Recently I’m trying to bring up my BBB board, and I want to develop linux drivers on it, so I need to compile kernel by myself.
Before I use my customized linux, I tried the BeagleBoard.org - getting-started imgs to boot my BBB.
When the BBB boot done, I can find a COM port on my win10.( I just use the miniUSB port connected to my laptop). Then, I can use mobaXterm or putty to login it.
However, when I use my own linux img to boot my BBB, I can not find such COM port. I doubt I need do some specical configurations to compile the kernel again. But I don’t know how to do it.
So you mean this feature is not only configurations in kernel ? I need install above packages to enable it?
Or above package is default enabled in the imgs from BeagleBoard.org - getting-started ?
Hi @Allen_Walker it’s a user-space side configuration. While it requires the Kernel to have specific config’s enabled, the “USB Configuration” is purely in user-space thru configfs.
