I have installed Angstrom on beaglebone.
Angstrom support systemd, but i want to run upstart.
How i can achieve it?
Tarun
Tarun
A similar question was asked on the yocto mailing lists:
https://lists.yoctoproject.org/pipermail/meta-freescale/2013-November/005525.html
You can look at the webos ports and try to pull it in, but given that you
asked the question I suspect it will be overly challenging for you.
Why not just run Ubuntu on your BeagleBone?
Please don’t consider this mere snark: I’m genuinely curious. Why would anyone want to use upstart? The war is over–systemd won. Upstart isn’t going to die right away, not least because it’s still in Ubuntu 14.04 LTS, but it will eventually. Why waste any more time on it?
