My BBB does not log into X11. Instead, it logs into terminal.
So I logged in as root and gave command ‘systemctl start gdm’. However I’m getting message as no such file found.
Sabi ni Sarkar noong Sunday, October 20, 2013 6:34:14 AM UTC+8:
A Linux newbie here.
Please help me to solve the issue!
P.S. I have updated the latest Angstrom image.
I believe you can start GNOME by typing in
gnome-session
I’m not quite sure because I normally go into my BBB through the LAN, and then I ssh -X and do the gnome-session command.
As to starting the BBB with gdm, I think you may have to edit /etc/ttys but then I normally use FreeBSD so I can’t be too sure. And in any case, I’ll echo lazarman’s suggestion that you ask about that in the Linux newbie group
