Koen,
That looks beautiful!
I hope it installs it to nand.
Looks great, I'm going to have a quick run at this after work!
Ii will read over the wiki soon. Thanks.
The main problem is that I have no serial console (ongoing issue) with
any computer and my BB.
Could you help with this:
I do not need an MLO to boot.
When I have an MLO on SD it seems to fail to boot, but when I have
just uImage it boots.
Is that normal? I insgtall the right way. Just seems odd. Everyone
needs the MLO, but it does not work for me... It may work, but didn't
work when booting, so I removed it and it boots.
The rootfs.,ubi present lacks a windowing system, but narcissus should be able to generate a .ubi with the GUI you choose.I say ‘should’ since someone reported a bug last week for jffs2, which might affect ubi as well.
If you have networking on your C4 you can login using ssh and install a GUI from the feeds. Keep in mind that it ‘only’ has 256MB of flash, so full GNOME will not fit, but e17 and xfce should work.
