Today I've had a very frustrating time trying to bring up a BeagleBoard
(arch/arm/mach-omap2/board-omap2beagle.c) with the 2.6.38
kernel. Unfortunately musb has been giving me great difficulties,
# modprobe g_ether
[ 25.276855] usb_gadget_probe_driver 1815: usb_gadget_probe_driver, no dev??
modprobe: Failed to load module g_ether: No such device.
After a great deal of printking, I've determined that the error is
coming from platform_driver_probe (platform.c:499). The code in question
appears to be a check ensuring that any devices being probe were first
registered. When the musb-hdrc module is probed, this check seems to
fail with code = 1 and list_empty(&drv->driver.p->klist_devices.k_list)
= 1.
What exactly is this check supposed to accomplish? Why would it fail
during musb initialization? The relevant call path is,
kernel_init -> do_one_initcall -> musb_init -> platform_driver_probe
Both musb_init and platform_driver_probe return with -19. As far as I
can tell, the board's init_machine successfully calls usb_musb_init
from omap3_beagle_init, so the device should be registered well before
arriving in musb_init.
Any ideas would be greatly appreciated. Cheers,
- Ben
there's no board-omap2beagle
# modprobe g_ether
= 1.
looking at your .config from previous mail, it's wrong. You're trying to
use am35x glue layer while you be using omap2430, just change:
- CONFIG_USB_MUSB_AM35X=y
+ # CONFIG_USB_MUSB_AM35X is not set
+ CONFIG_USB_MUSB_OMAP2PLUS=y
My apologies, s/omap2/omap3.
> # modprobe g_ether
> = 1.
Alright, fair enough. The mishmash of IP found in these ARM devices can
make it very difficult to determine the correct configuration at
times. Thanks for your help!
- Ben
