[mailto:beagleboard@googlegroups.com] On Behalf Of Don Smales
Sent: Friday, October 16, 2009 10:06 AM
To: Beagle Board
Subject: [beagleboard] Re: How to develop software for beagle board?
Thanks for the help. I ordered the board a few minutes ago, and will
probably
take a look at Eclipse, because I like the GUI. Mostly, I am a
hardware guy,
but I do write some embedded software from time to time.
The job market has been so bad, I decided to devote some time to
learning
Linux and DSP coding with C. This looks like the cheapest and easiest
way
to accomplish both.
The TI OMAP development kit is like $1500. A little beyond what I
wanted
to spend right now. I think you eventually have to buy their CCStudio
software
when the trial licence runs out. I am not sure, but I think that's
another $2000.
Again, more money than I wanted to invest in this.
I'm not sure I understand why you need CCSV4. The only reason I use CCSV4 is
to do low level debugging with a JTAG debugger. Other than that, I never use
CCSV4. In any case, CCSV4 doesn't run on Linux yet and probably won't for
several months. At the moment, you have to run CCSV4 on Windows and NFS
mount the Linux build environment, or use SAMBA.
I personally use SlickEdit or KScope to write, build and navigate code as
they both have great code indexers. KScope needs on Ubuntu 9.04, but with
some hacking, it still works great. For example, SlickEdit and KScope will
index the complete Linux Kernel in about 2 to 3 minutes. Eclipse will take
more than 1/2 hour to do the same and then it still misses some indexing
unless you manually specify all the folders in detail. Once this is done,
Eclipse seems to work fine.
> > From: beagleboard@googlegroups.com
> > Sent: Friday, October 16, 2009 8:24 AM
> > To: Beagle Board
> > Subject: [beagleboard] How to develop software for beagle board?
> > I see you can buy a beagle board for $149, but what additional
> > software do you need to develop C code for it? Am I correct in
> > assuming you can use TI CCStudio Platinum V 4.0 for this?
> > Am I going to have to purchase TI CCStudio Platinum eventually, or is
> > there a way I can keep using the free evaluation tools indefinitely?
> You can use cross development tools from Angstrom or CodeSourcery. If
you
> want a GUI, download the Eclipse CDT, but reference the ARM cross
> development tools, or build everything with a makefile.www.angstrom-
distribution.orghttp://www.codesourcery.com/sgpp/lite/arm/portal/release830w
ww.e
