How to flash buildroot image in the sd card to emmc
Hello all.
Just as proof of concept I am building a beagleboneblack image from buildroot (version 2023.02.9). I did make beaglebone_defconfig and that generated a sdcard.img in output/images, which I use to flash my sd card, which in mounted as:
/dev/sda1 16M 7.5M 8.5M 47% /media/myuser/3B55-2A0F
/dev/sda2 52M 22M 26M 47% /media/myuser/rootfs
I can boot my beagleboneblack with that card, but now I wonder, is there a way to boot from my internal beagleboneblack with that generated image? Maybe flashing it from my host computer with generated image, or maybe some operation with the sd card? I know for bbb debian you guys have addded a really nice script tool that achieves that.
Please notice I am not an u-boot, kernel or a beaglebone specialist.
Thanks in advance guys,
Gustavo
I can provide more detail if needed. Along the sd card, other files are also generated from buidlroot:
am335x-boneblack.dtb, boot.vfat, extlinux, MLO, rootfs.ext2, rootfs.ext4, rootfs.tar, sdcard.img, u-boot.img, uEnv.txt, zImage
This is the sd card fdisk -l:
Device Boot StartCHS EndCHS StartLBA EndLBA Sectors Size Id Type
/dev/mmcblk0p1 * 0,0,2 2,10,9 1 32768 32768 16.0M c Win95 FAT32 (LBA)
/dev/mmcblk0p2 2,10,10 67,79,13 32769 1081344 1048576 512M 83 Linux
have you tried to dd the sdcard.img to the emmc
been a while, but i think that is what i did
Thanks, I will have a try and then I will post results here.
You could also just try sudo beagle-flasher.
All newer images should have it.
Hey, but as I said, I am using buildroot to generate my image from scratch, there is no beagle-flasher tool afaik.
You should be able to download the install image on the BBB (when booted from sd card), and then copy in onto the MMC on the device via dd. I’ve only my PB booted right now - but looks like it appears under /dev/mmcblk* - one of those will be the SD card, the other will be the MMC. If you check dmesg you should be able to find which is which.
I guess start from
dmesg | grep mmc
Going through the same thing with Yocto-based images because Yocto also doesn’t include the beagle-flasher that I’ve seen. Debian usually included this by default when getting it from here on beagleboard.org. I noticed this deviation when I went custom embedded Linux and appreciated the built-in functionality.
I’d say if you do go down the route of diskdump (dd) to /dev/mmcblk, be careful to not corrupt the unit by stopping it short due to power issues. You should be able to rewrite another image should that happen.
One tool used and recommended by embedded Linux tutorials, Yocto, etc is a Linux tool called bmaptool. Compared to dd, it has verification capabilities as well as faster image writing speeds. I like the validation capabilities it provides because this is critical for embedded system designs. Robustness and ease helps embedded system engineers sleep at night.
An example command would be:
sudo bmaptool copy sdcard.img /dev/sdX
By booting into the manual SD boot button on the board, then running bmaptool to /dev/mmcblk1 (or whatever your eMMC part is), your eMMC image will be overwritten with your custom buildroot image. You’d have to do this for every image write on buildroot image upgrades unless you make a custom script, possibly even an initramfs entry script but that would be more advanced and possibly unnecessary for personal projects.
One current embedded system design implementation out there is the use of upgrade engines such as RAUC, Mender, even SWUpdate. RAUC is supported by buildroot at the time of this response. If you want to make your life easier with image upgrades on a custom designed OS, I’d look at that: Integration — RAUC 1.15.1 documentation
Lastly, if I were you, I’d just make a bash script with the bmaptool commands, outputs, and recovery logic by rewriting the prior image back. You’d basically be standardizing the commands you already were entering in, such as the dd/bmaptool commands. You’d just have to make sure it’s tested and stable which is a useful skill to learn with embedded engineering. Testing would be making sure you get the same results each time, and the system can smoothly apply image changes with helpful outputs.
Pro-tip: Definitely make sure you’re writing to the right device and partition, so you don’t have to reinstall the sdimg to the SD Card. Bmaptool is more robust for that, but it’s better to build that best practice up.
I understand if this is a lot of info, let me know if there’s further questions or clarification and I’ll do my best to help!
Comparison of the image writing tools: Skip flashing unused blocks with UUU | Marcus Folkesson Blog
More info on bmaptool: Using the bmaptool to record disk images safely and quickly | by Domarys Correa | O.S. Systems | Medium
Sorry for the long delay to reply, but just informing that dd works, but there are some additional steps needed:
  • move sdcard.img to bbb running an image (you might need to increase your sd roofs partition before this)
  • in BBB, assuming image is in /tmp: dd /tmp/sdcard.img of=/dev/mmcblk1 bs=1M
  • mount /dev/mmcblk1p1 /mnt
  • vi /mnt/extlinux/extlinux.conf
  • change mmcblk0 to mmcblk1
  • sync
Thanks for all support
