I2C1
Can anybody with a green or black verify the odd behavior i am seeing on
my greens and blacks ?
I am using the latest IOT image
root@beaglebone:/home/debian# uname -r
4.9.78-ti-r94
I use i2ctools and issue the commands
root@beaglebone:/home/debian# i2cdetect -r 0
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0 using read byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- UU -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@beaglebone:/home/debian# i2cdetect -r 2
I will probe file /dev/i2c-2 using read byte commands.
Continue? [Y/n] y
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- UU UU UU UU -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
root@beaglebone:/home/debian# i2cdetect -r 1
I will probe file /dev/i2c-1 using read byte commands.
Continue? [Y/n] y
10: -- -- -- -- -- ^C
Doing the last command there ( i2cdetect -r 1 )
Its S L O W as heck. reading bus 0 or 2 is fast as it always has been.
This happens on a green or black and whether its just standalone or on
an expansion board.
I see this happen with the last 3 software versions
http://debian.beagleboard.org/images/bone-debian-9.3-iot-armhf-2018-01-28-4gb.img.xz
https://debian.beagleboard.org/images/bone-debian-9.2-iot-armhf-2017-10-10-4gb.img.xz
http://debian.beagleboard.org/images/bone-debian-9.1-lxqt-armhf-2017-08-31-4gb.img.xz
anything earlier and I2C1 is not enabled by default and not tested by me
