how to plug and play USB Wi-Fi adapter on Beagleboard?
Hi guys,
I have a USB Wi-Fi adapter and have connected to my Beagleboard. I use wpa supplicant to config the wifi card to connect my wifi network. If I plug the adapter to the board and then boot it, the wpa supplicant and DHCP can run correctly (I changed /etc/network/interface). But if I plug the card to the board which is running, I don’t know how to run wpa supplicant application and DHCP client after the device driver automaticlly loaded. Any ideas about that? Thank you very much.
Best regards,
Raymond
Hi Raymond,
Could you tell me the steps for porting android gingerbread on beagle board-xM. Because there is project to port the android and then put the support of USB wifi dongle on that.
Please Help me.
Warm Regards
~Sumit Gemini
