Hi, evenryone
I’m using SD booting (my u-boot, kernel, rootfs exists in SD card)
My toolchain is gcc-linaro-arm-linux-gnueabihf-4.8-2013.10 version and my root file system is debian 7.0.
My kernel is extracted from TI_Android_JB_4.2.2_DevKit_4.1.1.
Kernel boots well and it seems that “init” in debian 7.0 is called.
But some lines is exected and segmentation fault occurred.
I attach the log below.
Please let me know how to solve this problem.
Thanks in advance.
U-Boot 2013.10 (Mar 29 2014 - 17:11:27)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: 0 MiB
cpsw, usb_ether
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
185 bytes read in 3 ms (59.6 KiB/s)
Checking if uenvcmd is set …
Running uenvcmd …
reading uImage
4156112 bytes read in 400 ms (9.9 MiB/s)
Booting kernel from Legacy Image at 81000000 …
Image Name: Linux-3.2.0
Data Size: 4156048 Bytes = 4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
Starting kernel …
[ 0.000000] Linux version 3.2.0 (root@Kims) (gcc version 4.8.2 20131014 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2013.10 - Linaro GCC 2013.10) ) #1 Sat Mar 29 16:14:25 KST 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES2.0 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait fixrtc ip=off
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 249972k/249972k available, 12172k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc078d000 (7700 kB)
[ 0.000000] .init : 0xc078d000 - 0xc07e3000 ( 344 kB)
[ 0.000000] .data : 0xc07e4000 - 0xc084eef0 ( 428 kB)
[ 0.000000] .bss : 0xc084ef14 - 0xc09a6cd0 (1376 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000061] Calibrating delay loop… 996.14 BogoMIPS (lpj=4980736)
[ 0.089233] pid_max: default: 32768 minimum: 301
[ 0.089324] Security Framework initialized
[ 0.089385] Mount-cache hash table entries: 512
[ 0.089721] CPU: Testing write buffer coherency: ok
[ 0.089752] ftrace: allocating 22377 entries in 66 pages
[ 0.144866] omap_hwmod: pruss: failed to hardreset
[ 0.145507] print_constraints: dummy:
[ 0.145690] NET: Registered protocol family 16
[ 0.146545] OMAP GPIO hardware version 0.1
[ 0.147369] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.148223] omap_i2c.1: alias fck already exists
[ 0.148651] omap2_mcspi.1: alias fck already exists
[ 0.148742] omap2_mcspi.2: alias fck already exists
[ 0.148834] edma.0: alias fck already exists
[ 0.148864] edma.0: alias fck already exists
[ 0.156341] bio: create slab at 0
[ 0.157073] SCSI subsystem initialized
[ 0.157745] usbcore: registered new interface driver usbfs
[ 0.157836] usbcore: registered new interface driver hub
[ 0.157928] usbcore: registered new device driver usb
[ 0.158172] registerd cppi-dma Intr @ IRQ 17
[ 0.158172] Cppi41 Init Done Qmgr-base(d087a000) dma-base(d0878000)
[ 0.158203] Cppi41 Init Done
[ 0.158203] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.158325] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.169219] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.169860] tps65910 1-002d: could not be detected
[ 0.170257] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.170684] Bluetooth: Core ver 2.16
[ 0.170745] NET: Registered protocol family 31
[ 0.170745] Bluetooth: HCI device and connection manager initialized
[ 0.170776] Bluetooth: HCI socket layer initialized
[ 0.170776] Bluetooth: L2CAP socket layer initialized
[ 0.170806] Bluetooth: SCO socket layer initialized
[ 0.170959] Switching to clocksource gp timer
[ 0.184814] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.184997] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.185150] MUSB0 controller’s USBSS revision = 4ea20800
[ 0.185150] musb0: Enabled SW babble control
[ 0.185821] musb-hdrc musb-hdrc.0: USB OTG mode controller at d083c000 using DMA, IRQ 18
[ 0.186035] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[ 0.186187] MUSB1 controller’s USBSS revision = 4ea20800
[ 0.186187] musb1: Enabled SW babble control
[ 0.186523] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.186614] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.186706] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.186737] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.186737] usb usb1: Product: MUSB HDRC host driver
[ 0.186737] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[ 0.186737] usb usb1: SerialNumber: musb-hdrc.1
[ 0.187133] hub 1-0:1.0: USB hub found
[ 0.187164] hub 1-0:1.0: 1 port detected
[ 0.187469] musb-hdrc musb-hdrc.1: USB Host mode controller at d083e800 using DMA, IRQ 19
[ 0.187744] NET: Registered protocol family 2
[ 0.187927] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.188232] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.188354] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.188415] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.188415] TCP reno registered
[ 0.188446] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.188446] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.188598] NET: Registered protocol family 1
[ 0.188842] RPC: Registered named UNIX socket transport module.
[ 0.188842] RPC: Registered udp transport module.
[ 0.188873] RPC: Registered tcp transport module.
[ 0.188873] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.189086] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.275299] ashmem: initialized
[ 0.275512] VFS: Disk quotas dquot_6.5.2
[ 0.275573] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.276245] fuse init (API version 7.17)
[ 0.276428] msgmni has been set to 488
[ 0.277221] io scheduler noop registered
[ 0.277221] io scheduler deadline registered
[ 0.277282] io scheduler cfq registered (default)
[ 0.277740] Could not set LED4 to fully on
[ 0.311645] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.930358] console [ttyO0] enabled
[ 0.934356] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.941986] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.949554] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 0.957153] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 0.964752] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 0.972473] [drm] Initialized drm 1.1.0 20060810
[ 0.981628] brd: module loaded
[ 0.987213] loop: module loaded
[ 0.990600] i2c-core: driver [tsl2550] using legacy suspend method
[ 0.997131] i2c-core: driver [tsl2550] using legacy resume method
[ 1.003540] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.081542] No daughter card found on AM335x EVM
[ 1.086395] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.101593] Board name: A335BNLT
[ 1.104949] Board version: 0A5A
[ 1.108276] The board is a AM335x Beaglebone Black.
[ 1.115051] tps65217 1-0024: TPS65217 ID 0xe version 1.2
[ 1.122314] print_constraints: DCDC1: 900 <–> 1800 mV at 1500 mV
[ 1.130462] print_constraints: DCDC2: 900 <–> 3300 mV at 1325 mV
[ 1.138671] print_constraints: DCDC3: 900 <–> 1500 mV at 1125 mV
[ 1.146850] print_constraints: LDO1: 1000 <–> 3300 mV at 1800 mV
[ 1.154998] print_constraints: LDO2: 900 <–> 3300 mV at 3300 mV
[ 1.163085] print_constraints: LDO3: 1800 <–> 3300 mV at 1800 mV
[ 1.171264] print_constraints: LDO4: 1800 <–> 3300 mV at 3300 mV
[ 1.180633] Maximum current provided by the USB port is 500mA which is not sufficient
[ 1.180633] when operating @OPP120, OPPTURBO and OPPNITRO. The current requirement for some
[ 1.180633] use-cases using OPP100 might also exceed the maximum current that the
[ 1.180664] USB port can provide. Unless you are fully confident that the current
[ 1.180664] requirements for OPP100 use-case don’t exceed the USB limits, switching
[ 1.180664] to AC power is recommended.
[ 1.225555] omap_hsmmc.0: alias fck already exists
[ 1.230804] omap_hsmmc.1: alias fck already exists
[ 1.236083] omap_i2c.3: alias fck already exists
[ 1.251586] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz
[ 1.257873] davinci-mcasp.0: alias fck already exists
[ 1.264434] at24 3-0054: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.271728] IN : bone_setup_display_daughter_board
[ 1.371551] No display cape found on BeagleBone
[ 1.376739] da8xx_lcdc.0: alias fck already exists
[ 1.382019] da8xx_lcdc da8xx_lcdc.0: GLCD: Found nxp-1280x720@60 panel
[ 1.533905] tda998x 1-0070: found TDA19988
[ 3.571594] tda998x 1-0070: failed to read EDID
[ 3.582092] Setup HDMI display complete
[ 3.586120] at24 3-0055: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 3.593414] IN : bone_setup_daughter_board
[ 3.691650] at24 3-0056: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 3.698913] IN : bone_setup_daughter_board
[ 3.781616] at24 3-0057: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 3.788909] IN : bone_setup_daughter_board
[ 3.871765] (hci_tty): inside hci_tty_init
[ 3.876190] (hci_tty): allocated 251, 0
[ 3.880279] NFC Driver for TI WiLink
[ 3.884582] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 3.891662] omap2-nand driver initializing
[ 3.895965] OneNAND driver initializing
[ 3.900360] CAN device driver interface
[ 3.904388] CAN bus driver for Bosch D_CAN controller 1.0
[ 3.951629] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 3.958099] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[ 3.965393] davinci_mdio.0: probed
[ 3.968963] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
[ 3.977600] PPP generic driver version 2.4.2
[ 3.982208] PPP BSD Compression module registered
[ 3.987121] PPP Deflate Compression module registered
[ 3.992523] usbcore: registered new interface driver cdc_ether
[ 3.998657] usbcore: registered new interface driver cdc_eem
[ 4.004638] usbcore: registered new interface driver dm9601
[ 4.010498] usbcore: registered new interface driver cdc_subset
[ 4.016723] cdc_ncm: 04-Aug-2011
[ 4.020141] usbcore: registered new interface driver cdc_ncm
[ 4.026123] usbcore: registered new interface driver cdc_acm
[ 4.032043] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 4.040435] Initializing USB Mass Storage driver…
[ 4.045623] usbcore: registered new interface driver usb-storage
[ 4.051910] USB Mass Storage support registered.
[ 4.056884] usbcore: registered new interface driver usbserial
[ 4.063018] USB Serial support registered for generic
[ 4.068359] usbcore: registered new interface driver usbserial_generic
[ 4.075195] usbserial: USB Serial Driver core
[ 4.079772] USB Serial support registered for GSM modem (1-port)
[ 4.086151] usbcore: registered new interface driver option
[ 4.092010] option: v0.7.2:USB Driver for GSM modems
[ 4.098449] gadget: Mass Storage Function, version: 2009/09/11
[ 4.104675] gadget: Number of LUNs=1
[ 4.108520] lun0: LUN: removable file: (no medium)
[ 4.113800] gadget: android_usb ready
[ 4.117736] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 4.123352] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 4.131195] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.138305] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.145874] usb usb2: Product: MUSB HDRC host driver
[ 4.151062] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[ 4.156616] usb usb2: SerialNumber: musb-hdrc.0
[ 4.161743] hub 2-0:1.0: USB hub found
[ 4.165679] hub 2-0:1.0: 1 port detected
[ 4.170288] mousedev: PS/2 mouse device common for all mice
[ 4.177032] using rtc device, am33xx-rtc, for alarms
[ 4.182128] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0
[ 4.189392] i2c /dev entries driver
[ 4.193298] Linux video capture interface: v2.00
[ 4.198394] usbcore: registered new interface driver uvcvideo
[ 4.204406] USB Video Class driver (1.1.1)
[ 4.482269] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 4.488769] device-mapper: uevent: version 1.0.3
[ 4.493774] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 4.502593] Bluetooth: HCI UART driver ver 2.2
[ 4.507263] Bluetooth: HCI H4 protocol initialized
[ 4.512268] Bluetooth: HCILL protocol initialized
[ 4.517181] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 4.599884] cpuidle: using governor ladder
[ 4.604583] cpuidle: using governor menu
[ 4.613769] usbcore: registered new interface driver usbhid
[ 4.619659] usbhid: USB HID core driver
[ 4.624877] logger: created 256K log ‘log_main’
[ 4.629913] logger: created 256K log ‘log_events’
[ 4.635192] logger: created 256K log ‘log_radio’
[ 4.640289] logger: created 256K log ‘log_system’
[ 4.646362] usbcore: registered new interface driver snd-usb-audio
[ 4.656799] asoc: am335x-hdmi-hifi <-> davinci-mcasp.0 mapping ok
[ 4.664764] ALSA device list:
[ 4.667907] #0: AM335X BONE
[ 4.671020] oprofile: hardware counters not available
[ 4.676391] oprofile: using timer interrupt.
[ 4.681152] Netfilter messages via NETLINK v0.30.
[ 4.686340] nf_conntrack version 0.5.0 (3905 buckets, 15620 max)
[ 4.693298] ctnetlink v0.93: registering with nfnetlink.
[ 4.699005] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 4.706359] NF_TPROXY: Copyright © 2006-2007 BalaBit IT Ltd.
[ 4.713134] xt_time: kernel timezone is -0000
[ 4.718109] ip_tables: © 2000-2006 Netfilter Core Team
[ 4.724182] arp_tables: © 2002 David S. Miller
[ 4.729156] TCP cubic registered
[ 4.732940] NET: Registered protocol family 10
[ 4.739135] Mobile IPv6
[ 4.741882] ip6_tables: © 2000-2006 Netfilter Core Team
[ 4.747955] IPv6 over IPv4 tunneling driver
[ 4.753631] NET: Registered protocol family 17
[ 4.758361] NET: Registered protocol family 15
[ 4.763092] can: controller area network core (rev 20090105 abi 8)
[ 4.769805] NET: Registered protocol family 29
[ 4.774536] can: raw protocol (rev 20090105)
[ 4.779052] can: broadcast manager protocol (rev 20090105 t)
[ 4.786376] Bluetooth: RFCOMM TTY layer initialized
[ 4.791564] Bluetooth: RFCOMM socket layer initialized
[ 4.797027] Bluetooth: RFCOMM ver 1.11
[ 4.800964] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.806579] Bluetooth: BNEP filters: protocol multicast
[ 4.812103] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.818634] Registering the dns_resolver key type
[ 4.823699] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 4.831848] ThumbEE CPU extension supported.
[ 4.836425] mux: Failed to setup hwmod io irq -22
[ 4.842742] Power Management for AM33XX family
[ 4.847717] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[ 4.854492] Copied the M3 firmware to UMEM
[ 4.858917] Cortex M3 Firmware Version = 0x181
[ 4.870422] clock: disabling unused clocks to save power
[ 4.878692] Detected MACID=c8:a0:30:ae:cb:b5
[ 4.885528] omap_rtc am33xx-rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 4.895477] Waiting for root device /dev/mmcblk0p2…
[ 4.974456] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 4.986175] mmc0: new high speed SDHC card at address e624
[ 4.992889] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 4.999847] mmcblk0: p1 p2
[ 5.061126] EXT4-fs (mmcblk0p2): recovery complete
[ 5.068176] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.076873] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 5.084350] Freeing init memory: 344K
INIT: version 2.88 booting
[ 5.479858] mmc1: new high speed MMC card at address 0001
[info] Using makefile-style concurrent boot in runlevel S (frog).
[ 5.501281] mmcblk1: mmc1:0001 MMC02G 1.78 GiB
[ 5.506713] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 5.514953] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 5.527618] mmcblk1: p1 p2
[ 5.538665] mmcblk1boot1: unknown partition table
[ 5.554077] mmcblk1boot0: unknown partition table
[…] Starting the hotplug events dispatcher: udevd. ok
[…] Synthesizing the initial hotplug events…done.
[…] Waiting for /dev to be fully populated…done.
[ 10.121063] Unable to handle kernel paging request at virtual address 5c5c5c94
[ 10.128814] pgd = c0004000
[ 10.131683] [5c5c5c94] *pgd=00000000
[ 10.135498] Internal error: Oops: 5 [#1]
[ 10.139617] Modules linked in:
[ 10.142852] CPU: 0 Not tainted (3.2.0 #1)
[ 10.147460] PC is at jbd2_journal_commit_transaction+0xa50/0x16bc
[ 10.153900] LR is at jbd2_journal_put_journal_head+0xd8/0x140
[ 10.159942] pc : [] lr : [] psr: a0000013
[ 10.159973] sp : cf3adea8 ip : cf3ade90 fp : cf3adf74
[ 10.172027] r10: 00000000 r9 : 5c5c5c5c r8 : ce92d948
[ 10.177520] r7 : 00000000 r6 : ce931808 r5 : cf37a800 r4 : cf325cc0
[ 10.184387] r3 : 5c5c5c94 r2 : 00000001 r1 : 00000000 r0 : ce92d948
[ 10.191253] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 10.198944] Control: 10c5387d Table: 8e170019 DAC: 00000015
[ 10.204986]
[ 10.205017] PC: 0xc01a8f98:
[ 10.209503] 8f98 e5933028 e3130301 1a0001dc e3570000 1a0001e3 e51b9088 e5d93000 e3530002
[ 10.218170] 8fb8 8a000230 e5943034 e1560003 1a0002a3 e5943018 e3530000 1a00029f e5943020
[ 10.226806] 8fd8 e3530000 1a000209 e5943028 e3530000 1a000312 e594302c e3530000 1a00030e
[ 10.235473] 8ff8 e5943030 e3530000 1a00030a e594601c e3560000 0a0000f5 e5969000 e2893038
[ 10.244140] 9018 e1932f9f e2822001 e1831f92 e3310000 1afffffa e596301c e1540003 03a07000
[ 10.252807] 9038 02858e1d 0a000033 ea0001eb e1a0000a e5991018 eb001ad9 e5963014 e5867018
[ 10.261474] 9058 e3530000 15863018 15867014 1586703c e596302c e3530000 0a000004 e5932050
[ 10.270111] 9078 e1a00006 e2822001 e5832050 eb0007c3 e5993000 e3130801 0a000002 e5963020
[ 10.278778]
[ 10.278808] LR: 0xc01aff3c:
[ 10.283294] ff3c 1a000022 e594302c e3530000 1a000020 e5943008 e3530000 1a00001e e5953000
[ 10.291961] ff5c e3130901 0a00001c e5943000 e1550003 1a00001a e5943014 e3530000 1a000018
[ 10.300628] ff7c e5943018 e3530000 1a00001d e3a03000 e5853028 e5843000 e10f3000 f10c0080
[ 10.309265] ff9c e5952000 e3c22901 e5852000 e121f003 e1a00004 ebfff818 e1a00005 ebfd44c8
[ 10.317932] ffbc e89da830 e7f001f2 e7f001f2 e7f001f2 e7f001f2 e7f001f2 e7f001f2 e7f001f2
[ 10.326599] ffdc e7f001f2 e30f0c00 e59f1034 e34c006f eb0fe024 e5940014 e5951018 ebfffeee
[ 10.335266] fffc eaffffde e30f0c20 e59f1014 e34c006f eb0fe01c e5940018 e5951018 ebfffee6
[ 10.343933] 001c eaffffd9 c05d20c0 e1a0c00d e92ddff0 e24cb004 e24dd034 e52de004 e8bd4000
[ 10.352600]
[ 10.352600] SP: 0xcf3ade28:
[ 10.357086] de28 c05acc24 c0062c14 00000002 ce92d948 00000000 c01a9018 a0000013 ffffffff
[ 10.365753] de48 cf3ade94 ce92d948 cf3adf74 cf3ade60 c05aded8 c000837c ce92d948 00000000
[ 10.374420] de68 00000001 5c5c5c94 cf325cc0 cf37a800 ce931808 00000000 ce92d948 5c5c5c5c
[ 10.383056] de88 00000000 cf3adf74 cf3ade90 cf3adea8 c01affbc c01a9018 a0000013 ffffffff
[ 10.391723] dea8 00068030 00000000 58609834 00000002 00000000 c01a8240 cf3adf0c c080eab8
[ 10.400390] dec8 cf3a7800 00000008 00000e6c c07ed200 c08893f0 cf325cc0 00000000 ffffffff
[ 10.409057] dee8 c0bf8194 c07e6968 58609834 00000002 cea556c8 ce92d948 00068030 00000000
[ 10.417694] df08 c05afb88 91827364 cf3adf10 cf3adf10 cf3adf18 cf3adf18 00000000 c003c338
[ 10.426361]
[ 10.426391] IP: 0xcf3ade10:
[ 10.430877] de10 cf3ade2c cf3ade20 c00ffb20 c05acc24 cf3ade54 cf3ade30 c05acc24 c0062c14
[ 10.439514] de30 00000002 ce92d948 00000000 c01a9018 a0000013 ffffffff cf3ade94 ce92d948
[ 10.448181] de50 cf3adf74 cf3ade60 c05aded8 c000837c ce92d948 00000000 00000001 5c5c5c94
[ 10.456848] de70 cf325cc0 cf37a800 ce931808 00000000 ce92d948 5c5c5c5c 00000000 cf3adf74
[ 10.465515] de90 cf3ade90 cf3adea8 c01affbc c01a9018 a0000013 ffffffff 00068030 00000000
[ 10.474151] deb0 58609834 00000002 00000000 c01a8240 cf3adf0c c080eab8 cf3a7800 00000008
[ 10.482818] ded0 00000e6c c07ed200 c08893f0 cf325cc0 00000000 ffffffff c0bf8194 c07e6968
[ 10.491485] def0 58609834 00000002 cea556c8 ce92d948 00068030 00000000 c05afb88 91827364
[ 10.500152]
[ 10.500152] FP: 0xcf3adef4:
[ 10.504638] def4 00000002 cea556c8 ce92d948 00068030 00000000 c05afb88 91827364 cf3adf10
[ 10.513305] df14 cf3adf10 cf3adf18 cf3adf18 00000000 c003c338 00000000 000001f4 00000000
[ 10.521972] df34 00000000 ffff8ebf c0052524 0000002f 00000030 c0052524 cf37a800 c07e6968
[ 10.530639] df54 cf37aa00 c080eab8 cf37a840 cf3ac038 cf37a850 cf3adfbc cf3adf78 c01addbc
[ 10.539306] df74 c01a85d4 cf3ac030 00000000 cf32d740 c0062de8 cf3adf88 cf3adf88 00000013
[ 10.547943] df94 cf069c3c cf37a800 c01adcf8 00000013 00000000 00000000 00000000 cf3adff4
[ 10.556610] dfb4 cf3adfc0 c0062708 c01add04 cf069c3c 00000000 cf37a800 00000000 cf3adfd0
[ 10.565277] dfd4 cf3adfd0 00000000 cf069c3c c0062670 c0047b78 00000000 cf3adff8 c0047b78
[ 10.573944]
[ 10.573944] R0: 0xce92d8c8:
[ 10.578430] d8c8 00000029 ce92d8c8 c0ba6ac0 00000000 00068033 00000000 00001000 cffd6000
[ 10.587097] d8e8 ce802c80 c00ffc08 00000000 ce92d8f4 ce92d8f4 00000000 00000000 00000000
[ 10.595764] d908 00000029 ce92d908 c0ba6aa0 00000000 00068032 00000000 00001000 cffd5000
[ 10.604431] d928 ce802c80 c00ffc08 00000000 ce92d934 ce92d934 00000000 00000000 00000000
[ 10.613098] d948 00000029 ce92d948 c0ba6a80 00000000 00068031 00000000 00001000 cffd4000
[ 10.621765] d968 ce802c80 c01a8240 00000000 ce92d974 ce92d974 00000000 00000001 00000000
[ 10.630432] d988 00000029 ce92d988 c0ba6a60 00000000 00068030 00000000 00001000 cffd3000
[ 10.639099] d9a8 ce802c80 c00ffc08 00000000 ce92d9b4 ce92d9b4 00000000 00000000 00000000
[ 10.647735]
[ 10.647766] R4: 0xcf325c40:
[ 10.652252] 5c40 ffff8ebf 00000000 00000000 00000000 00000000 00000001 00000004 00000000
[ 10.660919] 5c60 00000000 ffff90b3 58a75fba 00000002 00000004 00000000 00000000 cf325c7c
[ 10.669586] 5c80 cf325c7c 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.678222] 5ca0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.686889] 5cc0 cf37a800 00000056 00000005 00000001 00000000 00000000 00000000 ce931808
[ 10.695526] 5ce0 00000000 00000000 00000000 00000000 00000000 cf325cf4 cf325cf4 00000000
[ 10.704193] 5d00 ffff8ccb 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.712860] 5d20 00000000 ffff8ebf 2eb63b75 00000001 000008e3 00000000 00000001 ce93c3f4
[ 10.721496]
[ 10.721527] R5: 0xcf37a780:
[ 10.726013] a780 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.734649] a7a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.743316] a7c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.751983] a7e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.760620] a800 00000030 00000000 ce9299c8 c0bf7000 00000002 00000000 00000001 cf37a81c
[ 10.769287] a820 cf37a81c cf325c00 cf325cc0 00000000 cf37a830 cf37a830 cf37a838 cf37a838
[ 10.777954] a840 cf37a840 cf37a840 cf37a848 cf37a848 cf37a850 cf37a850 cf37a858 cf37a858
[ 10.786621] a860 00000001 cf37a864 cf37a864 00000000 00000000 00000000 00000000 00000000
[ 10.795288]
[ 10.795288] R6: 0xce931788:
[ 10.799774] 1788 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 10.808441] 17a8 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 10.817077] 17c8 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 10.825744] 17e8 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 10.834411] 1808 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 10.843078] 1828 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 10.851745] 1848 ce929f88 00000001 00000002 00000001 00000000 00000000 00000000 cf325cc0
[ 10.860412] 1868 00000000 ce931888 ce931808 00000000 00000000 00000000 00000000 00000000
[ 10.869079]
[ 10.869079] R8: 0xce92d8c8:
[ 10.873565] d8c8 00000029 ce92d8c8 c0ba6ac0 00000000 00068033 00000000 00001000 cffd6000
[ 10.882232] d8e8 ce802c80 c00ffc08 00000000 ce92d8f4 ce92d8f4 00000000 00000000 00000000
[ 10.890899] d908 00000029 ce92d908 c0ba6aa0 00000000 00068032 00000000 00001000 cffd5000
[ 10.899566] d928 ce802c80 c00ffc08 00000000 ce92d934 ce92d934 00000000 00000000 00000000
[ 10.908203] d948 00000029 ce92d948 c0ba6a80 00000000 00068031 00000000 00001000 cffd4000
[ 10.916870] d968 ce802c80 c01a8240 00000000 ce92d974 ce92d974 00000000 00000001 00000000
[ 10.925506] d988 00000029 ce92d988 c0ba6a60 00000000 00068030 00000000 00001000 cffd3000
[ 10.934173] d9a8 ce802c80 c00ffc08 00000000 ce92d9b4 ce92d9b4 00000000 00000000 00000000
[ 10.942840] Process jbd2/mmcblk0p2- (pid: 49, stack limit = 0xcf3ac2f0)
[ 10.949798] Stack: (0xcf3adea8 to 0xcf3ae000)
[ 10.954406] dea0: 00068030 00000000 58609834 00000002 00000000 c01a8240
[ 10.963012] dec0: cf3adf0c c080eab8 cf3a7800 00000008 00000e6c c07ed200 c08893f0 cf325cc0
[ 10.971618] dee0: 00000000 ffffffff c0bf8194 c07e6968 58609834 00000002 cea556c8 ce92d948
[ 10.980224] df00: 00068030 00000000 c05afb88 91827364 cf3adf10 cf3adf10 cf3adf18 cf3adf18
[ 10.988861] df20: 00000000 c003c338 00000000 000001f4 00000000 00000000 ffff8ebf c0052524
[ 10.997467] df40: 0000002f 00000030 c0052524 cf37a800 c07e6968 cf37aa00 c080eab8 cf37a840
[ 11.006072] df60: cf3ac038 cf37a850 cf3adfbc cf3adf78 c01addbc c01a85d4 cf3ac030 00000000
[ 11.014709] df80: cf32d740 c0062de8 cf3adf88 cf3adf88 00000013 cf069c3c cf37a800 c01adcf8
[ 11.023315] dfa0: 00000013 00000000 00000000 00000000 cf3adff4 cf3adfc0 c0062708 c01add04
[ 11.031921] dfc0: cf069c3c 00000000 cf37a800 00000000 cf3adfd0 cf3adfd0 00000000 cf069c3c
[ 11.040557] dfe0: c0062670 c0047b78 00000000 cf3adff8 c0047b78 c006267c dfdcef77 b7fcff5d
[ 11.049163] Backtrace:
[ 11.051757] [] (jbd2_journal_commit_transaction+0x0/0x16bc) from [] (kjournald2+0xc4/0x320)
[ 11.062438] [] (kjournald2+0x0/0x320) from [] (kthread+0x98/0x9c)
[ 11.070678] [] (kthread+0x0/0x9c) from [] (do_exit+0x0/0x6c0)
[ 11.078552] r6:c0047b78 r5:c0062670 r4:cf069c3c
[ 11.083435] Code: e3560000 0a0000f5 e5969000 e2893038 (e1932f9f)
[ 11.089965] —[ end trace c352c158df0ceae4 ]—
[ 11.096832] ------------[ cut here ]------------
[ 11.101715] kernel BUG at fs/jbd2/transaction.c:678!
[ 11.106933] Internal error: Oops - undefined instruction: 0 [#2]
[ 11.113250] Modules linked in:
[ 11.116485] CPU: 0 Tainted: G D (3.2.0 #1)
[ 11.122100] PC is at do_get_write_access+0x2a4/0x43c
[ 11.127319] LR is at 0x5c5c5c5c
[ 11.130615] pc : [] lr : [<5c5c5c5c>] psr: 20000013
[ 11.130645] sp : ce197c10 ip : ce197be8 fp : ce197c64
[ 11.142700] r10: c0062e2c r9 : ce931808 r8 : cf37a800
[ 11.148193] r7 : ce92d948 r6 : 00000000 r5 : ce9303f8 r4 : cf325c00
[ 11.155059] r3 : 5c5c5c5c r2 : 00000000 r1 : 5c5c5c5c r0 : c0ba7728
[ 11.161956] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 11.169647] Control: 10c5387d Table: 8e318019 DAC: 00000015
[ 11.175689]
[ 11.175689] PC: 0xc01a73ec:
[ 11.180175] 73ec e1a07000 ea000000 eb10145c e1a00007 e24b1044 e3a02002 ebfaedcd e5993008
[ 11.188842] 740c e3530004 0afffff7 e1a00007 e24b1044 ebfaedf9 eaffff85 e3e0a01d e3560000
[ 11.197509] 742c 01a0000a 1a000061 e24bd028 e89daff0 e24bd028 e3e0001d e89daff0 e1a0a002
[ 11.206146] 744c e1a00005 e1a01009 eb0012c7 eafffff2 e35e0000 05894020 01a0a00e 0afffff7
[ 11.214813] 746c e7f001f2 e35e0000 1a000060 e1a01004 e1a00009 e3a02006 e1a0a00e ebfffecf
[ 11.223480] 748c eaffffee e5992000 e5896014 e5894020 e5923000 e3130001 0a000049 e1a0300d
[ 11.232147] 74ac e592101c e3c34d7f e5926008 e3c4303f e5932004 e7eb1051 e2822001 e5832004
[ 11.240814] 74cc e30d2200 e30933f0 e34c207e e34c3088 e5922000 e593e000 e5990038 e5993000
[ 11.249450]
[ 11.249481] SP: 0xce197b90:
[ 11.253967] 7b90 00000000 5c5c5c5c cf325c00 ce9303f8 00000000 ce92d948 cf37a800 ce931808
[ 11.262634] 7bb0 c0062e2c ce197c64 ce197be8 ce197c10 5c5c5c5c c01a746c 20000013 ffffffff
[ 11.271270] 7bd0 ce92d948 00000002 ce197bfc ce197be8 c0062de4 c0062d80 cf325c00 ce9303f8
[ 11.279937] 7bf0 ce197c0c ce197c00 c00ffba8 c0062dc4 ce197c64 ce197c10 c01a72ec c00ffb80
[ 11.288604] 7c10 ce196000 00000000 ce93a588 00000016 00000000 ce2ce380 c0062e2c ce197c2c
[ 11.297271] 7c30 ce197c2c ce197c40 c0163fa4 ce931808 ce9303f8 ce93a588 c05ccf60 0000116d
[ 11.305908] 7c50 ce197e20 ce0ccf40 ce197c7c ce197c68 c01a7638 c01a71d4 00000000 ce9303f8
[ 11.314575] 7c70 ce197cac ce197c80 c018c8dc c01a7610 ce197cbc ce9303f8 cea1f0c0 00000000
[ 11.323242]
[ 11.323242] IP: 0xce197b68:
[ 11.327728] 7b68 20000013 c05ae214 00000000 e7100000 ce197c64 ce197b88 c05adfa8 c000820c
[ 11.336395] 7b88 c0ba7728 5c5c5c5c 00000000 5c5c5c5c cf325c00 ce9303f8 00000000 ce92d948
[ 11.345062] 7ba8 cf37a800 ce931808 c0062e2c ce197c64 ce197be8 ce197c10 5c5c5c5c c01a746c
[ 11.353698] 7bc8 20000013 ffffffff ce92d948 00000002 ce197bfc ce197be8 c0062de4 c0062d80
[ 11.362365] 7be8 cf325c00 ce9303f8 ce197c0c ce197c00 c00ffba8 c0062dc4 ce197c64 ce197c10
[ 11.371032] 7c08 c01a72ec c00ffb80 ce196000 00000000 ce93a588 00000016 00000000 ce2ce380
[ 11.379699] 7c28 c0062e2c ce197c2c ce197c2c ce197c40 c0163fa4 ce931808 ce9303f8 ce93a588
[ 11.388336] 7c48 c05ccf60 0000116d ce197e20 ce0ccf40 ce197c7c ce197c68 c01a7638 c01a71d4
[ 11.397003]
[ 11.397003] FP: 0xce197be4:
[ 11.401489] 7be4 c0062d80 cf325c00 ce9303f8 ce197c0c ce197c00 c00ffba8 c0062dc4 ce197c64
[ 11.410156] 7c04 ce197c10 c01a72ec c00ffb80 ce196000 00000000 ce93a588 00000016 00000000
[ 11.418823] 7c24 ce2ce380 c0062e2c ce197c2c ce197c2c ce197c40 c0163fa4 ce931808 ce9303f8
[ 11.427490] 7c44 ce93a588 c05ccf60 0000116d ce197e20 ce0ccf40 ce197c7c ce197c68 c01a7638
[ 11.436126] 7c64 c01a71d4 00000000 ce9303f8 ce197cac ce197c80 c018c8dc c01a7610 ce197cbc
[ 11.444793] 7c84 ce9303f8 cea1f0c0 00000000 cea1f0c0 ce197cdc ce9303f8 cf373200 ce197ccc
[ 11.453460] 7ca4 ce197cb0 c0167f20 c018c8a8 ce9303f8 cea1f0c0 c016a35c ce9303f8 ce197d0c
[ 11.462097] 7cc4 ce197cd0 c0167f98 c0167ebc 00000041 0000ddee 00000000 ce93a588 00000600
[ 11.470764]
[ 11.470794] R0: 0xc0ba76a8:
[ 11.475280] 76a8 c0ba76a8 c0ba76a8 c0ba76b0 c0ba76b0 c0ba76b8 c0ba76b8 c0ba76c0 c0ba76c0
[ 11.483947] 76c8 c0ba76c8 c0ba76c8 c0ba76d0 c0ba76d0 c0ba76d8 c0ba76d8 c0ba76e0 c0ba76e0
[ 11.492584] 76e8 c0ba76e8 c0ba76e8 c0ba76f0 c0ba76f0 c0ba76f8 c0ba76f8 c0ba7700 c0ba7700
[ 11.501251] 7708 c0ba7708 c0ba7708 c0ba7710 c0ba7710 c0ba7718 c0ba7718 c0ba7720 c0ba7720
[ 11.509918] 7728 c0ba7728 c0ba7728 c0ba7730 c0ba7730 c0ba7738 c0ba7738 c0ba7740 c0ba7740
[ 11.518554] 7748 c0ba7748 c0ba7748 c0ba7750 c0ba7750 c0ba7758 c0ba7758 c0ba7760 c0ba7760
[ 11.527221] 7768 c0ba7768 c0ba7768 c0ba7770 c0ba7770 c0ba7778 c0ba7778 c0ba7780 c0ba7780
[ 11.535888] 7788 c0ba7788 c0ba7788 c0ba7790 c0ba7790 c0ba7798 c0ba7798 c0ba77a0 c0ba77a0
[ 11.544555]
[ 11.544555] R4: 0xcf325b80:
[ 11.549041] 5b80 507fdf5c fbaffdbe cff8efb8 ebbafff4 bbededfd efbff8fd f76f9fef c7ff6fff
[ 11.557708] 5ba0 77a5ff7e fe83f77f ff86fdd5 7df3fdff f5f8bef7 d8dcb6f6 5fd8eabf 5ffdffbc
[ 11.566375] 5bc0 fffbbe09 7fe0e547 d4cded35 844ddd7d f32f7bfd 9ced7bf5 768fe777 a7dff67f
[ 11.575042] 5be0 693dfe7f cebfffba fbbd6def a7ffc6ab fff716bf 1fdb4f9e c597fa3b efeffabe
[ 11.583709] 5c00 cf37a800 00000057 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.592376] 5c20 00000000 00000000 00000000 00000000 00000000 cf325c34 cf325c34 00000000
[ 11.601013] 5c40 ffff8ebf 00000000 00000000 00000000 00000000 00000001 00000004 00000000
[ 11.609680] 5c60 00000000 ffff90b3 58a75fba 00000002 00000004 00000000 00000000 cf325c7c
[ 11.618316]
[ 11.618347] R5: 0xce930378:
[ 11.622833] 0378 2c301000 5c010800 04000100 22012200 53008420 08008480 04080100 04c00000
[ 11.631469] 0398 00200008 05000048 00020680 00040040 00044080 08044000 04440140 00461002
[ 11.640136] 03b8 00008120 00000400 40008008 00418020 24440100 08010004 0a012240 00010391
[ 11.648803] 03d8 8e112100 0c110190 00200004 00840002 80444c10 00000011 c0104040 06031164
[ 11.657470] 03f8 cf325c00 00000002 00000001 00000000 00000000 00000000 00000000 00000000
[ 11.666137] 0418 00000000 00000000 00000000 00000000 cf325c00 00000002 00000000 00000000
[ 11.674774] 0438 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.683441] 0458 92040084 80801045 08000004 01001000 4602361e 04324512 00050022 80044420
[ 11.692108]
[ 11.692108] R7: 0xce92d8c8:
[ 11.696594] d8c8 00000029 ce92d8c8 c0ba6ac0 00000000 00068033 00000000 00001000 cffd6000
[ 11.705261] d8e8 ce802c80 c00ffc08 00000000 ce92d8f4 ce92d8f4 00000000 00000000 00000000
[ 11.713928] d908 00000029 ce92d908 c0ba6aa0 00000000 00068032 00000000 00001000 cffd5000
[ 11.722595] d928 ce802c80 c00ffc08 00000000 ce92d934 ce92d934 00000000 00000000 00000000
[ 11.731262] d948 00000029 ce92d948 c0ba6a80 00000000 00068031 00000000 00001000 cffd4000
[ 11.739929] d968 ce802c80 c01a8240 00000000 ce92d974 ce92d974 00000000 00000001 00000000
[ 11.748565] d988 00000029 ce92d988 c0ba6a60 00000000 00068030 00000000 00001000 cffd3000
[ 11.757232] d9a8 ce802c80 c00ffc08 00000000 ce92d9b4 ce92d9b4 00000000 00000000 00000000
[ 11.765899]
[ 11.765899] R8: 0xcf37a780:
[ 11.770385] a780 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.779052] a7a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.787719] a7c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.796386] a7e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.805023] a800 00000030 00000000 ce9299c8 c0bf7000 00000002 00000000 00000001 cf37a81c
[ 11.813690] a820 cf37a81c cf325c00 cf325cc0 00000000 cf37a830 cf37a830 cf37a838 cf37a838
[ 11.822357] a840 cf37a840 cf37a840 cf37a848 cf37a848 cf37a850 cf37a850 cf37a858 cf37a858
[ 11.831024] a860 00000001 cf37a864 cf37a864 00000000 00000000 00000000 00000000 00000000
[ 11.839691]
[ 11.839691] R9: 0xce931788:
[ 11.844177] 1788 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 11.852844] 17a8 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 11.861511] 17c8 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 11.870178] 17e8 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 11.878814] 1808 5c5c5c5c 5c5c5c5c 5c5c5c5c 00000000 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 11.887481] 1828 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c 5c5c5c5c
[ 11.896148] 1848 ce929f88 00000001 00000002 00000001 00000000 00000000 00000000 cf325cc0
[ 11.904815] 1868 00000000 ce931888 ce931808 00000000 00000000 00000000 00000000 00000000
[ 11.913482]
[ 11.913482] R10: 0xc0062dac:
[ 11.918060] 2dac ebff591e e24bd00c e89da800 e1a0c00d e92dd830 e24cb004 e52de004 e8bd4000
[ 11.926727] 2dcc e1a04001 e1a05000 ebffffa8 e1a01005 e1a02004 ebffffe3 e89da830 e1a0c00d
[ 11.935363] 2dec e92dd818 e24cb004 e52de004 e8bd4000 e1a04000 ebff6b8c e3500000 089da818
[ 11.944030] 2e0c e5942010 e284300c e594100c e5812004 e5821000 e584300c e5843010 e89da818
[ 11.952697] 2e2c e1a0c00d e92dd830 e24cb004 e52de004 e8bd4000 e1a0e000 e5104008 e5935000
[ 11.961334] 2e4c e1540005 0a000001 e3a00000 e89da830 e510e004 e593c004 e15e000c 1afffff9
[ 11.970001] 2e6c e35e0000 e28e501f e20ec01f b1a0e005 e1a0e2ce e794e10e e1a0cc3e e31c0001
[ 11.978668] 2e8c 1afffff0 ebffffd4 e89da830 e1a0c00d e92dd800 e24cb004 e52de004 e8bd4000
[ 11.987335] Process mountdevsubfs.s (pid: 400, stack limit = 0xce1962f0)
[ 11.994384] Stack: (0xce197c10 to 0xce198000)
[ 11.998962] 7c00: ce196000 00000000 ce93a588 00000016
[ 12.007568] 7c20: 00000000 ce2ce380 c0062e2c ce197c2c ce197c2c ce197c40 c0163fa4 ce931808
[ 12.016204] 7c40: ce9303f8 ce93a588 c05ccf60 0000116d ce197e20 ce0ccf40 ce197c7c ce197c68
[ 12.024810] 7c60: c01a7638 c01a71d4 00000000 ce9303f8 ce197cac ce197c80 c018c8dc c01a7610
[ 12.033416] 7c80: ce197cbc ce9303f8 cea1f0c0 00000000 cea1f0c0 ce197cdc ce9303f8 cf373200
[ 12.042053] 7ca0: ce197ccc ce197cb0 c0167f20 c018c8a8 ce9303f8 cea1f0c0 c016a35c ce9303f8
[ 12.050659] 7cc0: ce197d0c ce197cd0 c0167f98 c0167ebc 00000041 0000ddee 00000000 ce93a588
[ 12.059265] 7ce0: 00000600 00000000 00000000 ce9303f8 cea1f0c0 ce197d40 cea1f0c0 00000080
[ 12.067901] 7d00: ce197d24 ce197d10 c016a35c c0167f54 cea1f0c0 00000001 ce197d3c ce197d28
[ 12.076507] 7d20: c00f8824 c016a330 cea1f0c0 cf010200 ce197d64 ce197d40 c00ed200 c00f87f4
[ 12.085113] 7d40: 386d4386 29dbbd07 cea1f0c0 00000080 ce197e28 00001000 ce197e14 ce197d68
[ 12.093750] 7d60: c00a4740 c00ed110 00000004 40000013 00000000 c084cdac ce197e04 00000080
[ 12.102355] 7d80: 00080001 ce197e20 ffffffff ce197e28 00000000 00000000 00000000 00000000
[ 12.110961] 7da0: 00000001 00000000 00000080 ce0ccf80 00000000 00000001 ce197dd4 00000000
[ 12.119598] 7dc0: 00000080 00000000 cf7a5100 00000000 91827364 ce197dd4 ce197dd4 ce197ddc
[ 12.128204] 7de0: ce197ddc 00000000 c07e6700 ce0ccf40 fffffdee ce197f08 00000000 00000000
[ 12.136810] 7e00: ffffffff 00000001 ce197ed4 ce197e18 c00d616c c00a4254 00000000 00000000
[ 12.145416] 7e20: cf7a5080 00000080 c019de44 00000000 00000000 00000001 ffffffff ce0ccf40
[ 12.154022] 7e40: 00000000 00000000 00000000 00000000 ce2ce380 00000080 00000000 00000000
[ 12.162628] 7e60: 00000080 00000000 00000000 00000000 00000080 00000000 00000080 ce197f08
[ 12.171264] 7e80: ce197ed4 ce197e90 c00d650c c023908c ce328824 c0237534 ce0aef40 cf7a5080
[ 12.179870] 7ea0: ce197f14 ce197eb0 c0237534 ce0ccf40 cf7a5080 ce197f08 0002c3d8 0002c404
[ 12.188507] 7ec0: ce197fb0 00000001 ce197f04 ce197ed8 c00d6674 c00d60ac ffffffff 00000000
[ 12.197113] 7ee0: 00000000 ce196000 bf000000 cf3ab000 0002c3d8 0002c404 ce197f24 ce197f08
[ 12.205718] 7f00: c00db4e8 c00d65d8 00000000 00000000 cf7a5080 0000000b ce197f44 ce197f28
[ 12.214324] 7f20: c00db6a8 c00db4b0 cf7a5080 00000080 00000004 ce196008 ce197f84 ce197f48
[ 12.222961] 7f40: c00dcf04 c00db5bc c00dfbc8 cf7a5080 0002c3d8 00000000 0002c404 cf3ab000
[ 12.231567] 7f60: ce197fb0 0002c404 0002c3d8 c00138c8 ce196000 00000000 ce197fa4 ce197f88
[ 12.240173] 7f80: c00171fc c00dcd24 0002c3d8 00037224 0002c404 0000000b 00000000 ce197fa8
[ 12.248779] 7fa0: c0013660 c00171c4 0002c3d8 00037224 00037224 0002c3d8 0002c404 0000002f
[ 12.257385] 7fc0: 0002c3d8 00037224 0002c404 0000000b 0002c404 00000000 0002c3d8 000219cc
[ 12.266021] 7fe0: 0000000b beded064 4024bcb3 401f0f96 80000030 00037224 00000000 00000000
[ 12.274597] Backtrace:
[ 12.277221] [] (do_get_write_access+0x0/0x43c) from [] (jbd2_journal_get_write_access+0x34/0x48)
[ 12.288299] [] (jbd2_journal_get_write_access+0x0/0x48) from [] (__ext4_journal_get_write_access+0x40/0x80)
[ 12.300384] r5:ce9303f8 r4:00000000
[ 12.304168] [] (__ext4_journal_get_write_access+0x0/0x80) from [] (ext4_reserve_inode_write+0x70/0x98)
[ 12.315795] r8:cf373200 r7:ce9303f8 r6:ce197cdc r5:cea1f0c0 r4:00000000
[ 12.322906] [] (ext4_reserve_inode_write+0x0/0x98) from [] (ext4_mark_inode_dirty+0x50/0x1f0)
[ 12.333709] r7:ce9303f8 r6:c016a35c r5:cea1f0c0 r4:ce9303f8
[ 12.339721] [] (ext4_mark_inode_dirty+0x0/0x1f0) from [] (ext4_dirty_inode+0x38/0x50)
[ 12.349761] r8:00000080 r7:cea1f0c0 r6:ce197d40 r5:cea1f0c0 r4:ce9303f8
[ 12.356903] [] (ext4_dirty_inode+0x0/0x50) from [] (__mark_inode_dirty+0x3c/0x1d0)
[ 12.366668] r5:00000001 r4:cea1f0c0
[ 12.370483] [] (__mark_inode_dirty+0x0/0x1d0) from [] (touch_atime+0xfc/0x164)
[ 12.379913] r5:cf010200 r4:cea1f0c0
[ 12.383697] [] (touch_atime+0x0/0x164) from [] (generic_file_aio_read+0x4f8/0x774)
[ 12.393493] r6:00001000 r5:ce197e28 r4:00000080
[ 12.398406] [] (generic_file_aio_read+0x0/0x774) from [] (do_sync_read+0xcc/0x10c)
[ 12.408203] [] (do_sync_read+0x0/0x10c) from [] (vfs_read+0xa8/0x154)
[ 12.416809] [] (vfs_read+0x0/0x154) from [] (kernel_read+0x44/0x50)
[ 12.425231] r8:0002c404 r7:0002c3d8 r6:cf3ab000 r5:bf000000 r4:ce196000
[ 12.432342] [] (kernel_read+0x0/0x50) from [] (prepare_binprm+0xf8/0x124)
[ 12.441314] r5:0000000b r4:cf7a5080
[ 12.445098] [] (prepare_binprm+0x0/0x124) from [] (do_execve+0x1ec/0x2d4)
[ 12.454071] r4:ce196008
[ 12.456756] [] (do_execve+0x0/0x2d4) from [] (sys_execve+0x44/0x64)
[ 12.465209] [] (sys_execve+0x0/0x64) from [] (ret_fast_syscall+0x0/0x30)
[ 12.474060] r7:0000000b r6:0002c404 r5:00037224 r4:0002c3d8
[ 12.480072] Code: e35e0000 05894020 01a0a00e 0afffff7 (e7f001f2)
[ 12.486633] —[ end trace c352c158df0ceae5 ]—
[…] Activating swap…done.
