How to customize the BBAI64 eMMC minimal image?
First of all, I want to thank the forums for the great information they provide.
I installed ROS2 humble on top of the BBAI64 microSD image and set it up with a bunch of python modules.
I mounted the microSD to my laptop and extracted the image to .img so I can use it on other BBAI64s.
The goal is to integrate ROS2, my code, and a few python modules in a minimal snapshot of eMMC.
I want to modify it so that when I flash my customized image with emmc-flahser, my ROS2, code, and python modules are ready to go.
Hi @ALEX_PARK , make sure bb-beagle-flasher is up to date:
sudo apt update
sudo apt install --only-upgrade bb-beagle-flasher
Then set the ‘flash’ direction:
Copy eMMC → new microSD:
sudo cp -v /etc/beagle-flasher/bbai64-emmc-to-microsd /etc/default/beagle-flasher
Then insert new microSD and run:
sudo beagle-flasher
After flashing has finished…
Take out microSD and test it on another bbai64, if it run exactly how you want, next set the “eMMC flasher” enablement:
sudo cp -v /etc/beagle-flasher/bbai64-microsd-to-emmc /etc/default/beagle-flasher
sudo enable-beagle-flasher
Now on every bootup with that specific microSD, it’ll flash the eMMC…
Oh?
I get it, I thought eMMC images and SD images were separate.
Thanks. I have gained one knowledge.
for the BBAI64, the location of tiboot3.bin varies between eMMC/microSD…
