Hello
I’m encountering a technical issue with my BeagleBoard and would appreciate some help in troubleshooting.
I’m seeing the following error message when trying to initialize SPI communication on my BeagleBoard:
“Failed to Initialize SPI Communication”
I’ve checked the connections, verified the SPI configuration, and ensured that the necessary drivers are loaded, but I’m still unable to resolve this issue.
I have already checked https://forum.beagleboard.org/c/general/8
msbi Has anyone else encountered a similar error or have any insights into what might be causing it? Any guidance or troubleshooting steps would be greatly appreciated.
Thank you for your help!
Best regards,
Hello…what board are you using?
If you are using the BBB, try to look in /dev/bone/spi
or print out the output of gpioinfo
I noticed one of my UARTs were taken over by SPI
. gpioinfo
will tell you which of those pins are taken over by SPI
P.S. In any light, please use the `gpioinfo’ command to find the output of what is already allocated to the pin headers.
I will boot my board and tell you what I am seeing on my end with what kernel and image: Updates on the way…
@gregbowers …
gpioinfo | grep spi*
line 2: "P9_22 [spi0_sclk]" "P9_22" input active-high [used]
line 3: "P9_21 [spi0_d0]" "P9_21" input active-high [used]
line 4: "P9_18 [spi0_d1]" "P9_18" input active-high [used]
line 5: "P9_17 [spi0_cs0]" "P9_17" input active-high [used]
line 14: "P9_31 [spi1_sclk]" "P9_31" input active-high [used]
line 15: "P9_29 [spi1_d0]" "P9_29" input active-high [used]
line 16: "P9_30 [spi1_d1]" "P9_30" input active-high [used]
line 17: "P9_28 [spi1_cs0]" "P9_28" input active-high [used]
That is on a BBB with kernel 5.10.168-ti-r77
and image BeagleBoard.org Debian Bookworm IoT Image 2023-10-07
Yeppers…
