Hi all,
During video play using a FS with Froyo and DSP, I am observing kernel
crashes that seems to be due to v4l2 buffer allocation so I am trying
the extra bootarg suggestion explained in:
http://code.google.com/p/rowboat/wiki/DSP#Boot
The problem is that my new bootargs do not fit in a single line so I
am trying to divide it in two lines. These are the bootargs I am
using:
setenv firstargs 'setenv bootargs mem=88M@0x80000000
mem=128M@0x88000000 androidboot.console=ttyS2 console=tty0
console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw init=/init rootwait
omapdss.def_disp=dvi omapfb.mode=dvi:1280x720MR-16@60'
setenv secondargs 'setenv bootargs $(bootargs)
omap_vout.vid1_static_vrfb_alloc=y omap_vout.video1_numbuffers=3
omap_vout.video2_numbuffers=0 omap_vout.video1_bufsize=1843200'
setenv bootcmd 'mmc init; fatload mmc 0 84000000 uImage; run firstargs
secondargs; bootm 84000000'
When I try to boot, the booting hangs and only the following lines get
printed:
OMAP3 beagleboard.org # boot
mmc1 is available
reading uImage
2452556 bytes read
## Booting kernel from Legacy Image at 84000000 ...
Image Name: Linux-2.6.32
Data Size: 2452492 Bytes = 2.3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux..........................................................................................................................................................
done, booting the kernel.
Can you please help me with this issue?
BTW, the U-Boot I am using is the one in http://rowboat.googlecode.com/files/u-boot.beagle.bin
Thanks in advanced,
Juan Garibay
