How to get started on serial ports on the BBB
I am little confused about serial ports on the BBB.
How can the BBB be connected to a RS 232 port ?? Do I have to use a USB-serial converter ?? or can this be done using the USART I/O pins on the BBB ?
I have seen a tutorial on adafruit that explains serial ports using python, I would like to use C++ for this, could anyone please point out some tutorials that explain how this can be done.
thanks
a
From a hardware perspective id you want to connect to a RS232 interface, you will need an RS232 level shifter.
https://www.sparkfun.com/products/133
Sure I understand, its not the hardware that is the problem, I need some C++ or C tutorials for the BeagleBone black that can help me.
Which of the USART ports can I use ?? Something that runs by default after power up would be good.
thanks
a
In C:
You can enum all the ttys in the system by reading the symlinks in directory /sys/class/tty/.
Then you can read the pseudofile to check if it is a real serial port or a virtual one. The possible values are in <linux/serial.h>:
See: c - UNIX - list all existing serial ports - Stack Overflow
use
dmesg | grep tty
From command. Write a script to monitor status of specific port you are looking for.
