we are on the process of porting android on beagle board . we are from cair drdo.we have succesfully port angstrom in beagle board.wewe format the s card in to two partion fat 32 and ext 3 partion. then we copy mlo and u boot.bin ,uImage into the fat 32. we copied the andriod .donut.tar.bz in to ext 3.i connect the beagle board to my pc through rs 232.i try select baud rate 115200,stop bit 1flow control none .but i get display 0 0 0 0in terminal window . it will not boot from sd card .,can you suggest some method port android in to beagle board
http://elinux.org/Android_on_OMAP
http://elinux.org/BeagleBoard#Android
2010/3/26 ajish zacharias <ajishzacharias@gmail.com>
