I’m running BBGW-blank-debian-8.5-seeed-iot-armhf-2016-06-19-4gb.img on a BBGW. I’ve used connmanctl to configure the wifi network to which I want to connect, and everything is working OK so far. On bootup, my BBGW does DHCP an address and I can ssh into it.
What I’d like to do now is disable the SoftAp0 interface with the 192.168.8.1 address. What is the correct/clean way to do this?
If I run “sudo systemctl disable wificonfig.service”, then wifi doesn’t come up at all the next time I reboot.
SoftAp0 is created by the wifidog service:
wifidog-pre-startup.service
wifidog-gateway.service
https://github.com/rcn-ee/repos/blob/master/seeed-wificonfig-installer/suite/jessie/debian/wifidog_pre
Thanks, Robert.
For anyone else running into this, here is the simplest solution I found to ensure wlan0 still comes up, SoftAp0 doesn’t, and the nodejs process isn’t started at bootup:
https://www.ccoderun.ca/programming/2016-06-29_BBGW/index.html#softap0
- edit /usr/bin/wifidog_pre
- at the top of the script, add this line: touch /tmp/wifi.up
- at the bottom of the script, comment out systemctl start of wificonfig.service
- at the bottom of the script, append these 2 additional lines:
systemctl stop wificonfig.service || true
systemctl disable wificonfig.service || true
- save the file and reboot the device
And if like me you don’t have a cell phone or other bluetooth device to configure the wlan0 interface, I have that figured out and documented here: Programming Comments - How to setup a BeagleBone Green Wireless
Stéphane
And if like me you don’t have a cell phone or other bluetooth device to configure the wlan0 interface, I have that figured out and documented here: https://www.ccoderun.ca/programming/2016-06-29_BBGW/index.html#wifi
I meant to say wifi, not bluetooth.
Stéphane
