ttl=128 time=0.645 ms
64 bytes from 192.168.7.1: icmp_seq=4 ttl=128 time=0.706 ms
64 bytes from 192.168.7.1: icmp_seq=5 ttl=128 time=0.574 ms
^C
--- 192.168.7.1 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 0.574/0.640/0.706/0.050 ms
Based upon the times, 192.168.7.1 is my computer, and 192.168.7.2 is
the BBB itself.
debian@beaglebone:~$ traceroute 192.168.7.2
traceroute to 192.168.7.2 (192.168.7.2), 30 hops max, 60 byte packets
1 192.168.7.2 (192.168.7.2) 0.201 ms 0.077 ms 0.064 ms
debian@beaglebone:~$ traceroute 192.168.7.1
traceroute to 192.168.7.1 (192.168.7.1), 30 hops max, 60 byte packets
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Note how traceroute failed to get times for anything -- my computer is
not running a traceroute daemon to respond.
On Fri, 6 Sep 2019 05:27:22 -0700 (PDT), user pc
following:
I tried: ifconfig -a and the output is a long list of things. As my laptop
is connected to home wifi router, I am listing the output for the wifi
adapter.
Don't trim -- show us all of it, otherwise we can't really tell what
you have going.
