Hi All,
We are working on beagle board XM with linux kernel 2.6.36-2.We are
using rt2870 wireless USB dongle to connect to the board.The board is
unable to detect the USB device, we have enabled usb support while
doing make menu config operation on kernel 2.6.36 but this didnt make
any difference.Any one could please respond here.
Raghavendra
Hi Robert
Thank you for the help after patching the kernel, hub has detected
wireless and webcam.
We have used the patches from the following site
http://www.labbookpages.co.uk/electronics/beagleBoard/custom.html
But we got two problems here
1. when i do iwconfig i m getting command not found.
2. when I do ifconfig wlan0 up
I m getting following error
phy0 -> rt2x00lib_request_firmware: Error -Failed to request Firmware.
I m using the ralink wireless USB, chipset is 3070
Can you please suggest any idea here
Thanks in Advance
Aditya B
Aditya B
Hi Robert
iwconfig is usually packaged in a package called "wireless-tools"
do you have the ralink firmware package installed?
Hi Robert,
Thanks for the response. We have enabled all options in the ralink
driver support.
(menuconfig -> device drivers -> Network device support -> wireless
lan )
Till we are observing the same error.
Re typing the error logs.
phy0 -> rt2x00lib_request_firmware:Info -Loading firmware file
'rt2870.bin'
ifconfig: SIOCSIFFLAGS: No such file or directory =4
We have cross compiled the wireless drivers manually, It has generated
rt3370.ko file. We copied rt3370.ko and RT2870STA.dat files into micro
sd card.
inserted the module using insmod command.
after inserting we got following logs
rtusb init ->
usbcore: registered new interface driver rt2870.
We tried again to up the wlan0 interface with no luck.
Please tell us did we miss any thing.
Raghav
Hi Robert,
driver support.
lan )
'rt2870.bin'
sd card.
rtusb init ->
Raghav
