Thank you for providing your valuable inputs.
I downloaded the latest U-boot, compiled and flashed in devkit board,
Now it is booting.
But I'm getting so many nand warnings and LCD is not coming up and
corresponding error logs are copied below:
Please provide the inputs on how to bring up LCD on devkit8000, Please
let me know if more information is required to conclude on this issue.
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux-2.6.38-rc1-g34a02d2-dirty
Data Size: 2427808 Bytes = 2.3 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 2.6.38-rc1-g34a02d2-dirty (andcoe@andcoe)
(gcc version 4.4.3 (GCC) ) #5 Fri Mar 11 16:37:31 IST1
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction cache
[ 0.000000] Machine: OMAP3 Devkit8000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x10000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=/dev/
mmcblk0p2 rw rootwait video=omapfb:mode:4.3inch_LCD
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5,
131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 255008k/255008k available, 7136k reserved, 0K
highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0035000 ( 180 kB)
[ 0.000000] .text : 0xc0035000 - 0xc0465628 (4290 kB)
[ 0.000000] .data : 0xc0466000 - 0xc0498c40 ( 204 kB)
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns,
wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000244] Calibrating delay loop... 473.71 BogoMIPS (lpj=1851392)
[ 0.170837] pid_max: default: 32768 minimum: 301
[ 0.171081] Mount-cache hash table entries: 512
[ 0.171539] CPU: Testing write buffer coherency: ok
[ 0.175476] print_constraints: dummy:
[ 0.175628] NET: Registered protocol family 16
[ 0.178680] omap_device: omap_gpio.0: new worst case activate
latency 0: 30517
[ 0.178771] OMAP GPIO hardware version 2.5
[ 0.178863] OMAP GPIO hardware version 2.5
[ 0.178955] OMAP GPIO hardware version 2.5
[ 0.179046] OMAP GPIO hardware version 2.5
[ 0.179138] OMAP GPIO hardware version 2.5
[ 0.179229] OMAP GPIO hardware version 2.5
[ 0.181121] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.182617] omap_device: omap_uart.0: new worst case deactivate
latency 0: 30517
[ 0.183166] omap_device: omap_uart.1: new worst case activate
latency 0: 30517
[ 0.187347] Found NAND on CS0
[ 0.187377] Registering NAND on CS0
[ 0.194152] OMAP DMA hardware revision 4.0
[ 0.214294] bio: create slab <bio-0> at 0
[ 0.217224] SCSI subsystem initialized
[ 0.220275] usbcore: registered new interface driver usbfs
[ 0.220550] usbcore: registered new interface driver hub
[ 0.220855] usbcore: registered new device driver usb
[ 0.222015] omap_device: omap_i2c.1: new worst case activate
latency 0: 30517
[ 0.222106] omap_i2c omap_i2c.1: bus 1 rev3.12 at 2600 kHz
[ 0.225982] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.226043] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.226715] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.230682] print_constraints: VUSB1V5: 1500 mV normal standby
[ 0.231597] print_constraints: VUSB1V8: 1800 mV normal standby
[ 0.232421] print_constraints: VUSB3V1: 3100 mV normal standby
[ 0.234405] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.235992] print_constraints: VPLL1: 1800 mV normal standby
[ 0.238128] print_constraints: VIO: 1800 mV normal standby
[ 0.239196] print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV
normal standby
[ 0.240081] print_constraints: VDAC: 1800 mV normal standby
[ 0.240264] omap_device: omap_i2c.1: new worst case deactivate
latency 0: 30517
[ 0.240417] omap_i2c omap_i2c.3: bus 3 rev3.12 at 400 kHz
[ 0.242218] Advanced Linux Sound Architecture Driver Version
1.0.23.
[ 0.243286] Switching to clocksource 32k_counter
[ 0.271972] musb-hdrc: version 6.0, tusb-omap-dma, otg (peripheral
+host), debug=0
[ 0.272674] NET: Registered protocol family 2
[ 0.272857] IP route cache hash table entries: 2048 (order: 1, 8192
bytes)
[ 0.273345] TCP established hash table entries: 8192 (order: 4,
65536 bytes)
[ 0.273590] TCP bind hash table entries: 8192 (order: 3, 32768
bytes)
[ 0.273712] TCP: Hash tables configured (established 8192 bind
8192)
[ 0.273742] TCP reno registered
[ 0.273742] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.273773] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.274169] NET: Registered protocol family 1
[ 0.274566] RPC: Registered udp transport module.
[ 0.274566] RPC: Registered tcp transport module.
[ 0.274597] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 0.274902] NetWinder Floating Point Emulator V0.97 (double
precision)
[ 0.277465] VFS: Disk quotas dquot_6.5.2
[ 0.277557] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 0.278198] JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[ 0.278533] msgmni has been set to 498
[ 0.279541] io scheduler noop registered
[ 0.279541] io scheduler deadline registered
[ 0.279632] io scheduler cfq registered (default)
[ 0.337280] OMAP DSS rev 2.0
[ 0.337371] OMAP DISPC rev 3.0
[ 0.337432] OMAP VENC rev 2
[ 0.502838] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.505371] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a
OMAP UART0
[ 0.505889] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a
OMAP UART1
[ 0.506408] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a
OMAP UART2
[ 1.096130] console [ttyO2] enabled
[ 1.115112] brd: module loaded
[ 1.125762] loop: module loaded
[ 1.132110] omap2-nand driver initializing
[ 1.136810] ONFI flash detected
[ 1.140380] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 256MiB 1,8V 16-bit)
[ 1.149902] cmdlinepart partition parsing not available
[ 1.155395] Creating 5 MTD partitions on "omap2-nand.0":
[ 1.161041] 0x000000000000-0x000000080000 : "X-Loader"
[ 1.168853] 0x000000080000-0x000000260000 : "U-Boot"
[ 1.176818] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 1.184448] 0x000000280000-0x000000680000 : "Kernel"
[ 1.193328] 0x000000680000-0x000010000000 : "File System"
[ 1.301361] dm9000 Ethernet Driver, V1.31
[ 1.400573] eth0: dm9000a at d086a000,d086e400 IRQ 185 MAC:
02:c0:03:00:d0:12 (platform data)
[ 1.409881] usbmon: debugfs is not available
[ 1.414367] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 2.423156] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 2.429168] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 2.437347] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 2.454406] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 2.460632] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 2.467803] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 2.475433] usb usb1: Product: OMAP-EHCI Host Controller
[ 2.481048] usb usb1: Manufacturer: Linux 2.6.38-rc1-g34a02d2-dirty
ehci_hcd
[ 2.488494] usb usb1: SerialNumber: ehci-omap.0
[ 2.494567] hub 1-0:1.0: USB hub found
[ 2.498535] hub 1-0:1.0: 3 ports detected
[ 2.534210] input: TWL4030 Keypad as /devices/platform/omap/
omap_i2c.1/i2c-1/1-004a/twl4030_keypad/input/input0
[ 2.547210] ads7846 spi2.0: touchscreen, irq 187
[ 2.553039] input: ADS7846 Touchscreen as /devices/platform/
omap2_mcspi.2/spi2.0/input/input1
[ 2.563323] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 2.569976] twl_rtc twl_rtc: Power up reset detected.
[ 2.575653] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 2.580902] i2c /dev entries driver
[ 2.586303] sdhci: Secure Digital Host Controller Interface driver
[ 2.592834] sdhci: Copyright(c) Pierre Ossman
[ 2.603820] usbcore: registered new interface driver usbhid
[ 2.609680] usbhid: USB HID core driver
[ 2.615570] OMAP3 Beagle/Devkit8000 SoC init
[ 2.706481] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 2.714416] ALSA device list:
[ 2.717529] #0: omap3beagle
[ 2.720916] TCP cubic registered
[ 2.724334] NET: Registered protocol family 17
[ 2.729064] NET: Registered protocol family 15
[ 2.733795] Registering the dns_resolver key type
[ 2.738830] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 1
[ 2.748199] omap_voltage_late_init: Unable to create voltage
debugfs main dir
[ 2.755798] vdd_debugfs_init: Unable to create debugfs directory
for vdd_mpu
[ 2.763275] vdd_debugfs_init: Unable to create debugfs directory
for vdd_core
[ 2.771575] Power Management for TI OMAP3.
[ 2.779937] omapfb omapfb: no driver for display
[ 2.784881] omapfb omapfb: no driver for display
[ 2.789733] omapfb omapfb: failed to setup omapfb
[ 2.797149] regulator_init_complete: VDAC: incomplete constraints,
leaving on
[ 2.805725] twl_rtc twl_rtc: setting system clock to 2000-01-01
00:00:00 UTC (946684800)
[ 2.814819] Waiting for root device /dev/mmcblk0p2...
[ 2.938842] mmc0: new high speed SD card at address b368
[ 2.945220] mmcblk0: mmc0:b368 SDC 3.81 GiB
[ 2.952423] mmcblk0: p1 p2
[ 3.037261] EXT3-fs: barriers not enabled
[ 6.220336] kjournald starting. Commit interval 5 seconds
[ 6.234802] EXT3-fs (mmcblk0p2): using internal journal
[ 6.240356] EXT3-fs (mmcblk0p2): recovery complete
[ 6.255065] EXT3-fs (mmcblk0p2): mounted filesystem with writeback
data mode
[ 6.262573] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 6.269012] Freeing init memory: 180K
INIT: version 2.86 booting
Please wait: booting...
