I have been creating my http server running in BBB with the standard method, create an server and listen in port 8888…
var server = http.createServer(function (req, res) {}).listen(8888); And it works fine.
But when i placed the JS file in cloud9/autorun folder, it dosen’t work anymore. As i understand, the autorun program has already occupied the listening port 8888, and caused the conflict of using port 8888.
So i wonder if there is any solution behind this? Can’t i use both of autorun mecanism and listening port 8888, or i have to give up one of these two? Or there is another port number to use to build the http server?
Chen
On Wed, 25 May 2016 02:28:26 -0700 (PDT),
bchengcong@gmail.com declaimed the following:
But when i placed the JS file in cloud9/autorun folder, it dosen't work
So i wonder if there is any solution behind this? Can't i use both of
There is nothing sacred about 8888.
Formal HTTP servers normally bind to port 80.
Any port number >1024 is a non-reserved port, and does not need special
privileges to use.
A common choice for "user" HTTP servers is port 8080.
