On Sun, 13 May 2018 09:36:09 +0100, Chris Green
<cl@isbd.net> declaimed the following:
Okay, I've not updated mine in some time...
Or, maybe... closely observe the blinkenlights... One identifies mmc0
activity, and another mmc1 activity (now -- which is considered 0 and 1 is
an exercise for the user; I have a vague memory that at one point in the
past, 0 and 1 depended upon which device was used for booting, and was not
fixed to eMMC vs SD).
Yes, I don't think the mmc0/mmc1 thing helps much, they seem not to
relate spcifically to eMMC and microSD - which is a pity.
Booting from the eMMC showed most, if not all, activity on LED 3 (0
being the heartbeat).
debian@beaglebone:~$ uname -a
Linux beaglebone 4.4.54-ti-r93 #1 SMP Fri Mar 17 13:08:22 UTC 2017 armv7l
GNU/Linux
debian@beaglebone:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 0 10240 0% /dev
tmpfs 99956 2924 97032 3% /run
/dev/mmcblk1p1 3704040 3064828 431340 88% /
tmpfs 249888 4 249884 1% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 249888 0 249888 0% /sys/fs/cgroup
tmpfs 49980 0 49980 0% /run/user/1000
Now, installing an old SD card and rebooting (forgot how long the BBB
takes to shutdown) had some flickers on LED 3, but most activity is now on
LED 1
GNU/Linux
/dev/mmcblk0p1 7570776 3037308 4174464 43% /
A second SD card (after a full shutdown, since I don't want to corrupt
it by having the system trying to flush to the old one)... Most activity
still on LED 1 during boot.
GNU/Linux
/dev/mmcblk0p1 7570776 3037312 4174460 43% /
Interesting -- all show the same "uname" results, but the "df" results
are different. Based on "apt-get update" all three must still be Jessie
installs. Time to configure one of the cards with the Stretch (or whatever
the current is called) build (and remember how to copy my home
configuration settings across, do an eMMC flash, and then "unflasher" the
SD card and resize the partition.
