I can't boot with the microSD card of the BeagleBoard Black
Hi everybody !
I don’t manage to boot on the microSD card of my BeagleBone Black rev C3.
I followed a lecture on the internet to know how to work with the BBB. Here is what I’ve done :
I made 2 partitions on the microSD card :
I tried to boot with and without pressing the S2 button (boot switch) but I’ve never managed to boot with the microSD card. I followed a tutorial that told me to clear the onboard eMMC to boot from the microSD card. Now when I connect with a debug cable on the UART connectors I got this :
Capture d’écran du 2022-08-24 15-10-55
Anyone knows what can I do to make it work ?
I’ve searched for a solution for days on the forum and the internet but I didn’t find anything…
Thx !
Either use the official images as is, or contact the authors of that educational course…
Thx for your answer !
I managed to flash the onboard eMMC.
Does anyone know if there is some tutorials to flash the microSD card as well ? So that I can proceed in the mooc I was doing before getting stuck.
You can etcher.io to flash the default image to a microSD…
If you want to learn how everything was put together…
My write-up is here:
Thx for the URL. I’ll check this out tomorrow.
  • It may be a stupid question but do you think I can’t boot off the microsd card because it’s capacity is too big (128GB) ? I read it was best to use 8/16/32 GB sd cards but I don’t see why the BBB couldn’t use my 128GB microSD card. Moreover, I could use it to flash the onboard eMMC.
Easy, test grab the latest image..
using etcher.io flash it to a microSD and see if it boots..
If it doesn’t, then your 128GB microSD won’t work..
It works with a 32GB microSD card so the problem was the microSD card size… It’s kind of strange since I could use the 128GB microSD card to flash the onboard eMMC !
