I have a device with a black Beagle Bone and I would like to update a file inside the firmware from which the device boots. I don’t have the original source code. At the moment I use the following steps on a 64-bit GNU/Linux desktop (Ubuntu) to try to accomplish this, but unfortunately the device does not boot from the resulting firmware. What do I need to change in order to alter an image successfully?
sudo su
tar xf FIRMWARE.tar.gz
mkimage -l initramfs.bin.SD
tail -c+65 < initramfs.bin.SD > Angstrom-xxxxxxxx_m-eglibc-ipk-v2013.06-beaglebone.rootfs.cpio.gz
mv initramfs.bin.SD initramfs.bin.SD.orig
gunzip Angstrom-xxxxxxxx_m-eglibc-ipk-v2013.06-beaglebone.rootfs.cpio.gz
mkdir unpacked
cd unpacked
cat …/Angstrom-xxxxxxxx_m-eglibc-ipk-v2013.06-beaglebone.rootfs.cpio | cpio -i
here change a text file
mkdir …/new
find . | cpio -H newc -o > …/new/Angstrom-xxxxxxxx_m-eglibc-ipk-v2013.06-beaglebone.rootfs.cpio
cd …/new
gzip -9 Angstrom-xxxxxxxx_m-eglibc-ipk-v2013.06-beaglebone.rootfs.cpio
mv Angstrom-xxxxxxxx_m-eglibc-ipk-v2013.06-beaglebone.rootfs.cpio.gz initramfs.gz
mkimage -A arm -O linux -n Angstrom-xxxxxxxx_m-eglibc-ipk-v -d initramfs.gz …/initramfs.bin.SD
cd …
tar cfvz FIRMWARE_new.tar.gz am335x-boneblack-xxxxxxxxx.dtb initramfs.bin.SD runme.sh
use FIRMWARE_new.tar.gz to install on a running device and reboot
We chatted for a while on IRC, but most of the pertinent information is still missing from your post. Did you create a backup from an eMMC somehow? You didn’t even provide a boot log. See Smart Questions on bbb.io/chat.
Jason, thanks for your reply. The device doesn’t have a screen or anything. I do have original firmware and a firmware version modified by someone else. The manufacturer and that independent other person who modified it both won’t give out how to unpack and pack. But for someone that has some experience with this, it should not be that difficult. Can I send firmware to you to have a look? Is only 12 MB. Thanks, Pander
Can you post publicly with your description of how you are trying to modify it?
He / we simply want to remove an instruction in the altered firmware, as the original stock firmware is insecure but the adjusted firmware, even though open source, has a pa
I just stumbled on this threat also looking for pointers on the same challenging file. i think we just need to be able to decompile this 12 MB file initramfs.bin.SD . once thats done and the file is readable, it should be easy to adjust, recompile and create our own custom FW.
