I want’s to use u-bootv2 in beagleboard.But when I compile,I can’t find the options of our board in menuconfig.Can anyone give some instructions about how to compile it and use it?
zhenzhi wu wrote:
I want's to use u-bootv2
u-boot-v2 is now called barebox
http://lists.infradead.org/pipermail/u-boot-v2/2009-December/000149.html
You might be interested in
too.
in beagleboard.But when I compile,I can't find the
Some minutes ago
> git clone git://www.denx.de/git/u-boot-v2.git u-boot-v2
> cd u-boot-v2/
> export ARCH=arm
> export CROSS_COMPILE=arm-none-linux-gnueabi-
> make omap3530_beagle_per_uart_defconfig
worked fine. Most probably you need this patch
http://lists.infradead.org/pipermail/u-boot-v2/2009-December/000175.html
for compilation ('make'), then.
Best regards
Dirk
I am trying to use u-bootv2 to load u-bootv1,following http://elinux.org/BeagleBoardRecovery,
I can download the ubootv2 to the board and it runs.however,when I am trying to use the command ‘loadb’,it returns with error.Is there some configuration should I do?
X-load Beagle>loadb
loadb returned with -2
Can I load ubootv1 in other ways?
BeagleBoardRecovery - eLinux.org,
to use the command 'loadb',it returns with error.Is there some configuration
should I do?X-load Beagle>loadb
loadb -f /dev/ram0
