I was building the Linux Kernel Source Code for 2.6.35, using the following steps:
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- distclean
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- omap3_beagle_defconfig
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- uImage
However, due to mkimage not installed, it could’nt generate the uImage. Now, i had
to download the u-boot source code and build it using the following steps to get mkimage binary:
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- omap3_beagle_config
Now mkimage binary got generated in /u-boot/tools/
and using the vmlinux generated after building the kernel, and following the steps, i generated the uImage
./mkimage -A arm -O linux -T kernel -C gzip -a 0x80008000 -e 80008000 -n “ARM Linux Kernel Image” -d linux.bin.gz uImage
and hence the uImage was generated.
The Kernel successfully boots up, however while executing an application having ARM Neon Intrinsics
in the source files, i am getting “Illegal Instruction” as error.
But, any previous kernel images of 2.6.35 which i havent built, works perfectly fine and executes the program
having ARM Neon Intrinsics without throwing any “Illegal Instruction” Error.
Wht is the cause of the issue…?
steps:
in the source files, i am getting "Illegal Instruction" as error.
having ARM Neon Intrinsics without throwing any "Illegal Instruction" Error.
Wht is the cause of the issue...?
steps:
In the config file omap3_beagle_defconfig, we dont have CONFIG_NEON flag. However, on
looking in the config file omap3_defconfig found the two flags CONFIG_NEON and
CONFIG_VFP. Hence, i copied these two flags in the omap3_beagle_defconfig config
file after which when i built the kernel following the above steps, i was able to execute
my application having ARM NEON Intrinsics. It WORKED…!!
Hence, thanks a lot Mans for helpin me in this regard. U did it…:))
