I am getting following problem :
I am able to mount my partition but immediately after freeing init
memory ,it throws "untracked pid xx exited" messages. I am working on
gingerbread 2.3.4 and able to boot properly with android kernel 2.6.37
but the issue comes if I use android 2.6.39 kernel .
My log :
Linux version 2.6.39 (ee205754@pcb-ee205754) (gcc version 4.3.3
(Sourcery G++ L1
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction
cache
Machine: OMAP3 Beagle
Board
Ignoring tag cmdline (using the default kernel command
line)
Memory policy: ECC disabled, Data cache
writeback
OMAP3630 ES1.2 (l2cache iva sgx neon isp
192mhz_clk )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x10000
Clocking rate (Crystal/Core/MPU): 26.0/332/600
MHz
Reprogramming SDRC clock to 332000000
Hz
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
130048
Kernel command line: root=/dev/mmcblk0p2 rootwait init=/init
console=ttyO2,11520
PID hash table entries: 2048 (order: 1, 8192
bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144
bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072
bytes)
Memory: 512MB = 512MB
total
Memory: 512940k/512940k available, 11348k reserved, 0K
highmem
Virtual kernel memory
layout:
vector : 0xffff0000 - 0xffff1000 ( 4
kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896
kB)
DMA : 0xffc00000 - 0xffe00000 ( 2
MB)
vmalloc : 0xe0800000 - 0xf8000000 ( 376
MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512
MB)
modules : 0xbf000000 - 0xc0000000 ( 16
MB)
.init : 0xc0008000 - 0xc003c000 ( 208
kB)
.text : 0xc003c000 - 0xc0577000 (5356
kB)
.data : 0xc0578000 - 0xc05b40e0 ( 241
kB)
NR_IRQS:410 nr_irqs:410
410
IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupts
Total of 96 interrupts on 1 active
controller
omap_hwmod: gpt12_fck: missing clockdomain for
gpt12_fck.
OMAP clockevent source: GPTIMER12 at 32768
Hz
sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every
131071999ms
Console: colour dummy device
80x30
ram_console: buffer (null), invalid size 0, datasize
4294967284
Calibrating delay loop... 471.61 BogoMIPS
(lpj=1843200)
pid_max: default: 32768 minimum:
301
Security Framework
initialized
Mount-cache hash table entries:
512
CPU: Testing write buffer coherency:
ok
omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for
l4_core
l4_per
l4_wkup
omap_hwmod: i2c1: softreset failed (waited 10000
usec)
omap_hwmod: i2c2: softreset failed (waited 10000
usec)
omap_hwmod: i2c3: softreset failed (waited 10000
usec)
print_constraints:
dummy:
NET: Registered protocol family
16
GPMC revision
5.0
OMAP GPIO hardware version
2.5
2.5
2.5
2.5
2.5
2.5
omap_mux_init: Add partition: #1: core, flags:
0
OMAP3 Beagle Rev: unknown
2
Found NAND on
CS0
Registering NAND on
CS0
Unable to get DVI reset
GPIO
hw-breakpoint: debug architecture 0x4
unsupported.
omap_init_gpu: Could not look up
gpu
OMAP DMA hardware revision
5.0
bio: create slab <bio-0> at
0
SCSI subsystem
initialized
usbcore: registered new interface driver
usbfs
hub
usbcore: registered new device driver
usb
omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600
kHz
twl4030: PIH (irq 7) chaining IRQs
368..375
twl4030: power (irq 373) chaining IRQs
376..383
twl4030: gpio (irq 368) chaining IRQs
384..401
print_constraints: VUSB1V5: 1500 mV normal
standby
print_constraints: VUSB1V8: 1800 mV normal
standby
print_constraints: VUSB3V1: 3100 mV normal
standby
twl4030_usb twl4030_usb: Initialized TWL4030 USB
module
print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV normal
standby
print_constraints: VDAC: 1800 mV normal
standby
print_constraints: VDVI: 1800 mV normal
standby
print_constraints: VSIM: 1800 <--> 3000 mV at 1800 mV normal
standby
omap_i2c omap_i2c.3: bus 3 rev4.0 at 100
kHz
Advanced Linux Sound Architecture Driver Version
1.0.24.
NetLabel:
Initializing
NetLabel: domain hash size =
128
NetLabel: protocols = UNLABELED
CIPSOv4
NetLabel: unlabeled traffic allowed by
default
Switching to clocksource
32k_counter
Switched to NOHz mode on CPU
#0
musb-hdrc: version 6.0, musb-dma, otg (peripheral+host),
debug=0
musb-hdrc musb-hdrc: USB OTG mode controller at fa0ab000 using DMA,
IRQ 92
2
IP route cache hash table entries: 4096 (order: 2, 16384
bytes)
TCP established hash table entries: 16384 (order: 5, 131072
bytes)
TCP bind hash table entries: 16384 (order: 4, 65536
bytes)
TCP: Hash tables configured (established 16384 bind
16384)
TCP reno
registered
UDP hash table entries: 256 (order: 0, 4096
bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096
bytes)
1
NetWinder Floating Point Emulator V0.97 (double
precision)
audit: initializing netlink socket
(disabled)
type=2000 audit(0.179:1):
initialized
ashmem:
initialized
VFS: Disk quotas
dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat,
Inc.
msgmni has been set to
1001
io scheduler noop
registered
io scheduler deadline
registered
io scheduler cfq registered
(default)
OMAP DSS rev
2.0
Serial: 8250/16550 driver, 4 ports, IRQ sharing
enabled
omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP
UART0
omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP
UART1
omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP
UART2
console [ttyO2]
enabled
omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP
UART3
brd: module
loaded
loop: module
loaded
mtdoops: mtd device (mtddev=name/number) must be
supplied
omap2-nand driver
initializing
No NAND device
found.
No NAND device
found.
OneNAND driver
initializing
asix
cdc_ether
smsc95xx
net1080
cdc_subset
zaurus
usbcore: registered new interface driver hwa-
rc
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host
Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number
1
ehci-omap ehci-omap.0: irq 77, io mem
0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI
1.00
usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
usb usb1: Product: OMAP-EHCI Host
Controller
usb usb1: Manufacturer: Linux 2.6.39
ehci_hcd
usb usb1: SerialNumber: ehci-omap.
0
hub 1-0:1.0: USB hub
found
hub 1-0:1.0: 3 ports
detected
uas
Initializing USB Mass Storage
driver...
usbcore: registered new interface driver usb-
storage
USB Mass Storage support
registered.
android
init
f_adb
init
android_register_function
adb
f_mass_storage
init
usb_mass_storage
mousedev: PS/2 mouse device common for all
mice
input: gpio-keys as /devices/platform/gpio-keys/input/
input0
input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/
i2c-1/1-0049/twl41
i2c /dev entries
driver
Linux media interface:
v0.10
Linux video capture interface:
v2.00
OMAP Watchdog Timer Rev 0x31: initial timeout 60
sec
twl4030_wdt twl4030_wdt: Failed to register misc
device
twl4030_wdt: probe of twl4030_wdt failed with error
-16
device-mapper: uevent: version
1.0.3
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-
devel@redhat.com
usbhid
usbhid: USB HID core
driver
logger: created 64K log
'log_main'
logger: created 256K log
'log_events'
'log_radio'
'log_system'
ALSA device
list:
No soundcards
found.
oprofile: hardware counters not
available
oprofile: using timer
interrupt.
TCP cubic
registered
10
17
Registering the dns_resolver key
type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev
3
ThumbEE CPU extension
supported.
omap_pmic_register_data: unable to find map
mpu
omap_vdd_data_configure: PMIC info requried to configure vdd_mpu_iva
notpopulata
voltdm_scale: No voltage scale API registered for
vdd_mpu_iva
sr_init: No PMIC hook to init
smartreflex
smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver
initialized
smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver
initialized
SmartReflex Class3
initialized
clock: disabling unused clocks to save
power
omapfb omapfb: failed to allocate
framebuffer
fbmem
omapfb omapfb: failed to setup
omapfb
omapfb: probe of omapfb failed with error
-12
regulator_init_complete: VDVI: incomplete constraints, leaving
on
regulator_init_complete: VDAC: incomplete constraints, leaving
on
drivers/rtc/hctosys.c: unable to open rtc device
(rtc0)
omap_vout omap_vout: probed for an unknown
device
Waiting for root device /dev/
mmcblk0p2...
mmc0: new high speed SDHC card at address
0007
mmcblk0: mmc0:0007 SD4GB 3.70
GiB
mmcblk0: detected capacity change from 0 to
3980394496
mmcblk0: p1
p2
EXT3-fs: barriers not
enabled
kjournald starting. Commit interval 5
seconds
EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running
e2fsck is red
EXT3-fs (mmcblk0p2): using internal
journal
EXT3-fs (mmcblk0p2): recovery
complete
EXT3-fs (mmcblk0p2): mounted filesystem with ordered data
mode
VFS: Mounted root (ext3 filesystem) on device
179:2.
Freeing init memory:
208K
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/
oom_score_adj inste.
init: untracked pid 48
exited
init: untracked pid 67
exited
init: untracked pid 71
exited
init: untracked pid 73
exited
init: untracked pid 86
exited
init: untracked pid 96
exited
init: untracked pid 95
exited
init: untracked pid 101
exited
init: critical process 'servicemanager' exited 4 times in 4 minutes;
rebooting e
Unable to fix this issue ?
