Hey every one,
I have some troubles with the wifi reception of my local network
how can I simply restart the right systemctl service in order to avoid a reboot ?
I mean reseting the wifi states like a fresh reboot will normally do without rebooting of course ?
I m on beagle black wire less and the problem don’t come from the beagle board I just need to avoid a reboot…
Did you try the terminal command
sudo systemctl restart network[.service]
The .service
extension is necessary for old kernel versions (< 4.0 AFAIR).
I will try this one ! so far I have tried connman.service
networking.service
wpa_supplicant.service
But sadly nothing work well I fill like my wifi was jammed by bad signals coming from some where … maybe is there a kind of cache to flush ? if any one have an idea the main fact is when I restart the connection is working back again so I just want avoid a reboot…
I usually do this to reset my wlan connection (assuming your wifi interface is wlan0):
sudo ip link set wlan0 down
sudo ip link set wlan0 up
connmanctl scan wifi
oh cool I will try that thanks a lot
