Hi All
I have to following problem. I’m trying to setup a custom cape with and SPI TPM based on SLB9670VQ2.0 chip.
What I’ve done so far is:
1 - building and deploying a custom kernel with SPI TPM 2.0 support enabled.
2 - Writing a dtbo to configure the right pins in their right modes for the TPM and to instruct the u-boot to load the specific kernel objects.
After many problems and a lot of research, I managed to to build the DTBO activate it by including uboot_overlay_addr5=/lib/firmware/TPM-SLB9670-00A0.dtbo in the /boot/uEnv.txt and making sure the DTBO is loaded and does it’s thing.
Now, the DTBO IS loading and causes the respective modules to be loaded:
ivan@beaglebone:~$ lsmod
Module Size Used by
8021q 32768 0
garp 16384 1 8021q
stp 16384 1 garp
mrp 20480 1 8021q
llc 16384 2 garp,stp
usb_f_acm 16384 2
u_serial 20480 3 usb_f_acm
usb_f_ecm 20480 2
usb_f_rndis 32768 4
u_ether 20480 2 usb_f_ecm,usb_f_rndis
libcomposite 61440 16 usb_f_ecm,usb_f_acm,usb_f_rndis
iptable_nat 16384 0
nf_nat_ipv4 16384 1 iptable_nat
nf_nat 36864 1 nf_nat_ipv4
nf_conntrack 155648 2 nf_nat_ipv4,nf_nat
nf_defrag_ipv6 20480 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
iptable_mangle 16384 0
iptable_filter 16384 0
tpm_tis_spi 16384 0
tpm_tis_core 24576 1 tpm_tis_spi
tpm 57344 2 tpm_tis_spi,tpm_tis_core
uio_pdrv_genirq 16384 0
uio 20480 1 uio_pdrv_genirq
ip_tables 24576 3 iptable_mangle,iptable_filter,iptable_nat
x_tables 32768 3 iptable_mangle,ip_tables,iptable_filter
While researching, I was led to believe that the modules would create the “all-important” device file in the /dev directory, i.e. /dev/tpm0
But that doesn’t happen?!
I tried modifying the dts file for my dtbo in every way I could imagine. It doesn’t work.
This is the complete dts file for my TPM dtbo:
- Device Tree overlay for Infineon SLx 9670
#include <dt-bindings/board/am335x-bbw-bbb-base.h>
#include <dt-bindings/interrupt-controller/irq.h>
#include <dt-bindings/pinctrl/am33xx.h>
#include <dt-bindings/gpio/gpio.h>
/dts-v1/;
/plugin/;
compatible = “ti,beaglebone”, “ti,beaglebone-black”;
/* Identification */
part-number = “TPM-SLB9670”;
version = “00A0”;
exclusive-use = “P9.21”, // Used as SPI0 MISO and is the Default +/
“P9.18”, // Used as SPI0 MOSI and is the Default +/
“P9.22”, // Used as SPI0 SCKL and is the Default +/
“P9.17”, // Used as SPI0 CS0 +/
“P9.15”, // GPIO1_16 aka GPIO_48 used as input to handle the IRQ from the TPM.
“P9.13”, // GPIO0_31 aka GPIO_31 used as output to drive the reset pin of the TPM
“spi0”,
“i2c0”,
“i2c2”;
fragment@0 // Releasing the spi0 pins from their current assignments. (Tried without this fragment no difference)
target = <&ocp>;
overlay
// P9_21_pinmux { status = “disabled”; };
// P9_18_pinmux { status = “disabled”; };
// P9_22_pinmux { status = “disabled”; };
// P9_17_pinmux { status = “disabled”; };
P9_15_pinmux { status = “disabled”; };
P9_13_pinmux { status = “disabled”; };
fragment@1 // Disabling both i2c interfaces since there are some pin conflicts, in the off chance they moght interfere (Tried without those two fragments - No difference)
target = <&i2c0>;
overlay
fragment@2
target = <&i2c2>;
overlay
fragment@3
target = <&am33xx_pinmux>;
overlay
pb_spi0_pins: pinmux_pb_spi0_pins // I checked if a got the right pins several times, tried with or without pullups no difference
{ // My only doubt is did I get the inputs anoutputs right?
pinctrl-single,pins = < BONE_P9_21 (PIN_INPUT_PULLUP | MUX_MODE0) // Used as SPI0 MISO +/
BONE_P9_18 (PIN_OUTPUT_PULLUP | MUX_MODE0) // Used as SPI0 MOSI +/
BONE_P9_22 (PIN_OUTPUT_PULLUP | MUX_MODE0) // Used as SPI0 SCKL +/
BONE_P9_17 (PIN_OUTPUT | MUX_MODE0)>; // Used as SPI0 CS0 (This pin has a physical pullup resistor) +/
// BONE_P9_15 (PIN_INPUT_PULLUP | MUX_MODE7) // Used as GPIO_48 for IRQ to TPM
// BONE_P9_13 (PIN_OUTPUT_PULLUP | MUX_MODE7)>; // Used as GPIO_31 for RST to TPM
fragment@4 // Every example I looked at has the spi configuring fragmet as separate form the actual TPM config fragmet even though they can be one…
{ // Here I assign the actual pins to the SPI interface and disable both channels since I want the TPM to be the active device rther than having spidev in /dev
target = <&spi0>;
overlay
pinctrl-names = “default”;
pinctrl-0 = <&pb_spi0_pins>;
status = “okay”;
#address-cells = <1>;
#size-cells = <0>;
channel@0
compatible = “spidev”;
reg = <0x0>;
spi-max-frequency = <32000000>;
channel@1
reg = <0x1>;
fragment@5 // The main fragment. Configuring the TPM. I did it as per the example given by those who wrote the SPI kernel modules.
{ // That’s how I managed to get the dtbo to load the actual modules. All my previous versions of this fragment failed to do that.
target = <&spi0>; // I did try wtihout the gpio interupt stuf but it didn’t work either.
overlay
#size-cells = <0>;
tpm_tis@0
compatible = “tcg,tpm_tis-spi”; // tcg,tpm_spi_tis,infineon,slb9670
status = “okay”;
#gpio-cells = <2>;
#interrupt-cells = <2>;
reg = <0x0>;
num-cs = <1>;
interrupt-parent = <&gpio1>;
interrupts = < 16 2>;
gpios = <&gpio1 16 GPIO_ACTIVE_LOW>, <&gpio0 31 GPIO_ACTIVE_LOW>;
dmesg gives no relevant information.
Thanks in advance and sorsy for long post
