How to make TP Link TL-WN721N Wireless card work in AP Mode (BBB use TI SDK 6.0 ,Kernel 3.2)?
What do i do? Please help
Hello**,**
The TL-WN721N seem to be a atheros AR9271 nic. I have a working AP setup with the beagleboard xM and a atheros AR9271 nic (link below), but the atheros kernel module crashes after a couple of hours. On x86 it is really stable, so it seem to be only related to arm.
Could you describe your setup, are you running hostapd?
I change to use the TL-WN821N,
compile the 8192CU driver for insmod and run the hostapd
it works fine ^ ^
