I am on the way of making a project showing that open source can be used for a lot of things in education.
And that you don’t always need S7, Danfoss…
The goal is to make a PLC with 8 digital inputs/outputs and analog input or I2C to read temperature/ humidity.
So I would need to make a cape which is connected to the GPIO’s of the BBB Rev A5C at startup and that starts-up a script at start-up.
On the web I have already found a lot of examples how to blink a LED or how to read the input.
Is there some guideline/project which could help me out a little bit concerning the hardware design (to make a cape)?
I would like to use optocouplers to connect directly to the GPIO pins.
For programming I would use Pybbio. Is this sufficient?
For the moment I am reading a lot of e-books on Python as I don’t have a lot experience with programming yet.
Thanks for your input, I will try to document the project online, so you can follow it.
I have recently designed an I/O cape for the BBB, had a prototype run of PCBs made, and built up two of them so far. The board has:
- 4 digital outputs (with LED indicators)
- 4 digital inputs (with LED indicators)
- 6 analogue inputs (somewhat configurable)
All the above are 5V tolerant but not optoisolated
- 12 more of the I/O pins are available on one header
- some of the special purpose lines available on another header (SPI, UART, etc)
- fitted with the specified EEPROM
- mix of surface mount and through hole - to make it easier to modify.
I have it working with a python driver and test program. Still trying to find time to finish off the project I originally designed it for but also wondering if there would be any interest out there for it.
