I put the latest console image of debian on beagle bone, and notice that when I do a ps aux I see
/usr/sbin/udhcpd -S
/usr/sbin/udhcpd -S /etc/udhcpd.conf
I believe this is for a dhcp server, which I don’t need (I only use dhcp as a client on the beagle bone)
I attempted to disable it with:
update-rc.d udhcpd remove
and then rebooted, but they still show up.
Is there a way to disable these if they are dhcpd servers?
It's started here:
/opt/scripts/boot/am335x_evm.sh
It's used to easily setup the usb-otg ethernet connection so you can
ssh in over usb.
Thank you very much. If I am reading the script correctly, I can disable this by deleting /etc/udhcpd.conf.
I did that and rebooted, and I don’t see the processes.
For whatever radon, it was causing problems with my routers dhcp server. Other devices on the subnet (192.168.1.0) would get a correct ip, and then it would be replaced with an ip on the 192.168.0.0 subnet. I didn’t see that with the May image.
It appears to be working now, so again, thank you for your help.
