Hello I am trying to check if a Beaglebone AI is getting correctly I2S from a TIDA-1454 so if I try to arecord test.wav
I get:
debian@beaglebone:/etc$ arecord --device=“hw:1,0” -d 20 -f S16_LE test.wav
pcm_dsnoop.c:638:(snd_pcm_dsnoop_open) unable to open slave arecord:
main:828: audio open error: No such file or directory
The card is detected since i get this output from arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: PCM5102a [PCM5102a], device 0: davinci-mcasp.0-pcm5102a-hifi pcm5102a-hifi-0
Subdevices: 1/1
Subdevice #0: subdevice #0
or arecord -L
> debian@beaglebone:/var/lib/cloud9$ arecord -L
null Discard all samples (playback) or generate zero samples (capture) onboard onboard_capture_left onboard_playback_left onboard_capture_right onboard_playback_right plug_onboard_capture_left plug_onboard_playback_left default sysdefault:CARD=PCM5102a PCM5102a, Default Audio Device dmix:CARD=PCM5102a,DEV=0 PCM5102a, Direct sample mixing device dsnoop:CARD=PCM5102a,DEV=0 PCM5102a, Direct sample snooping device hw:CARD=PCM5102a,DEV=0 PCM5102a, Direct hardware device without any conversions plughw:CARD=PCM5102a,DEV=0 PCM5102a, Hardware device with all software conversions
and ALSA configuration:
pcm.onboard{
type hw
card 0
ctl.onboard {
type hw
card 0
}### Dsnoop splited channels pcm.onboard_capture_left { type dsnoop ipc_key 32 slave { pcm "onboard" channels 2 rate 48000 format S32_LE } bindings.0 0 } pcm.onboard_playback_left { type dmix ipc_key 33 slave { pcm "onboard" channels 2 } bindings.0 0 } pcm.onboard_capture_right { type dsnoop ipc_key 32 slave { pcm "onboard" channels 2 rate 48000 format S32_LE } bindings.0 1 } pcm.onboard_playback_right { type dmix ipc_key 33 slave { pcm "onboard" channels 2 } bindings.0 1 } ### PLUGS ## ### used with darkice ### device = plug:plug_onboard_left pcm.plug_onboard_capture_left{ type plug slave.pcm "onboard_capture_left" } pcm.plug_onboard_playback_left{ type plug slave.pcm "onboard_playback_left" } pcm.!default { type asym playback.pcm "plug_onboard_playback_left" capture.pcm "plug_onboard_capture_left" }
So what can it be the problem?
