If you are using Angstrom I believe if you look around /etc/systemd/system/graphical.target.wants you can remove the sym link : gdm.service → /lib/systemd/system/gdm.service this should do it.
Can you share your project, does sound like fun. We need more fun!
David
If you are using Angstrom I believe if you look around /etc/systemd/system/graphical.target.wants you can remove the sym link : gdm.service -> /lib/systemd/system/gdm.service this should do it.
Or the proper way:
systemctl disable gdm.service
Thanks Koen, That helps me understand whats going on. That makes much more sense now.
David
