How to Formally Invoke a "Background Process" in C on a BBW
Here is how you do the background process thing on a Beagle, even stock.
https://www.raspberrypi.org/forums/viewtopic.php?f=33&t=175567
A claim.
ok, here is a good example of how you can run a BBB-specific shell script with the DAEMON1 code examples. It reads back to you the current configurations for pins on the P8/9 headers. Its not just a cat of a config file but saves to a text file AND is entirely available in a C program.
You can also read the resulting text file in python btw.
IMPORTANT: requires the shell script to be in the same directory as the executable. Make “pinmux.sh” and put these lines of shell script in it:
cat /sys/kernel/debug/pinctrl/44e10800.pinmux/pingroups > ./pinmux.txt
sleep 1
exit
IMPORTANT: remember to “chmod 777 pinmux.sh” or it won’t run. ie. make is executable.
I got the info for it from: http://derekmolloy.ie/gpios-on-the-beaglebone-black-using-device-tree-overlays/
#include <stdio.h>
#include <unistd.h>
#include <string.h>
#include <math.h>
#include <sys/types.h>
#include <sys/wait.h>
#include <dirent.h>
main()
int ppid;
int status;
FILE *fptr;
char c;
remove("pinmux.txt");
printf("generating pin group data /sys/kernel/debug/pinctrl/44e10800.pinmux/pingroups...\n");
fflush(NULL);
if ((ppid=fork())==0)
printf("Child process\n");
execlp("bash","bash","./pinmux.sh","",NULL);
return; //terminates child process
//does this block? YES!
// printf("Parent process %d\n",ppid);
wait(&status);
fptr=fopen("pinmux.txt","r");
while(!feof(fptr))
fread(&c,1,1,fptr);
printf("%c",c);
fclose(fptr);
Compile with “gcc pinmux.c -o pinmux -lm” and execute with “./pinmux”
Here is another powerful example of how a correctly set up background process can fetch a web page for you.
Using URL_encode() you can even invoke specific scripts on a remote host via HTTP and HTTPS protocol using CURL (available on stock Angstrom but remember to connect it to the inet).
#include <stdio.h>
#include <unistd.h>
#include <string.h>
#include <math.h>
#include <dirent.h>
main()
int ppid;
int status;
FILE *fptr;
char c;
remove("woody.txt");
printf("Reading the HTML source from Stanford Systems...\n");
fflush(NULL);
execlp("bash","bash","./ecurl.sh","",NULL);
wait(&status);
fptr=fopen("woody.txt","r");
printf("\n\nSource code of Woody's home page.\n\n");
while(!feof(fptr))
fread(&c,1,1,fptr);
printf("%c",c);
fclose(fptr);
Again requires a short shell script to do the actual operation. In this case, put the following shell scripting into “ecurl.sh”:
curl -k http://wodystanford.wordpress.com > ./woody.txt
sleep 1
exit
make executable, and compile C portion and execute as in the previous example.
OK, in summary, what is the MAGIC piece of code here…the crux…the essence:
