and compiled the kernel that’s used in that distribution, but the load kernel script fails with “not enough space” message. The page also doesn’t say how to replace the existing kernel.
Also, in general, how do I go from the default kernel image (zImage) to something that can be used in tftp boot and card/internal boot?
I ‘got ubuntu-saucy-13.10-armhf-3.8.13-bone30.img.xz’ and used Win32DiskImager to write the image to the sd card. Once written, I plugged it into the linux mint machine. and 2 partitions got mounted on sdb1 and sdb2. Edited system.sh to have MMC=/dev/sdb
Ran ./tools/install_kernel.sh
I get this:
I see…
fdisk -l:
Disk /dev/sda: 211.1 GB, 211093946368 bytes
Disk /dev/sdb: 16.0 GB, 16012804096 bytes
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 196.6G 0 disk
├─sda1 8:1 0 191.5G 0 part /
├─sda2 8:2 0 1K 0 part
└─sda5 8:5 0 5.1G 0 part [SWAP]
sdb 8:16 1 14.9G 0 disk
├─sdb1 8:17 1 1M 0 part /home/miro/linux-dev/deploy/disk
└─sdb2 8:18 1 1.8G 0 part /media/miro/rootfs_armhf.com
That's not my image, so what's the problem? "armhf.com" decided to
format his image a specific way. Different then the way I've been
supporting beagleboard.org based boards with images for over the last
5 years..
Ah, that makes sense. If I use one of the images suggested above, how do I remove extra services from starting up? I’d like this to be as barebones as possible, yet so I can still use eclipse to remotely deploy the user app. Also, once I have the sd card with the working image, how do I transfer that to the internal flash?
"sudo apt-get remove xyz"
I'd like this to be as barebones as
"barebones as possible"... how about a debian wheezy based install in
less then 64Mb (not including kernel/modules)???
