I am trying to get the default Libero design and I am having trouble getting the HSS to build. I am using GitBash to go through the “Exploring Gateware Design with Libero” demo and the source script that bustedwing created. I am getting the error:
riscv64-unknown-elf-gcc.exe: error: bui: No such file or directory
make: *** [Makefile:137: hss-l2scratch.elf] Error 1
!!! Error: Hart Soft Service build failed !!!
$ python build-bitstream.py ./build-options/default.yaml
Running on Windows host
Windows Subsystem for Linux installed
Found device tree compiler: Version: DTC 1.6.1
Design version: 2004
Initialize workspace
The FlashPro Express bitstream programming job files will be stored in
directory: ./bitstream/FlashProExpress
Clone sources
HSS checked out at commit v2025.03
Applying: Disable annoying debug message
Applying: Bring back old DESIGNVER formatting
Generate Device Tree Overlays
Board options path: .\board-options\board-selection.yaml
The board selected is: mpfs-beaglev-fire
Path to dtso files: device-tree-overlay
Device tree overlay selected:
component: CAPE
build option: DEFAULT
device tree overlay file: cape-gpios.dtso
component: CAPE
device tree overlay file: leds.dtso
component: M2
device tree overlay file: pcie.dtso
number of gateware device tree overlays: 3
C:\Cadence\SPB_22.1\Beagle_m2\gateware\work\dtbo\context-0\CAPE\cape-gpios.dtbo
C:\Cadence\SPB_22.1\Beagle_m2\gateware\work\dtbo\context-0\CAPE\leds.dtbo
C:\Cadence\SPB_22.1\Beagle_m2\gateware\work\dtbo\context-0\M2\pcie.dtbo
b'MCHP\x1c\x00\x00\x00\x00\x00\x01\x00\x10\x00\x00\x00\x03\x00\x00\x008\x00\x00\x00*\x0b\x00\x00\xf2\n\x00\x00*\x0b\x00\x00\xd0\x11\x00\x00\xa6\x06\x00\x00\xd0\x11\x00\x00<\x13\x00\x00l\x01\x00\x00'
|| -- Board: mpfs-beaglev-fire --||-- Die: MPFS025T --||-- Package: FCVG484 --||-- Die voltage: 1.0 --||-- Part range: EXT --||
MSS folder path: .\sources\MSS_Configuration\MPFS025T\FCVG484\mpfs-beaglev-fire
Selected config file: .\sources\MSS_Configuration\MPFS025T\FCVG484\mpfs-beaglev-fire\MSS_Configuration.cfg
Generating MSS configuration
INFO: Fabric programming is required to apply changes to following FICs settings. FIC_0 (AXI4) , FIC_1 (AXI4) , FIC_2 (AXI4) and FIC_3 (APB).
INFO: MSS PLL - Input Reference Clock frequency 125.000 MHz
| Output Clock Name | Required (MHz) | Integer solution (MHz) |
| Output0 Frequency (CPU) | 600.000 | 600.000 |
| Output1 Frequency (Crypto) | N/A | N/A |
| Output2 Frequency (EMMC/SD) | 200.000 | 200.000 |
| Output3 Frequency (CAN) | 8.000 | 8.000 |
INFO: DDR PLL - Input Reference Clock frequency 125.000 MHz
| Output0 Frequency | 800.000 | 800.000 |
| Output1 Frequency | 400.000 | 400.000 |
| Output2 Frequency | 800.000 | 800.000 |
| Output3 Frequency | 800.000 | 800.000 |
INFO: SGMII PLL - Input Reference Clock frequency 125.000 MHz
| Output0 Frequency | 625.000 | 625.000 |
| Output1 Frequency | 625.000 | 625.000 |
| Output2 Frequency | 625.000 | 625.000 |
| Output3 Frequency | 625.000 | 625.000 |
INFO: Successfully generated xml file to 'C:\Cadence\SPB_22.1\Beagle_m2\gateware\work\MSS/PF_SOC_MSS_mss_cfg.xml'
INFO: Successfully generated MSS configuration report to 'C:\Cadence\SPB_22.1\Beagle_m2\gateware\work\MSS\PF_SOC_MSS_Report.html'
INFO: Successfully generated MSS component to 'C:\Cadence\SPB_22.1\Beagle_m2\gateware\work\MSS/PF_SOC_MSS.cxz'
INFO: FPGA Fabric programming is required.
Build Hart Software Services (HSS)
Target board: mpfs-beaglev-fire
Cleaning up existing XML files in ./sources\HSS\boards\mpfs-beaglev-fire\soc_fpga_design\xml
Removing ./sources\HSS\boards\mpfs-beaglev-fire\soc_fpga_design\xml\PF_SOC_MSS_mss_cfg.xml
Copying new XML file from work\MSS\PF_SOC_MSS_mss_cfg.xml to sources\HSS\boards\mpfs-beaglev-fire\soc_fpga_design\xml\PF_SOC_MSS_mss_cfg.xml
INFO: Windows detected
mpfs-beaglev-fire selected
INFO: NOTICE: enabling -flto (which means stack protection is disabled)
INFO: Expected mpfsBootmodeProgrammer.jar version v3.6 but found
INFO: This version of the HSS relies on SoftConsole v2021.3 or later
MPFSCFGGEN boards/mpfs-beaglev-fire/soc_fpga_design/xml/PF_SOC_MSS_mss_cfg.xml
Input XML file: C:\Cadence\SPB_22.1\Beagle_m2\gateware\sources\HSS\boards\mpfs-beaglev-fire\soc_fpga_design\xml/PF_SOC_MSS_mss_cfg.xml
Hardware configuration header files created in directory: C:\Cadence\SPB_22.1\Beagle_m2\gateware\sources\HSS\build\boards\mpfs-beaglev-fire/fpga_design_config
GENCONFIG
INFO: SoftConsole on Windows detected, adding C:\Cadence\SPB_22.1\Beagle_m2\gateware\sources\HSS\thirdparty\Kconfiglib to Python sys.path
CC build/application/hart0/hss_state_machine.o
CC build/application/hart0/hss_clock.o
CC build/application/hart0/hss_registry.o
CC build/baremetal/drivers/mss/mss_usb/mss_usb_common_cif.o
CC build/baremetal/drivers/mss/mss_usb/mss_usb_device.o
CC build/baremetal/drivers/mss/mss_usb/mss_usb_device_cif.o
CC build/baremetal/drivers/mss/mss_usb/mss_usb_device_msd.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/hal/hal_irq.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/drivers/mss/mss_gpio/mss_gpio.o
CC build/services/beu/beu_service.o
CC build/services/boot/hss_boot_service.o
CC build/services/boot/hss_boot_pmp.o
CC build/services/boot/gpt.o
CC build/services/ddr/ddr_service.o
CC build/services/ddr/ddr_api.o
CC build/services/goto/goto_service.o
CC build/services/healthmon/healthmon_service.o
CC build/services/healthmon/healthmon_monitors_weak.o
CC build/services/gpio_ui/gpio_ui_service.o
CC build/services/gpio_ui/gpio_ui_api.o
CC build/services/ipi_poll/ipi_poll_service.o
CC build/services/opensbi/opensbi_service.o
CC build/thirdparty/opensbi/lib/utils/irqchip/plic.o
CC build/thirdparty/opensbi/lib/utils/libfdt/fdt.o
CC build/thirdparty/opensbi/lib/utils/libfdt/fdt_ro.o
CC build/thirdparty/opensbi/lib/utils/libfdt/fdt_rw.o
CC build/thirdparty/opensbi/lib/utils/libfdt/fdt_wip.o
CC build/thirdparty/opensbi/lib/utils/libfdt/fdt_addresses.o
CC build/thirdparty/opensbi/lib/utils/fdt/fdt_fixup.o
CC build/thirdparty/opensbi/lib/utils/fdt/fdt_helper.o
CC build/thirdparty/opensbi/lib/sbi/riscv_asm.o
CC build/thirdparty/opensbi/lib/sbi/riscv_atomic.o
CC build/thirdparty/opensbi/lib/sbi/riscv_locks.o
CC build/thirdparty/opensbi/lib/sbi/sbi_bitmap.o
CC build/thirdparty/opensbi/lib/sbi/sbi_bitops.o
CC build/thirdparty/opensbi/lib/sbi/sbi_console.o
CC build/thirdparty/opensbi/lib/sbi/sbi_domain.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall.o
CC build/thirdparty/opensbi/lib/sbi/sbi_emulate_csr.o
CC build/thirdparty/opensbi/lib/sbi/sbi_fifo.o
CC build/thirdparty/opensbi/lib/sbi/sbi_hart.o
CC build/thirdparty/opensbi/lib/sbi/sbi_hsm.o
CC build/thirdparty/opensbi/lib/sbi/sbi_illegal_insn.o
CC build/thirdparty/opensbi/lib/sbi/sbi_init.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ipi.o
CC build/thirdparty/opensbi/lib/sbi/sbi_irqchip.o
CC build/thirdparty/opensbi/lib/sbi/sbi_math.o
CC build/thirdparty/opensbi/lib/sbi/sbi_misaligned_ldst.o
CC build/thirdparty/opensbi/lib/sbi/sbi_platform.o
CC build/thirdparty/opensbi/lib/sbi/sbi_pmu.o
CC build/thirdparty/opensbi/lib/sbi/sbi_scratch.o
CC build/thirdparty/opensbi/lib/sbi/sbi_string.o
CC build/thirdparty/opensbi/lib/sbi/sbi_system.o
CC build/thirdparty/opensbi/lib/sbi/sbi_timer.o
CC build/thirdparty/opensbi/lib/sbi/sbi_tlb.o
CC build/thirdparty/opensbi/lib/sbi/sbi_trap.o
CC build/thirdparty/opensbi/lib/sbi/sbi_unpriv.o
CC build/thirdparty/opensbi/lib/utils/timer/aclint_mtimer.o
CC build/thirdparty/opensbi/lib/utils/ipi/aclint_mswi.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall_base.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall_hsm.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall_ipi.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall_legacy.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall_pmu.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall_rfence.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall_srst.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall_time.o
CC build/thirdparty/opensbi/lib/sbi/sbi_ecall_vendor.o
CC build/services/opensbi/opensbi_ihc_ecall.o
CC build/services/opensbi/opensbi_rproc_ecall.o
CC build/services/opensbi/platform.o
CC build/services/opensbi/opensbi_ecall.o
CC build/services/reboot/reboot_service.o
CC build/services/scrub/scrub_service.o
CC build/services/sgdma/sgdma_service.o
CC build/services/startup/startup_service.o
CC build/services/tinycli/tinycli_api.o
CC build/services/tinycli/tinycli_service.o
CC build/services/tinycli/tinycli_hexdump.o
CC build/services/usbdmsc/flash_drive/flash_drive_app.o
CC build/services/usbdmsc/usbdmsc_api.o
CC build/services/usbdmsc/usbdmsc_service.o
CC build/services/usbdmsc/flash_drive/usb_user_descriptors.o
CC build/services/wdog/wdog_service.o
CC build/modules/compression/hss_decompress.o
CC build/thirdparty/miniz/miniz.o
CC build/modules/ssmb/ipi/ssmb_ipi.o
CC build/application/hart0/hss_init.o
CC build/application/hart0/hss_main.o
CC build/application/hart1-4/u54_handle_ipi.o
CC build/application/hart1-4/u54_state.o
CC build/boards/mpfs-beaglev-fire/hss_uart_init.o
CC build/boards/mpfs-beaglev-fire/uart_device_list.o
CC build/boards/mpfs-beaglev-fire/hss_board_init.o
CC build/boards/mpfs-beaglev-fire/hss_logo_init.o
CC build/init/hss_ddr_init.o
CC build/init/hss_boot_init.o
CC build/init/hss_sys_setup.o
CC build/init/hss_usb_init.o
CC build/init/hss_ihc_init.o
CC build/init/hss_pcie_init.o
CC build/init/hss_opensbi_init.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/drivers/mss/mss_pdma/mss_pdma.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/drivers/mss/mss_mmc/mss_mmc.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/drivers/mss/mss_mmc/mss_mmc_if.o
CC build/baremetal/drivers/fpga_ip/miv_ihc/miv_ihc.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/drivers/mss/mss_mmuart/mss_uart.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/drivers/mss/mss_sys_services/mss_sys_services.o
CC build/baremetal/drivers/mss/mss_watchdog/mss_watchdog.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/mss_mpu.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/mss_peripherals.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/mss_plic.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/mss_beu.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/mss_l2_cache.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/mss_util.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/nwc/mss_nwc_init.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/nwc/mss_io.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/nwc/mss_pll.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/mss_pmp.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/nwc/mss_sgmii.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/startup_gcc/system_startup.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/nwc/mss_ddr.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/nwc/mss_ddr_debug.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/common/nwc/mss_ddr_test_pattern.o
CC build/services/mmc/mmc_api.o
CC build/modules/debug/hss_debug.o
CC build/modules/debug/hss_perfctr.o
CC build/modules/misc/assert.o
CC build/modules/misc/csr_helper.o
CC build/modules/misc/c_stubs.o
CC build/modules/misc/hss_crc16.o
CC build/modules/misc/hss_crc32.o
CC build/modules/misc/hss_memcpy_via_pdma.o
CC build/modules/misc/hss_progress.o
CC build/modules/misc/device_serial_number.o
CC build/modules/misc/design_version_info.o
CC build/modules/misc/uart_helper.o
CC build/modules/misc/hss_trigger.o
CC build/modules/misc/hss_memtest.o
CC build/application/crt.o
CC build/baremetal/polarfire-soc-bare-metal-library/src/platform/mpfs_hal/startup_gcc/mss_utils.o
CC build/thirdparty/opensbi/lib/sbi/riscv_hardfp.o
CC build/thirdparty/opensbi/lib/sbi/sbi_expected_trap.o
CC build/thirdparty/opensbi/lib/sbi/sbi_hfence.o
CARRAY thirdparty/opensbi/lib/sbi/sbi_ecall_exts.carray
CC build/services/opensbi/opensbi_ecall_exts.o
CPP boards/mpfs-beaglev-fire/hss-l2scratch.ld
LD hss-l2scratch.elf
Upon researching online, the issue maybe because of my PATH being incorrect. I tried installing and setting a new path, but I am running into the same error. Running riscv64-unknown-elf-gcc --version gets me:
riscv64-unknown-elf-gcc.exe (SiFive GCC-Metal 10.2.0-2020.12.8) 10.2.0
Copyright (C) 2020 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
I am not sure where to go from here. Please let me know if I can provide anymore information. Thanks.
