Hi
Can anyone help me how to start beagle board? I hv purchased it just couple of day back. I have window 7 installed in my laptop and hv USB to serial converter. I have connected it to beagle board but not able to connect. i have beagle board A3 version.
Pls help me out.
Vishal
Hello Vishal,
First of all, you should read the BeagleBoard System Reference Manual
(in this case version C4):
http://beagleboard.org/static/BBSRM_latest.pdf
You are going to have to search for the version A3...
Then, buy the parts you need:
http://specialcomp.com/beagleboard/
If you are using usb to serial. You probably want to download a
software called Putty. That way, you can connect from your laptop to
your board.
You are gonna need to make sure that you have a Linux SD Card also.
There are several
websites but that depends also on the BB version which you are using.
Some websites are:
http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidationv3
http://code.google.com/p/beagleboard/wiki/LinuxBootDiskFormat
http://elinux.org/BeagleBoardUbuntu
http://www.snowbotic.com/archives/33
Frederico
