I’m using the minimal version of BBAI64 and it takes about 20 seconds to boot the cli from the SD card.
It probably takes about 10-12 seconds to enter the SD card from u-boot, and about 10 seconds for debian to run, for a total of 20 seconds.
If I shorten the boot select time in u-boot and boot from eMMC without using SD, can I get debian to boot in less than 10 seconds?
Way too much stuff to load, I have not personally tested that, so I could be all wrong. However, a full desktop experience has a ton of code. Do you really need a full debian experience? If not look at Arago minimal image and just add to that one, that boots very fast from SD.
Your best bet for running a full debian experience would be to use RCN’s app note setting the board up to boot using a hybrid configuration using emmc first then continue on using NVMe. It works extremely well, and NVMe will give you about 800 Mbs compared to about 35 Mbs from an SD card.
I haven’t really optimized for boot up speed on the bbai64, looking at one of my docker/sbuilder’s…
voodoo@bbai64-02:~$ sudo systemd-analyze
Startup finished in 4.952s (kernel) + 7.786s (userspace) = 12.738s
graphical.target reached after 7.749s in userspace
voodoo@bbai64-02:~$ sudo systemd-analyze blame
24.491s fstrim.service
5.305s bb-usb-gadgets.service
1.735s docker.service
1.631s systemd-random-seed.service
1.376s dev-nvme0n1p1.device
651ms containerd.service
635ms systemd-udev-trigger.service
525ms man-db.service
460ms schroot.service
384ms systemd-logind.service
362ms systemd-journald.service
337ms systemd-resolved.service
267ms user@1000.service
254ms systemd-timesyncd.service
250ms systemd-networkd.service
240ms bb-symlinks.service
203ms apparmor.service
202ms systemd-journal-flush.service
191ms ssh.service
181ms avahi-daemon.service
177ms e2scrub_reap.service
150ms cockpit-motd.service
147ms systemd-tmpfiles-setup.service
129ms logrotate.service
116ms wpa_supplicant.service
98ms networking.service
93ms rsyslog.service
84ms cockpit.socket
83ms systemd-udevd.service
71ms systemd-remount-fs.service
67ms dev-hugepages.mount
65ms systemd-update-utmp.service
61ms rpcbind.service
disabling bb-usb-gadgets.service should give you some bootup, we ship with docker.service pre-installed…
This is an eMMC/nvme hybrid: BBAI64 - NVMe - rootfs
voodoo@bbai64-02:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0 179:0 0 14.6G 0 disk
├─mmcblk0p1 179:1 0 128M 0 part /boot/firmware
└─mmcblk0p2 179:2 0 14.5G 0 part
nvme0n1 259:0 0 232.9G 0 disk
└─nvme0n1p1 259:1 0 232.9G 0 part /
mmcblk0boot0 179:256 0 4M 1 disk
mmcblk0boot1 179:512 0 4M 1 disk
