I'm working with the i2c2 from the beagle board, and I wrote a program
for user-space, the header used is "i2c-dev.h" from lm sensors.
The hardware I use requires the following:
Write:
Start->Chip address+write->Register address(msb)->Register address
(lsb)->Data to write->Stop
Read:
(lsb)->Chip address+read->Data to read->Stop
I'm using ioctl with I2C_RDWR, no error is shown, but the values read
doesn't match with the ones written(0x00 is alway read). Maybe I'm
missing something that is not allowing the correct i2c bus
communication.
The i2c2 bus was previously enabled.
The program acts this way:
1. Open file descriptor for i2c2
2. Bind I2C slave address(ioctl with I2C_SLAVE)
3. Write
4. Read
5. Close
Thanks for your help,
Ernesto
This is the code i'm using:
